1) Look at the bottom of the Mercury logo screen when it comes up.
2) Memorize or write down the -> enter BIOS Setup, or enter CMOS Setup key.
3) Restart the computer.
Let it go to Windows, then Start > Turn Off Computer > Restart.
Won't go to Windows? Hold down the CTRL and ALT and DELete keys AT THE SAME TIME. This will restart your computer.
AS SOON AS the monitor screen goes blank, (Windows is restarting), tap on the enter BIOS Setup key repeatedly.
Tap in 2 second intervals.
Hear a series of beeps? They are Stuck Key Error Code beeps, and you are causing them. Ignore the beeps.
Computer is off?
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup (CMOS Setup) key.
The enter BIOS Setup window goes by F-A-S-T. The above method/s will get you into BIOS Setup.
Regards, joecoolvette
SOURCE: My mother bord is asus
Go to the Asus website. Click support. Follow the onscreen directions to find your board. Click on downloads. Your bios & drivers should be found available for free download. Hope this helps & please remember to rate my answer. thanks.
The problem is well known witht this model Toshiba - the problem is the fan stops working and then hence shuts down to prevent overheating - it does not take long once the laptop is hot. Without replacing the fan just reboot the laptop until you hear the fan start again on reboot.
SOURCE: I want Audio Driver for Mercury Mother Bord
IF YOU FRIENDS HAVING SYSTEM. THEY WILL BE HAVING REALTEAK AUDIO DRIVER IN THEIR MOTHERBOARD CD.THEN INSTALL IT TO YOUR COMPUTER THROUGH THE MOTHERBOARD CD.
