Question about Kyocera Mita Km-5530 Km5530 Copier Interface Bd 2bc2801
Km-5530 - code c3300 - Kyocera Mita Km-5530 Km5530 Copier Interface Bd 2bc2801
My kyocera km 6030 is showing an error C3300. Kindly tell me its solution
clean the opticals, the mirrors and the lamp. seems there is alot of dust on them.
May 16, 2014 | Kyocera Km-6030 With Feed, Finisher, Bank,...
C3300 code
I am living in a Pakistan Village and have cyocera K-6030. I am facing an error on control pannel C3300, I would be most grateful, if I may be informed only that in which part of the machine this fault of C3300 is? it solution please. Thanks with regards. my e mail no is gmtyping@gmail.com and gmtyping@yahoo.com. If some one here can show me its solution, because my e mail is also not opening. thanks. my name is ghulam muuhammad
Mar 08, 2014 | Kyocera Km-6030 With Feed, Finisher, Bank,...
My printer does not work it shows error code c3300
Go the Kyocera web site and search for the error code. Also, you may need to enter your model. Good luck.
Oct 05, 2013 | Kyocera Km-6030 With Feed, Finisher, Bank,...
How can i clear an error c3300?
Hi anonymous, Firstly read your user manual. Secondly search online for "error code c3300 kyocera km5050". I did and therefore can't see any reason to spoonfeed any further.
Aug 25, 2012 | Kyocera KM 5050 Toner Cartridge 34000...
Hi sir ....... when the copier ( kyocerammita 5530
Optical system (AGC) problem
1. insufficient exposure lamp luminosity
2. defective engine pcb
3 incorrect shading position
4. defective CCD unit
check exposure lamp harness connections; adjust position of contact glass shading plate or clean/replace the scanner home position sensor; replace the exposure lamp or inverter pcb if needed; replace CCD unit or engine/main board if applicable
Jan 10, 2010 | Office Equipment & Supplies
I need to reset ID Code on Kyocera Mita KM-5530
The solution is easy! Push the Default Setting/Counter button on the top right side of the keyboard. Press the the Managment icon on the diplay. Enter 6-4-8-2 on the keyboard and select the Managment icon in the OFF position. Close all windows on the display and you should be ready to go.
Jun 17, 2009 | Kyocera Mita KM-4035 Printer
Error code c3300 on km-5050
Hello sir; That's exposure lamp or main board problem, my suggestion; check the exposure lamp.
Apr 03, 2009 | Kyocera Mita Office Equipment & Supplies
Kyocera Mita Km-5530 Km5530 Copier Interface Bd 2bc2801 Logo
57 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
