Question about Universal 10417 Indoor/Outdoor Clock, Atomic, 13-1/2in, Black UNV10417 UNV 10417
How to set the time on Universal 10417 Clock
I need a copy of the manual for my clock to reset the time.
Need to reset atomic clock to Virginia time zone; now 4 hours ahead
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
May 31, 2012 | La Crosse Radio Controlled Atomic Clock
Clock Manuals
Hello
I've the user manual to your Sony AM/FM clock radio. There are so many model numbers to these devcies. If you give me the exact model number [not the serial number], I'll search in my system library for that manual. If has,, if you send your email address to me by Fixya comment box, I'll send a copy of it to you, if I have it.
If you need only a manual to sony AM/FM clock radio, send your email address to me now. I'll send you one[ user manual for SONY ICF-707 AM/FM clock radio. OK
Oct 31, 2011 | Sony Dual-Alarm AM/FM Clock Radio with...
7:15 p.m., 10/6/09-I don't know how to set up the time & date on the machine. I need clear, step-by-step instructions. Help! AT&T digital answering machine model 1738. THANK YOU!! Barbara S.
To set the clock. You must set the clock once so that the system announces the correct day and time with your messages. After this, if you subscribe to Caller ID, the system will automatically reset the clock each time new call information is received.
Press PLAY/STOP to exit at any time while
setting the clock.
1 Press and hold CLOCK until the Message Window displays C, and the default day is announced.
2 To change the day setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3 Press and release CLOCK. The current hour setting is announced.
4 To change the hour setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5 Press and release CLOCK. The current minutes setting is announced.
6 To change the minutes setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct minutes setting is announced.
7 Press and release CLOCK. The current year is announced.
8 To change the year setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
9 Press and release CLOCK. The new day, time, and year are announced.
To check the clock, press and release CLOCK.
If you need futher instructions for your answering machine you can download a copy from:
http://phone.manualsonline.com/manuals/mfg/att/1738.html
Please rate this solution. Thanks..
Oct 07, 2009 | AT&T Lands Phones
Alarm doesn't go off when set. I've adjusted the time. Still nothing
Try removing the battery and unplugging it form the wall for a few hours. This will allow the microprocessor time to discharge and reset to it normal functions. After letting the Clock/Radio discharge, you can put the battery back in the Clock/Radio and see if it has reset itself to the factory setting.Then use the link (http://www.emersonradio.com/owners) copy the web page link and paste it into the address bar of you browser. It will take you to Emerson home page for owners manuals. There you can find your model clock radio and follow the instructions for resetting the clock radios functions. I hope this information helps you with your problem.
May 20, 2009 | Emerson Smartset Clock Radio
The clock does not show the correct time.
[http://www.emersonradio.com/owners/SmartSet%20Series/] copy this web link and paste it into the address bar of your web browser. It will take you to the Emerson customer web page for the pdf copies of the SmartSet Clock/Radios. You will need a pdf reader and writer to read and make a copy of the owners manual for yourself.Find the make and model number of your Clock/Radio. The instructions for resetting the time after changing the battery will be in the manual. I hope this information helps you with your problem. Than you for using FixYa and have a nice day.
Jan 02, 2009 | Emerson Smartset Clock Radio
Resetting Clock Radio
[http://www.emersonradio.com/owners/SmartSet%20Series/] copy this web link and paste it into the address bar of your web browser. It will take you to the Emerson customer support web page for the SmartSet Clock/Radio owners manuals.These manuals are in pdf form, so you will need a pdf reader to read the manual.You will also need a pdf writer to make a copy of the manual for yourself. Once there locate your make and model of Clock/Radio and open the link. You can make a copy of the owners manual using the print function of your computer to make a pdf copy. I hope this information help you with your problem of finding a owners manual for your Clock/Radio. Thank you for using FixYa and have a nice day.
Dec 22, 2008 | Emerson Smartset Clock Radio
Reset cd clock radio? (manual missing)
Make sure the clock is in standby mode, as opposed to playback mode. Press time set button — the clock digits will blink. If they don't, you're in playback mode. Press the hour button to adjust the hour. Press the minute button to adjust the minute. Press time set button to confirm the time.
Sep 30, 2008 | TruTech Clock Radio
Clock setting on alpine iva-w200
Copied from Alpine-usa.com support page:
Setting item: CLOCK ADJUST
Further setting items : HOUR / MINUTE / TIME ADJUST
Setting content: 1-12 / 0-59 / RESET
The clock-adjusting mode is canceled when the power is turned off,
when [RETURN] or [CONTROL] is touched.
Setting item: DAYLIGHT SAVING TIME
Setting content: OFF / ON
Setting the Time
HOUR: Adjust the hour.
MINUTE: Adjust the minute.
RESET: If the clock shows less than 30 minutes past, the
minute will be “: 0”; more than 30, the hour
advances.
Setting Daylight Saving Time
ON: Place the Summer Time mode ON. The time advances by
one hour.
OFF: Return to the ordinary time.
Aug 19, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Emerson research smartset cks2237
http://www.emersonradio.com/owners/SmartSet%20Series/CKS2237_073106.pdf Copy this link and paste it into the address bar of your browser. It will take you to the users manual for the model CKS2237 clock radio. On pages 7-10 you will find the instructions for setting the time for the clock. I hope this information helps you solve your problem.
Apr 29, 2008 | Emerson Smartset Clock Radio
Needles flying around the clock
I have a mantle clock version and to set the clock to recognize the radio signal, I need to hold down both the ET and PT time zone buttons for a few seconds. The clock hands will then continue to move until they reset themselves to the correct time.
Nov 03, 2007 | La Crosse Radio Controlled Atomic Clock
Universal 10417 Indoor/Outdoor Clock, Atomic, 13-1/2in, Black UNV10417 UNV 10417 Logo
127 people viewed this question
Top Universal Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
 Grubhead
Grubhead
richie46
Are you an Universal Audio Player and Recorder Expert? Answer questions, earn points and help others
