Question about Toshiba TW40F80 40" Rear Projection Television
No pictures and no sound on Toshiba TW40F80 television
Hello! When i turn the power on, the red power light on the front turn on, but no pictures and no sound appear! The problem appear when i'm looking the television, and whitout advice, i lost the picture and the sound in the same time, and the red power light still on. I need help for resolve this malfonction. I didn't see anything whit a visual inspection of the components inside. Thank's a lot for the resolution of the problem. Michel!
  • garylmiller Nov 17, 2007
    I have checked all the fuses and they are all good. And my power light blinks on and off.
    Genius:
  • 1,694 Answers
Check soldered-in micro fuses in power supply. Ex.--F851,F852.
If there is a blown fuse, identify which B+ circuit it protects.
Most common - convergence IC's bad===replace.
Need more help? Let me know.....T.
Posted on Oct 23, 2007
Toshiba tw40f80 cannot adjust green and blue
ok, if you do have a sound problem it is separate from the convergence trouble; this set uses two STK-392-110 ic's. you need to change both and any of the resistors near them that may be gone or open---then adjust the set with the original remote--you can do the adjustments in the customer menu or if needed in the TECH menu-I can tell you how to get into that menu--if you have no sound from the speakers in the set that is a separate issue.
I do this here for free--if you have questions or need help reply here--if this has helped you give me a vote here.
Most of these sets with a convergence problem just need the two chips replaced and the set adjusted---you can buy both chips on Ebay for less than 14 dollars plus shipping.
Aug 29, 2009 | Toshiba TW40F80 40" Rear Projection...
Tv clicks on red light comes on then begins to blink no picture
Well it seems more to be an issue with the ballast, that doesn't have enough voltage to keep on with the lamp. And the ballast is trying to ignite, that's why you hear that clicking sound. Ballast are not that expensive, they're running around 60-70 dlls, It's worth to try.
Jul 30, 2009 | Toshiba TW40F80 40" Rear Projection...
I have sound but no picture?
Have you replaced the lamp before? If not then it's most probable you need to replace it, also listen closely to see if you notice any strange noises like a clicking, humming, whirling or whinning sounds... if you don't hear any of those noises, i recommend you replace the lamp first, but if you have those noises and need free troubleshooting bc it could either be a color wheel or a ballast go to discountdashmerchantdotcom the troubleshoot is free
Jul 01, 2009 | Toshiba TW40F80 40" Rear Projection...
Have a Toshiba 42H82 rear projection TV
Sounds like a power supply problem. You will need your tech again.
Nov 13, 2008 | Toshiba 42H82 42" Rear Projection...
No picture or sound on my toshiba tv
In this unit it's likely the convergence amps are the cause. Those and possibly the 2.2ohm resistors (especially R7726) in the yoke return path - that's why you found the open fuse.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Oct 21, 2008 | Toshiba 42H81 42" Rear Projection...
Tw40f80 toshiba
YOU SHOULD CALL YOUR THE TOSHIBA COMPANY FOR THEM TO FIX IT.
Jan 16, 2008 | Toshiba TW40F80 40" Rear Projection...
Tv not powering up
Check micro fuses in power supply,Ex. F851,F852,etc.
Common cause is convergence IC's are bad,located on large heat sinks.let me know....T.
Oct 23, 2007 | Toshiba TW40F80 40" Rear Projection...
Toshibe CF32G50 - Red Flashing Light
YOUR SET IS TRIPING MAYBE POWER SUPPLY IN TV SET
Jul 11, 2007 | Toshiba CF32G50 32" TV
Televison & Video Logo
73 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
