Question about Garrity Replacement Bulb
Where is the spare bulb stored?
04-33
  • Jim Frey Nov 07, 2012
    I found it hidden under the spring in the cap of the battery compartment.
For '97 Ford Econo 150 - for non-working left tail light - do I replace tail light bulb, or is it solved in the fuse box.
You get at this from the inside; remove the interior trim in that corner and there's your housing. The bulb is nearly always the problem, but the socket simply turns out of the housing and you pop another bulb in. If you don't have a spare bulb take the old one in to any auto parts store and they will match it. Get a few since the one on the right side is the same age, ... lol. Hope that helps
May 16, 2011 | 1997 Ford Econoline
How do you change the bulb in a mini maglite?
Carefully.....
Check in the base of the torch and you will see the spare bulb. you need to pull the spring out to get at it.
Next unscrew the top off the torch to expose the bulb.
The bulb is easily removed by gently pulling straight out. Replace the new bulb in the same way, lining the two pins up with the holes (doesn't matter which way round) and wipe the bulb clean of any finger grease etc.
Screw the top back on and replace the spring in the base before screwing the base back on..
Replacement bulbs, and all other parts for that matter, are easily sourced at any good outdoor store that stocks MAG.
Hope this helps..
Jul 05, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Low beams do not work but High beams do
Yes you are... but only the bad onemake sure must be carefully when you take out the old bulbs. take this with you to the spare part..ask the store for the same type...and some times you must say to them type and brand of your car.
when you install new bulbs remember don't touch the glass area 'cause can make light not bright...good luck
Jan 30, 2009 | 2006 Mazda 3
FM/AM GE Digital clock radio model#7-4966 display bulb burned out
Geri, I recently had the same problem with my GE model 7-4966 clock radio. The radio manual states that there is a spare bulb included and stored on the underside of the battery compartment door on the bottom of the clock radio. To replace the bulb: 1. Twist the bulb bar handle on the underside of the radio to unlock and remove the holder. 2. Carefully pull the bulb out of the holder and replace with the spare bulb. 3. Place the holder back in place, twist the bar handle to the right to "lock" the bulb holder in position.
In case you can't find a spare bulb, the manual states "use only a GE259 or equivalent 6.3 volt, wedge base bulb. A clerk at Radio Shack told me she could get a replacement bulb.
Dennis60
Jan 27, 2009 | Audio Players & Recorders
How to change bulb in bumpers on volvo v40
The amber lights in the bumper are a complete unit, (bulb cannot be removed without some or all of the amber light assembly) so unfortunatey you will have to go to your Volvo spare parts store & pick one up - front & back are different, as are left & right - check it. I paid €25 for a unit in Ireland.
Changing is a case of unscrewing as much of the bumper as you need to access it and clipping it out. It takes quite a bit of force to clip the new unit back.
Unfortunately I can't help about dash bulb.
Ciaran
Dec 11, 2008 | 2007 Volvo V40
LIGRT BULBS BLOWN WHERE TO BUY NEW ONES SHARP R9320 MELB AUSTRALIA
These bulbs should be available at most grocers, home improvement stores, hardware stores, or appliance parts stores.
Otherwise you can find Sharp spares here and support here.
Aug 26, 2008 | Sharp Microwave Ovens
The bulb is not working in my Panasonic NN-A554W inverter slimline combi oven and I do not know the size/number to obtain a replacement. I know you are supposed to get in an engineer but that is a bit...
It's a T170 type bulb (should be very common at a grocery store or hardware store) rated at 240 volt, either 20 or 25 watt is okay, and if you order it as a spare online, it may come with the 90-degree bracket.
You can see a good photo and detailed specifications here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 06, 2008 | Panasonic Microwave Ovens
Panasonic Dimension 4 the Genius Microwave/Convection NN-C888W I cannot seem to get into this to replace the electric light bulb. Please can you help me.
i had to take the entire cover off the microwave (it is held in pace by screws at back as well as the bottom). Take the busted bulb to hardware store (bunnings) or panasonic spares and replace. Note I have a slightly different models (nn9853, nn9807).
AH
Apr 30, 2008 | Microwave Ovens
Life of a bulb
I too have an early P1 series Livingstation with a bulb that MAY be going out. I've been searching online and found several suppliers with prices ranging from $249 to $367. the Epson store seems to be the cheapest and probably most reliable supplier at $249 including shipping! http://www.epson.com/cgi-bin/Store/ProductQuickSpec.jsp?BV_UseBVCookie=yes&oid=40809413&category=
The stated life of the bulb is 10,000 hours ... and I've had my LSP1 for perhaps 4 years. We use it kind of heavily - and I'd say we've used it roughly 30-40 hours a week... and over 4 years I'd say that equates to 200 weeks at 30-40 hours = 6000-8000 hours of use already. So, once I replace the current lamp - if the replacement works well... then I'll immediately buy a spare bulb. That will enable effective use for another 20,000 hours with the new replacement and spare. That hould last me about 9-11 more years for only $500 or so.... assuming I get 4.5-5.5 years of use per bulb.
Jan 05, 2008 | Epson Livingstation LS57P2 57" Rear...
Garrity Replacement Bulb Logo
Top Garrity Camping, Backpacking & Hiking Experts
Tom Queen
Tom Queen
aron5566
aron5566
tjcwriter
tjcwriter
Are you a Garrity Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
