Question about Kenmore Elite 45986 Front Load Washer
How to access filter for kenmore elite front load washer
Water slow to spin out, where and how can the filter be cleaned.
Also tub fills with water when off. I have have to shut the incoming water valve off to prevent this.
Is there a solenoid valve that controls incoming water that may be stuck open from time to time? This does not happen continually. Any help will be appreciated.
  • 5,911 Answers
To access the pump drain filter, follow the instructions in the link provided:
It is recommended by the manufacturer that if the pump still does not operate correctly after cleaning, to replace it. It does not take much to damage the motor and impeller of these small drain pumps.
The water fill problem is usually caused by a water inlet valve that is not shutting off properly. To access the fill valve solenoids follow these steps:
1. Unplug the washer.
2. Remove the top panel of the washer by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then off.
3. The inlet valve is located at the left rear of the washer (as viewed from the front). This is where the fill hoses attach.
4. A resistance reading of the valve solenoids should be between 750 and 850 ohms.
If you live in an area that has hard water, or if you use well water it is common for sediment and/or deposits to accumulate in the water inlet valve and cause problems with either filling or shutting off. you can attempt to remove the valve and clean it to see if this will correct the problem. Use white distilled vinegar to submerge the plastic portion of the valve in. DO NOT submerge the electrical contacts. Sometimes soaking in vinegar will dissolve and remove hard water deposits and sediment. If you wish to simply replace the valve, follow these steps:
1. Leave washer unplugged and remove electric connections to inlet valve.
2. Shut off water supply and remove fill hoses from the back of the washer.
3. Remove the dispenser hose from the inlet valve and remove mounting screw(s).
4. Install replacement valve in the reverse order of the steps provided.
Replacement parts can be purchased on line at,, or All three sites have great service and offer competitive pricing. I would recommend checking with all three sites for the best price. Use your model number to initiate your search.
Posted on Jan 05, 2009
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
What does F2 code mean with the Kenmore Elite HE3?
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
HE3T Kenmore Frontload Washer Random Draining Problems
The water pumped goes right back into the machine. It may be because the washer is siphoning the water from the laundry tub with a slow drain and back. Your solutions are advised but try this also:
  1. Check the pump impeller for obstruction.
  2. Cut the drain hose into the laundry tub in excess of 4 inches.
Aug 21, 2009 | Kenmore Elite 45986 Front Load Washer
Washer will not spin properly
Try this:
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
Apr 06, 2009 | Washing Machines
Not draining or spinning
probably not drain hose ..remove screws bottom cover remove clean out port on pump and clean.. after removing as much water as possible from tub
Nov 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3
ck for blockage between dispenser and where it comes into tub just above door have known dry detergent if used not disolve and cake up blocking inlet to tub also be sure drawer is clean and ck above drawer in washer and clean small holes
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
The water is not being pumped out of my kenmore front loader washeer machine
Unplug the washer from AC
Open the bottom access panel (3 screws on bottom lip)
open the large filter in center,
be ready for a lot of water, mops and rags ready. water vac is really handy .
Clean all the debris you find in the filter, reach in an spin the little propeller and make sure it spins freely.
pour in a cup of water inside the tub does it drain down freely.
reassemble and test.
front access panel has a switch so it has to be closed back.
Jan 26, 2008 | Kenmore 43142 Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Probably something caught in pump. Remove lower panel if this one has it and you will see the pump. Loosen the round cover in middle to access clean-out.
Nov 08, 2007 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
494 people viewed this question
Sal De
 Brian Main
Brian Main
