Question about Panasonic NN-S753 Microwave Oven
Door does not secure when closed
Oven will not work because door latch does not catch
Unit is labeled "inverter"
  • joy murray Jan 09, 2009
    I have NN-A773. Door open button doesn't seem to make contact with anything, so door latches cannot engage.
    Champion:
  • 208 Answers
Hi , Either you have a faulty door interlock switch(es), or the door latches (on the door) have been damaged and will not activate the interlocks. either way, you have to be conversant with adjusting microwave latch assemblies once the repair has been effected AND THE USE OF AN OVEN LEAK DETECTOR IS IMPERATIVE for final testing or the end user will be subjected to harmful levels of microwave radiation.
Posted on Feb 07, 2009
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
Door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
Feb 10, 2008 | Emerson MW8987B/W Microwave Oven
Door catch is stuck in unit so door won't close and microwave won't work
No, the only way is to take it to a technician. The door and catch has about 4 safety interlocks to stop you getting microwaved. The case has security screws only the techs can undo.
Apr 07, 2016 | In Microwave Ovens
Door will not close without slamming
Possible causes - door switch, or door switch assembly out of adjustment; plastic latch guides on door switches worn; door hinge worn, causing door to be out of alignment. If it's the last one, the unit needs to be checked for microwave radiation.
Dec 22, 2013 | Panasonic Inverter Countertop Microwave
Bosch integrated microwave doesnt start/close
Door latch settings are out because door slamming and abuse of unit
Dec 02, 2013 | Bosch Microwave Ovens
Neff H7871 oven door does not stay closed. Catches do not appear to be working
The door latch is either cracked or broken.The door when gets closed the door latches clicks.But if the door latch is loose or cracked it will not click and door will not close.The door needs to be disassembled and the door latch has to be replaced, if the latch is cracked.Also to check the latch from inside the door needs to be removed.-------- This will help.thanks.Helpmech.
Jun 29, 2011 | Neff Microwave Ovens
DOOR CATCH NOT CLOSING, FEELS LOOSE. ELECTRONICS STILL WORKING - JUST SHOWS 'PLEASE CLOSE DOOR'. NOT SURE IF WORTH A REPAIR OR BUY NEW.
Most likely it is a mechanical problem with door safety switch. Unplug the unit from power! If you take the cover off, you will be able to determine if switch is defective by using ohm meter. You may be lucky and find a broken door latch or loose switch holder - look for lose plastic parts. !!! Do not attempt to bypass safety switch.
Feb 09, 2011 | Panasonic NNA554 Convection/Microwave Oven
The door wont open. The button works but wont release the latch for he door to open
Door catches.
One of the latches has broken off and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Jan 19, 2011 | Frigidaire PLMB209DC Microwave Oven
The door latches wont latch
Door catches.
One of the latches has broken off and is not lifting the dother latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Jan 03, 2011 | Sharp R-1480 Microwave Oven
Panasonic NN-S753 Microwave Oven Logo
599 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
