ESP DEFECTIVE VISIT WORKSHOP
Hi guys, i have a E270CDI the ESP WARNING LITE comes on intermittently what does this mean, the SERVICE BRAKE warning also comes on at the same time as well as the ABS lite.
BearWeb
  • 357 Answers
SOURCE: Mercedes Benz C180 Fault Message Brake Assist.Visit Workshop BAS
Hi there
BAS is the Brake Assist System and if there is a malfunction it would only come into play in an Emergency stop while applying full pressure. BAS applies full braking force because people tend to lighten up their pressure on the pedal in these situations. I would suggest that the best thing to do is go to a Workshop or Service Center and have it checked out. Please remember to put a good rating on my profile.
Kind regards
Dustin Ellse
Posted on Jun 26, 2008
SOURCE: ABS, ESP, Level warning lights (2004 Allroad TDI)
I had the brake light switch replaced by a local dealer. Cost was $140 and it fixed the problem. Have driven the car for two weeks since and no lights and all systems normal.
Posted on Oct 15, 2008
  • 84 Answers
SOURCE: Service Brake message
Hello, You probably have brake pads that are worn down to the sensors. You will need to take it to whomever does your repairs. It could be either the front or rear pads or both.
If you find this info to be correct, please enter a (fixya) rating
Thanks, Gator241
Posted on Mar 02, 2009
  • 12 Answers
SOURCE: fit new indicator stalk to VW passat esp , abs light on now
the stalk should have no interference with the abs or esp set up what i would look at doing is checking your abs sensors they can go all of a flash...goodluck
Posted on Jun 19, 2009
matney68
  • 426 Answers
SOURCE: ABS & Brake warning lights turn on
it is possible but its also possible you have a wheel speed sensor acting up. you would have to have it scanned for codes
Posted on Jul 30, 2009
The spot for brakes on the dashboard has an IP lite up on it. what does that mean?
CHECK OR HAVE SOMEONE CHECK BRAKE FLUID LEVEL, BE SURE PARKING BRAKE IS NOT ON!
Jan 22, 2016 | Cars & Trucks
My 2006 e200k has come with the abs esp warning and says visit workshop. Thereafter the ABS light stays on. I travel from PMB to Durban and I need to drive back to PMB. I drove from PMB with no proble
If the car hasn't gone into "limp home mode" then you should be fine to drive it but go easy on the brakes as there won;t be any ABS to help assist with heavy braking.
Oct 07, 2014 | 2006 Mercedes-Benz E-Class
My 2001 c200 kompressors lights up the ESP visit workshop warning when I drive through a sharp curve at speeds above 50km/h? help
take it back to service provider and tell them its started since they did service at least they will tell you what it is even if they dont fix it unless it wasent there before it went then kick up a stink they will soon put it right
Feb 10, 2014 | 2001 Mercedes-Benz C-Class
Help!
Hi Dz, Don't panic, the warning you see is an automated service period reminder. The light will be extinguished when you visit a dealer or workshop with the scanning equipment which communicates with your vehicle, and like the fault code warnings will be extinguished with that equipment. Just as a matter of interest, deleting the fault code warnings do not repair defective units. If that is what you're doing, you may find that the vehicle fails the examination. have a diagnostic scan carried out before attending the government examination, just to be on the safe side. Regards John
Feb 19, 2012 | Cars & Trucks
Yellow warning indicator lamp of a tringle with an excalmation point in the center and a counterclockwise arrow arround the triangle ---what does it mean?
Check & replace if necessary the brake pedal switch placed above pedals on the support.
If the problem still occurs you might access the ABS & ESP ECU (Electronic Control Unit) using diagnostic equipment connected to the data link connector of the car, in order to pull out all DTC (Diagnostic Trouble Codes) memored.
Then you will be able to replace bad piece(s) and fix the problem by erasing all DTC stocked inside ABS ECU & reset it.
The ESP system means the Electronic Stability Program. If the ESP lights on the dashboard permanently the ESP system is faulty. You must access the ESP Electronic Control Unit (ECU) memory for pull out all DTC (Diagnostic Trouble Codes), using diagnostic equipment connected to the data link connector of the car. Then you will be full informed about bad pieces (e.g.: brake pedal switch, front right wheel abs sensor interrupted, ...). After bad pieces replacement you will be able to erase all faults memored by ESP ECU, in other words reset the ESP system and turn off the warning lamp on dashboard.
I'm convinced that your brake pedal switch is faulty because the glow plug warning sign went ON after ESP warning light. Just replace the brake pedal switch, see if rear stop lamps light when press the brake pedal, and test the car on the road.
Good Luck!
Sep 06, 2011 | 2005 Audi A4
The esp light went on first and then the glow plug warning sign on my 2005 TDi passat. said workshop assistance, what is the problem
Good Luck!
May 11, 2011 | 2003 Volkswagen Passat
My c200 kompressor has a problem with the ESP,how can i fix it?
In your car Electronic Stability Program system included many different sensors (yaw-rate sensor, steering angel sensor, body acceleration sensor, some more) if ESP visit Workshop message appear on your instrument display It's very hard to say witch sensor could be the fault without right diagnose most common faults are either steering angel sensor or yaw-rate sensor might be some other sensors if you replace yaw-rate sensor it's need to be calibrate by diagnose computer, if replace steering angle sensor it's need to do right way otherwise when you tern steering wheel fully left or right it will brake at first time then you have to be replace another one so like to advise you to get right diagnose and repair buy Mercedes specialist if do some thing wrong it's be more cost to you if you get right place to do it only you have to pay once.
Sep 03, 2010 | 2002 Mercedes-Benz C-Class
May 22, 2008 | 2004 Audi allroad
53 people viewed this question
 Grubhead
Grubhead
