Question about Refrigerators
Do you know where to get a Traulsen URS 36 DT manuel?
Hi I'm in HVAC and just purchased an older model Traulsen for my wife. Working, but would like a service manuel if I can get ?
3 Suggested Answers
  • 401 Answers
SOURCE: Need replacement R12 refer and freezer
You can use R134a compressors with the Poly oil in them and use R12 or R134a (flush the remaining old mineral oil out of the system first). Match your BTU requirements.
Posted on Dec 30, 2009
  • 1078 Answers
SOURCE: Service manuel for traulsen RBC 100-003 5 or 6
https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/TR35850%20Rev%200407.PDF
see if you can access this site and get your manual.
Hope this helps. Let me know if I can be of any more help.
Posted on Jun 26, 2010
Hi i'd like to have the plan of traulsen's refrigerators and freezers model URS 48DT
https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/TR35749%20Rev%200503.PDF
Only manual found is the UR48DT. Try to access this site for the manual. If you can not, let me know and I will try to email it to you.
Nov 18, 2010 | Traulsen Refrigeration 48'' Wide x 24''...
Does anyone know how much energy the traulsen urs48dt should be using per day/month or year? Note that the compressors in my case have moved to the garage which I assume impacted efficiency. I love the...
Ok, next question, when he replaced the compressors, did he modify the evap sections with TX Valves and remove the cap tubes? Per Traulsen specs, all remote units are factory set with TX valves while local units are equipped with cap tubes. If this modification was not done, it may be your cause of excessive electical consumption. Then again, re-reading your recent post, the compressors were changed to 3/4 hp? From Traulsen specs your unit came with a 1/6 fridge compressor and a 1/3 freezer compressor, is that correct? Electrical consumption on these are URS48DT 11.2 Amps 1/6 HP & 1/3 HP (1288 watts) at full load, while a 3/4 compressor is 14.9 amps 3/4 HP (1713.5 Watts) at full load X2 = 3527 Watts, or about 3 times original. I may be off target, but from what I can assume, I am beginning to think your compressors are over sized, drastrically and that the evap units may not have been modified to TX Valve. Let me know if this helps or if there is any additional information you can provide. Current compressor model numbers, previous compressor model numbers, complete unit model/serial number would all be a help in determining your exact specifications.
Thanks
Richard
Jun 23, 2009 | Traulsen Commercial 2 Door Cooler /...
How do you adjust temps (Traulsen URS 48 DT)?
You can go to traulsen.com and download the owners manual for your model and serial number. I did and it was VERY helpful to me. Let me know.
Apr 06, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
Traulsen URS 48 DT Freezer in Freeze/Thaw Cycle/Fridge Side O.K.
I'm not intently familiar with this particular brand, but here's some ideas to check. If the thermostat sticks on, the freezer coils can freeze, blocking air flow and jamming circulation fan. This will cause the temp in freezer compartment to rise. When the ice on the coils thaw, the compartment starts to cool again, but the cycle will continue. Another thought is if this unit has a defrost timer that could be defective. Without seeing the unit, it's hard to determine the exact cause.
Hope this helps.
Jan 04, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
Reference manufacture date
Hello Rob,
I called Traulsen with your model and serial # and was able to ID the manufacture date, Oct 4, 1989.
We specialize in cooler/freezer gaskets. We also sell refrigeration hardware & accessories. We can get many Traulsen OEM parts below list price. We'd be happy to help you locate the parts you need.
Shoot us an email to orders@coolergaskets.com or call toll free at 855-288-2259
Thanks,
Matt
Coolergaskets.com
Dec 19, 2008 | Traulsen Refrigerators
Traulsen ur 48 dt freezer want go below 10 deg
The first place to look is to check the charge. Using guages check the low and high side pressures and their relationship to one another. I'm assuming your unit is a R-404 unit which, if fully charged and the condenser is clean, and the fan is operating, should have about 210 to 250 high side pressure. Other things to check: evaporator coil ice/frost free; defrosting properly to obtain a clean coil; all evaporator fans running. If low side pressure is above 30 PSI you have a weak compressor. Whatever, fix the Traulsen unit, its head and shoulders above anything else on the market today.
Nov 23, 2008 | Freezers
Set video on older 36" rca colour tv Model # f3667et
take hammer and give it the good ole smasharoni as hard as u can
Jun 13, 2008 | RCA F36673ET 36" TV
Refrigerators Logo
325 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
