Question about AEG D5701-4 Electric Double Oven
Relay board Need wiring diagram
My oven keeps giving the f10 code even though I have replaced the temp sensor and the oven relay panel. What's the next step? It's an electrolux #ew30es6cgw2. Tia
F10 - Runaway temperature. If these error codes shown while the oven is in day time mode, the EOC (electronic oven control) would need to be replaced. Otherwise check the oven temperature sensor (RTD sensor) as described earlier and replace if necessary.
Most of the EOCs incorporated power relays among all other components while some of ovens use a separate power relay board to simplify design and lower cost of production. You can determine it by visual EOC inspection and/or by the wiring diagram for your oven (if it is available). If there are some relays on it, replace the EOC. If there are no relays on the EOC, check the parts list (Search by the Model number) for the relay or power board. If there is a such part, replace it. I'll be glad to help you if any problems with the diagnostic. Just leave a comment on the bottom of the page. In such situation I'll need the complete model number of the oven.
Mar 03, 2017 | Electrolux Ovens
Ned's to know witch relay to replace wich f8 problem
Hi there! Typically for such an error code, F8 or F80, there is a communication error between the UI (User Interface) and the control board (often the microwave control board). Yes you have a microwave control board in a double wall oven. This will require either the main control board or the UI board being replaced by a professional for safety reasons. I would suggest to contact a professional that partners with your manufacturer. Contact your manufacturer first to see if there are any known issues or a limited warranty for your model.
Mar 30, 2013 | Frigidaire 30 in. Electric Gallery Series...
Bake element will not shut off at set temp.
You need to check the oven cycle relay,
  1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. In order to gain access to the oven cycling relay, refer to your owner's manual. Removing the back panel of the range accesses most relays, but some ranges locate the relay under the oven compartment where the utility drawer is usually located.
  3. Now you can test the relay using your VOM. First, label each wire attached to the relay and remove them from the relay terminals. Using your VOM's ohmmeter function, set the range to R x 1 and touch one test lead to the terminal marked L and the other test lead to terminal H2. There should be NO continuity. Next, test the terminals marked H1 and H2. Again, there should be NO continuity. Finally, test the S and R terminals. Continuity should exist between these two terminals. If your relay does not pass all these tests, it is defective and should be replaced.
  4. To remove the relay, undo the two screws securing it to the range and replace with the correct new relay. Refer to your wiring diagram and labeled wires to ensure that the wires are on the correct terminals. Now replace the back panel or drawer and test the oven.
Then you check the oven thermostat: When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
Hope this information helped you.
Jan 14, 2011 | Whirlpool RBS275PD Electric Single Oven
I need wiring diagram for relay circuit board kenmore drop in stove model # 911-4558818
hello. go to searspartsdirect.com
enter the model number and you will get an entire set of schematics to review for free. Joe
Oct 12, 2010 | Ovens
I had an F1 Code on my Jenn Air WW2780B Double Wall Oven, and turned both ovens on to heat up, which they did, and the F1 code never came back after that... so far. Could it be fixed?
Hi, This code is an indication of a fault that exist within the actual relay board. It is malfunctioning at this time, and should be replaced asap, if possible.This relay board is located inside the unit, mounted on the cooling fan shroud. Once replaced, the F1 code will be cleared automatically.
Relay board part number: Y04100261
Click here to view an exploded diagram of the cooling fan shroud, with relay board attached. The relay board is labeled number 9, and the shroud is labeled number 1
Oct 27, 2009 | Ovens
I need a wiring diagram for the circuit board to a Whirlpool RM770PXBQ2 wall oven. Can you help?
loks like to be a an older, micro/oven combo unit. too old to even have a tech sheet available any more,althought i can lookup the techsheet its nothing more than a wire diagram for the unit and a quick troubleshooter, no real breakdown for diagnosing hte circut board itself, hers alink to what i found good luck. there may be a copy of this within the control cavity as well
http://www.servicematters.com/docs/wiring/wiring_main.htm
Dec 16, 2008 | Ovens
Digital screen goes off oven will not work stove top is working fine
The "digital screen" is connected to the electronic control board which controls the oven (the surface elements on the stove top will not be affected by this problem). The "flickering on and off" could be any connection that feeds the electrical supply of the control board. Like something in the wiring harness that feeds the relay board, or the wiring harness that goes from the relay board to the electronic control board. It could also be the relay board or the electronic control board themselves. To isolate the problem you would need to check electrical supply to each board at the time of the "problem" when the "digital screen goes completely off." This would tell you where you "have" the voltage and where the voltage supply is lost. If it is a loose or burned wiring harness replace the harness or individual wire causing the problem if it turns out that it is the relay control board or electronic control board replace them. The relay control boards are typically around $75.00 and the electronic control board $150.00 and up. Might be cheaper to purchase another used oven or bite the bullet and buy a new range.
Nov 29, 2007 | GE Profile JTP18 Electric Single Oven
Oven timer and temperature display dim
You need a new display/relay board package they have come up with to solve this problem. The parts generally run about $250, and if you have it repalced by a service company, the total will be a little less than $500. The display is really easy to change by itself, but you must change the realy board with it, and it has about 40 different wires going to it. If you draw a diagram as you take the wires off, and label them carefully, it isn't that hard to do the whole job..just take your time. This is a problem thermadore/dacor ovens have had for some time. If it isn't too old you may try calling thermadore and see if they are willing to at least buy you the parts, as this is a known problem. Good Luck!
Nov 23, 2006 | Thermador SMW272 Electric Double Oven
AEG D5701-4 Electric Double Oven Logo
42 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
