Question about Electrolux Dryers
Eied55hiwo code e66
Dryer will not start code e66
2 Suggested Answers
michiganfan9
  • 179 Answers
SOURCE: Affinity Dryer code E66
It could be the door is coming open just enough to trigger the switch to the off position. Even though the door looks closed it could be partially open. Most likely the clips that hold the door shut are not tight enough that when the clothes hit the door it pops open a little bit. These clips are basically springs and over time they loosen up.
Posted on Aug 25, 2012
How to take front panel off an Electrolux EIED55HIWO dryer?
Good Afternoon Friend,
I understand you want to know how to remove the front panel of your Electrolux dryer, model# EIED55HIW0. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able to remove the front panel with ease. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Electrolux EIED55H Dryer
WHAT DOES THE E66 MEAN ON MY AFFINITY DRYER
Good Morning Friend, this is Z, Thank you for your inquiry!
An error code E66 is associated with the heating element relay. A technician would typically check the ohm resistance of the relay to determine if it is the cause of the error code on your Frigidaire dryer. If the readings are incorrect, the heating element is replaced. If the readings are incorrect, it could potentially be the main control board. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis. I hope this helps explain the error code you are receiving.
May 21, 2014 | Frigidaire AEQ7000ES Dryer
Frigidaire FASG7073LW0 error "E66 HEATER" then "DOOR OPEN"
Hello Abe D - An error code E66 is associated with the heating element relay. A technician would typically check the ohm resistance of the relay to determine if it is the cause of the error code. If the readings are incorrect, the heating element is replaced. If the readings are incorrect, it could potentially be the main control board. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis. I hope this helps explain the error code you are receiving.
Jun 22, 2013 | Frigidaire Dryers
Electrolux
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
May 01, 2013 | Frigidaire Electric Dryer
Electrolux dryer EIED55HIWO
Hello - Typically 88:88 on an Electrolux dryer indicates a generic power failure code. Try resetting the unit by unplugging it or flipping the household breaker off. Wait approximately ten minutes.
Dec 10, 2012 | Electrolux Dryers
Error code e66
Hello wez1330 - Error code E66 indicates that the thermal limiter circuit is open. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the inlet or outlet thermal limiter for continuity. If the thermal limiter is open, tech will need to check for evidence of high temperature event and any resulting damage. If no futher damage is evident, the thermal limited and retest will need to be replaced.
Sep 29, 2012 | Electrolux Frigidaire Affinity 5.8 cu. ft....
Aug 24, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Electrolux dryer e63
Check heater coils andconnections for short circuits to the cabinet. Replace heater and/or wiring andretest.
Jul 29, 2012 | Dryers
Electrolux Gas Dryer: E66 error
Should the heater wire have electrical continuity to the housing
Mar 08, 2012 | Electrolux EIED55H Dryer
Dryers Logo
47 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
