Question about Universal Indoor Outdoor Clock, Atomic, 13-1 2in, Black - UNV-10417
Set the correct time on Univeral 10417 clock - Universal Indoor Outdoor Clock, Atomic, 13-1 2in, Black - UNV-10417
Setting clock on GE electric stove
Range Setting the Clock and Timer Non-Electronic Clocks: To set the clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
Digital Clocks: To set the clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
Electronic Clocks: To set the clock touch the Clock pad. Touch the number pads. Touch the number pads. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
Nov 06, 2016 | GE Kitchen Ranges
How to set the time
press and hold clock set, press hours button to correct hour and then minutes button to correct time. Then release the hours set button.
Or
press and release clock set, hours and minutes will flash, press hours button to correct hour and then minutes button to correct time. Then release the hours set button.
Instructions are sometimes specific to make and model.
Jul 08, 2016 | Audio Players & Recorders
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
I have a clock that will not get correct time. I have no way yo set it . Model #44100 Equity.
All Equity Insta-Set clocks automatically set the correct time and date when you turn on the power. Occasionally, the automatic time-setting feature malfunctions and you must reset the time yourself. Manually changing the time to the correct time on an Equity Insta-Set clock requires the push of only a few buttons to get the clock back on track:
1. Press and hold the "Alarm Set" button for five to seven seconds, the year will begin to blink when the clock is ready for adjustment.
2. Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock
3. Set the month, day, hour and minute. Press the "Alarm Set" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
4. Press the "Alarm Set" button after setting the date and time to store the information into your clock's memory.
Best regards,
gylacz
Mar 18, 2011 | Audio Players & Recorders
How do you set the time? I figured out the alarm clock but can't find a way to set up the time.
Setting the Clock
1. Press and hold the HOUR button for 5 seconds (Fig. 5). The time will begin to flash
2. While the time is flashing, press the HOUR button until you reach the correct hour. Then press the
MINUTE button (Fig. 5) until you reach the correct minute.
NOTE: PM indicator will appear on the left side of the clock face for evening hours (Fig. 5). If the
PM indicator is not illuminated, the hour is set to AM. Be sure to set the time for the correct
12-hour period - AM (morning) or PM (evening).
NOTE: After 5 seconds, the time will stop flashing and it will be set.
Mar 03, 2011 | Homedics SS-4000 Clock Radio
Sony clock radio with auto time set is always 4 minutes fast.
This is easily fixed. Set the time manually the 1st time. Make sure you use the CORRECT time, which is four minutes less than what the clock said when you first plugged it in. Once you reset the timing, it will remember the four minute difference and always show the correct time.
Sep 11, 2010 | Sony Dual-Alarm AM/FM Clock Radio with...
Oregon Scientific Model 323a--Atomic clock...the atomic clock keeps setting itself to one hour behind what time it actually is in my time zone...I mannually re-set the clock to the correct time...but when...
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
Mar 21, 2010 | Oregon Scientific RM323A Travel Alarm...
How to set clock in 2000 GMC JIMMY
Owners manual: 3-10:
Setting the Clock for Systems with HR and
MN Buttons
Press and hold HR until the correct hour appears on the
display. Press and hold MN until the correct minute
appears on the display. To display the clock with the
ignition off, press RECALL or HR/MN and the time
will be displayed for a few seconds. There is an initial
two-second delay before the clock goes into the
time-set mode.
SET Button
Press SET. Within five seconds, press and hold the
SEEK right arrow until the correct minute appears on
the display. Press and hold the SEEK left arrow until the
correct hour appears on the display.
Nov 13, 2009 | Car Audio & Video
Time not correct
press mode button once.
Then press set until the time zone is on the correct setting
then press mode again
Dec 22, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Setting the clock
Setting the Clock for Systems with the
Set Button
Press SET. Within five seconds, press and hold the right
SEEK arrow until the correct minute appears on the
display. Press and hold the left SEEK arrow until the
and MN Buttons
time-set mode
Nov 13, 2008 | 2002 Chevrolet Silverado 2500HD
Universal Indoor Outdoor Clock, Atomic, 13-1 2in, Black - UNV-10417 Logo
208 people viewed this question
Top Universal Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
 Grubhead
Grubhead
richie46
Are you an Universal Audio Player and Recorder Expert? Answer questions, earn points and help others
