Question about Athenatech A202 (DNHA202)
SATA Hard drive
My stat hard drive has some bugs in the back oopening real small like worms or such. is bug spray OK or should i use RAID or something? also it smells a little like feet.
You should probably just get a new SATA drive, it's probably safer all around.
Posted on Jan 07, 2009
Small brown bugs that can fly are all over my fruit trees
> problem with Memory Cards & USB Flash Drives
If they have red shells, they are "ladybugs", and are good to have -- they eat other insects. Talk to the Agricultural Department of your local government.
Mar 11, 2014 | Electronics - Others
How can I connect my hard drive of my toshiba a15-s127 which wont power-up because of a corrupt/missing file, to my second computer to back it up ... and will it transfer any bugs that could be on that old...
You must remove the hard drive and get an external enclosure for it. Best Buy or Microcenter will be able to help you with finding the correct enclosure (You will want a 2.5" enclosure in either IDE or SATA. The hard drive will have the type printed on it to help you decide).
This can then be plugged into your new computer to transfer data. Bugs won't be transferred, but viruses could be if they infected your personal documents, but your virus scanner should be able to catch that.
Mar 03, 2011 | Toshiba Satellite A15-S127 Notebook
Mobo will not power on if two sata drives are connected . The fans on system and cpu will not spin. System will power on and fans will spin if second hard drive is unplugged and system will post and boot...
good day sir, hi, its either your motherboard does not support 2 sata drives simultaneously or your motherboard sata port is bugged.
Choices:
1. get a bigger hard drive
2. use a PCI to SATA card for your extra SATA hard drive.
3. replace your motherboard.
Hope this may help.
Dec 17, 2009 | ASUS Computers & Internet
The hard drive fell over and now it wont stop making alarm noises and it wont work
I'm afraid the disk got damaged internally. If it was set to RAID 0 mode (speed), at least half, possibly all data is probably lost.
If it was set to RAID 1 (safe) mode, maybe the data can be recovered. It's not very likely, I'm afraid, because in this case the drive would make noises but would also work. I fear you had two 512 Gb disks configured as RAID 0. For RAID 1, it is sufficient to open the enclosure - it has three small screws on the side - and unscrew the four internal screws holding the drive caddy. Extract the caddy, unscrew both hard disks, and try connecting them, one at a time, to an external SATA to USB adaptor (Kraun makes a very handy USB to SATA-EIDE3.5-EIDE2.5 adaptor with external AC, but many exist).
In RAID 1, one of the disks might be detected and work (of course, both could have been damaged, but that would be real bad luck).
In RAID 0, sometimes it is possible to partially recover one of the disks (with half the data). It takes lots of luck, not all RAID 0 enclosures support this.
If you can't recover the disks easily (the RAID 1 trick is almost immediate), I'm afraid your only option is a data recovery service :-(
Nov 04, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
Dell inspiron 1721 hard drive not recognized for Vista reinstall
ok, theres a small issue with the raid controller. You have to install a 3rd party raid driver (its on the dell cd) to continue, OR, you can set that BIOS's hard drive controls to ATA or LEGACY (legacy would likely work best, but youd have no 'raid' functions, but who sets up raid drives on a notebook?). Your last option is use the dell discs to restore, and inssert the windws disc when prompted
Nov 04, 2009 | Dell Inspiron 1721 Notebook
I am using a single SATA II Drive in a new system, GIGABYTE GA-MA790X-UD4P, AMD 790X & SB750 chipsets. I know I can let the SATA II be a "Native IDE" but isn't that loosing any benefit of the SATA II...
The "Native IDE" mode causes the motherboard to "report" to the Operating System that the installed SATA drive is an IDE drive, rather than reporting "no IDE drives installed", and then requiring the Operating System to load a SATA device-driver to interface with the SATA drive.
Using RAID to "mirror" your hard-drive is a very-cool way to provide a "real-time" and "up-to-date" backup.
Should one of your drives suddenly "die", the other will continue to work, and you can buy another hard-drive, re-establish the "mirroring", and continue to work productively -- no fiddling with offline/stale backups.
Sep 18, 2009 | Gigabyte GA-MA790X-UD4P Motherboard
Harddrive is not detecting bios
get a hard drive kit that will connect it via usb or get a PCI card that will allow you to install the PCI card into a PCI slot and then attach the hard drive to the PCI card ( ensuring you select the correct PCI card ) ie if its a sata drive then get a sata PCI controller card and if its IDE then get an IDE PCI controller card.
Also check for motherboard updates for your computers motherboard and also check in the bios to ensure LBA is enabled and that its detecting the hard drive.
Apr 10, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Athenatech A202 (DNHA202) Logo
73 people viewed this question
Top Athenatech Computers & Internet Experts
David Payne
David Payne
Are you an Athenatech Computer and Internet Expert? Answer questions, earn points and help others
