Question about Frigidaire FRS26ZSG
Fridgidare, freezer cold fridge warm
Model # FRT18SGAWH manufactured 1-05
freezer gets cold then ice crystals form coating the air vents, fridge is on recomended setting but is too warm. Have unplugged to and let ice melt, fridge gets cold, next day its warm again.
  • Anonymous Mar 26, 2014
    only stays cold for one day then have to unplug it again
  • 82 Answers
Sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Posted on Jan 05, 2009
Fridgidare model number FRS26R2AWI , My Refidgirator side is working fine but the Freezer side is warm I took off the the freezer Coyle cover in the back of the freezer and they are warm any ideas ?
This does not make any sense because the fridge section gets cold air from the freezer via the damper mechanism that allows air into that compartment. The usual complaint is that the freezer is not that cold and the refrigerator is warm.
If your evaporator behind rear freezer panel is covered with ice the issue is with the defrost mechanism/heater element.
If compressor is always running and the entire evaporator is not nice and cold then you may be low on refrigerant.
Sep 06, 2017 | Refrigerators
Ice crystals on food in fridge
What is your temp in the fridge? Check that your door is closing all the way. You have several air vents along the middle of the back way, are you getting the ice crystals of food right in front of the air vents? If that's the case then that is also the problem. Right in front of the air vents is where air from you freezer enters the fridge. I would start with checking the temp in your fridge though.
Mar 14, 2013 | Amana Refrigerators
I have a maytag fridge (freezer on bottom) the fridge is not very cold. freezer has started to get ice near the door opening in the last week.
if you see ice near the door the door muat not be closing all the way or the gasket could be ripped,ice will form where warm and cold air are mixing together,did you remove any of the shelves or baskets in the freezer or in the fridge?i've seen people clean out the fridge and the shelves weren't put back in correctly keeping the door open,check that or food packages that might be hitting the door,when the warm air gets in it usually freezes the air ducts,this is why the fridge is warm,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer into the fridge section and then it returns through other air ducts so if warm air is getting in it will freeze up the air ducts,you can try shutting down the machine or unplug it,remove the food from the freezer and with a hair dryer hit the back inside wall of the freezer,blow the air up into the vent holes in the back wall,if you see water dripping down through the slots you have ice up in there,keep blowing the hot air up into the holes until you don't see any more water dripping,if you can remove the ice maker and remove the back inside wall of the freezer would be better.first check the freezer back wall to see if there's any frost or like snow on it,if so you could have a defrost problem,bad jazz board,this is the computer board that's behind your digital controls in the fridge section,bad defrost thermostat or heater,also do you mean the floor of the freezer has ice on it,you could have a blocked drain in the freezer.write back with more info and let me know what you find and hopefully i can help you better.
Sep 05, 2012 | Refrigerators
I purchased a bottom freezer Amana refrigerator when we built our house in 1999. The produce in the vegetable drawer keeps freezing! Everything else in the fridge is fine. Why does this happen?
Usually on bottom freezer fridges, there are two vents at the bottom of the freezer compartment where the cold air goes back into the freezer (cold air enters the fridge through the vent at the top/back of the fridge.)
If the vents at the back of the fridge are covered, the cold air will settle to the bottom of the fridge after it enters, and freeze your vegetables. The problem could be caused by ice build up in the evaporator coil of the freezer section also, but this will probably warrant a checkup from a pro.
One thing that can cause ice to build up inside those vents is moist air seeping in through a faulty door gasket. A thin coat of ordinary Vaseline on the gasket surface can help it make a better seal.
Dec 04, 2009 | Dishwashers
My GE Adora side by side refrig. has stopped making ice and I am having a hard time regulating the settings on it. The freezer is too cold and the refrig. section isn't cold enough. I also have noticed...
Defroster circuit/timer has failed.
The water line to the icemaker has probably frozen,so no ice. The cooling coils are in the freezer, and the cold air moves to the fridge via vents and circulation fan.
When it all ices up, no air gets to fridge, fridge gets warm.
Many models have a mechanical defroster timer located under the lower front kick panel. Manually rotate the timer until you hear the compressor stop.
Defroster heater then should come on and you hear scorch/hiss/gurgle of defrost sounds. If the timer is working, the fridge should come back on after about a half hour or so.
Sometimes timer fails, sometimes heater element fails. There is also a defrost thermostat that's part of the heater assembly.
Oct 23, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
The frreezer is too cold, the refrigerator is not cold at all.
most casses the gas level getting too low so the fridge gets warm and the compressor never puts off
May 12, 2009 | Kenmore 16.7 cu. ft. Freezerless...
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
May 07, 2009 | Refrigerators
Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Bosch KGV24V01GB Fridge Freezer - Model has Auto defrost feature but freezer section is all iced up. What do I do?
Try increasing the temperature of the freezer (closer to -5) for a few days. It could be you have it too cold.
At certain times it should feel warm in some places on the sides, or you may hear a fan running. If you don't get this, there may be a fault in the defrost circuit, timer or fan.
Make sure vents are clear, and that door seals are in good condition. A faulty door seal admits warm damp air which then freezes.
Where is the ice forming?
Jun 28, 2008 | Bosch Refrigerators
Refrigerators Logo
634 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
