Question about Packard Bell iMedia Computers & Internet
When i use the recovery disks or the internal recovery process the computer takes on the data then restarts after about 50 minutes then freezes or goes to th blue screen of death which caused me to start the recovery process, can i wanted to reformatt my hard drive to delete all files and then use the recovery disks to reboot. the computer does not allow me to reformatt from BIOS and as a reslut i seem to be in limbo grateful for any advice p.s i only have the recovery disks not a windows os disk & using vista regards
  • Packard Bell Master
  • 27,725 Answers
BSOD Bluescreen of death can be caused by a number of things
A bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to fail
make sure all leads have a dust free secure connections
A bad driver loose or faulty lead or not having enough ram
you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to
compatible ram also you will have an option to scan your system
you should always ask the seller if they guarantee the compatability of the ram before making any purchase
if you dont want to install more ram uninstall some unnecessary programs
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
if you can get a screen
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
hope it helps
Posted on Nov 06, 2012
  • 21 Answers
SOURCE: NTLDR is compressed
Try this:
Insert the Windows CD (the oryginal one) into the CDrom drive, and restart tyour PC. When the compter bootsagain select an option that are required to start the computer from the CD if you are asked to do so. When the "Welcome to Setup" screen appears, press R to start the Recovery Console. When prompted type "1" or if you have a multiple-boot computer, select the installation that you must access from the Recovery Console. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER. Now you should be at the comman prompt and ready to repair the ntldr file. Now all you need to do is enter the following commands (in order) and each command on a new line just like you see them here:
cd \
attrib -c ntldr
exit
The PC should reboot now and everything should work just fine.
Posted on Oct 23, 2007
tom19511
  • 1601 Answers
SOURCE: Computer Keeps restarting
start in safe mode, and uninstall
Posted on Jan 06, 2008
LMITC
SOURCE: Blue Screen c000021a
boot system into safe mode. locate the icon for my computer. right click and go to properties. locate the computer name tab and select it. find the radio button for "change" and click it. rename the computer to something considerably shorter then what you have. the system cannot boot and complete the logon process if the computer name is longer than 200 "bytes"
Posted on May 27, 2009
DosHog
  • 168 Answers
SOURCE: Lenovo 3000n100 goes to rescue and recovery 4 on start up
If the drive was bad, it SHOULD give an error message to that fact. You have 2 doing the same thing. I do NOT believe in coincidence. I would first try a new hard drive. If that works, you have to determine the value of the data on the old drive(s). A data recovery service may be your only refuge, albeit, expensive.
If a new drive does not work, I would contact Lenovo. If you have 2 out of 2 bad, unless you use your laptop as a car jack to change tires, they must have seen this problem before. They may even offer to repair at no charge even though the systems are out of warranty.
I hope that helps.
Posted on Aug 01, 2009
herbalgarden
  • 344 Answers
SOURCE: Windows doesn't recognize recovery partition after os reinstall
The issue you are having involves using multiple systems,...If your emachine came with vistan and you installed xp, you voided your warranty status...However remove your dual boot and stick to vista if you wanna keep your restore partition working properly.....On a side note theres usually conflict with running OEM OS's on dual boot...typically it doesnt work and if it does it doesnt work like you want it to! so here is what you can do..Call Emachine up and fib to them a bit (just alittle) tell them that you cought a nasty bug and it messed with your restore partition and now you cant restore your pc....request the factory programing discs (if you ask nicely they'll hook you up 99.99% of the time) you get the discs so you can reprogram the pc to factory spec if you ever wanted to. Now use a retail version of vista and a retail version of xp. and create your dual boot, feel free to remove your restore partition if you want (cause you have the factory programing discs if you wanna go back to stock stuff YAY) I hope this helps!
Posted on Sep 27, 2009
Testimonial: "Highly knowledgeable and an awesome guy for taking his time to share his expertise with the pc community. Thanks again!!!"
How do I fix currupt data
I believe you mean "corrupt data". When we have message corrupt data means that something wrongs with hard disk. You can try correct problem running full disk check.
Check your hard disk for errors
You can help solve some computer problems and improve the performance of your computer by verifying that your hard disk has no errors .
Open Computer by clicking the button " Start " and then click Computer.
Right-click the hard drive you want to check, and then click Properties.
Click the Tools tab , and then , under Error-checking , click Check . Administrator permission required If you are prompted for an administrator password or confirmation , type the password or provide confirmation .
To automatically fix problems with files and folders that the scan detects , select Automatically fix file system errors . Otherwise , the disk check will report problems but not solve .
To run a full disk check , select Scan for and attempt recovery of bad sectors . This scan attempts to find and repair physical errors on the same hard disk and may need more time to complete .
To check for errors in both files and for physical errors , select both check boxes AutoCorrect file system errors and Scan for and attempt recovery of bad sectors .
Click the Start button .
Depending on the size of your hard disk , this process may take several minutes . For best results, do not use your computer for other tasks while it lasts error checking .
note
If you select the Automatically fix file system errors for a disk that currently in use (for example , the partition that contains Windows), you will be prompted to reschedule the disk check for the next time you restart your computer your .
Jan 29, 2014 | Toshiba Computers & Internet
Tip
Hard Disk Data Recovery
Definition of Hard Disk: Hard Drive is a storage device where you can store any types of data and file. Hard Drive is available as external and internal device. We know PC storage device as internal system Hard Disk. When you save data or install programs on your computer, the information is typically written to your Hard Disk. The Hard Disk is a spindle of magnetic disks, called platters, that record and store information. There are several interface standards for passing data between a Hard Disk and a computer. The most common are IDE and SCSI. Hard Disk is made of one or more aluminium or glass platters, coated with a ferromagnetic material. Most Hard Disks are found as Parallel ATA (PATA), Serial ATA (SATA) or SCSI device.
Difference with Floppy Drive:
The term hard is used to distinguish it from a soft, or floppy, disk. Hard Disks hold more data and also faster than floppy disks. As an example a Hard Disk can store anywhere from 10 to more than 100 gigabytes, where most floppies have a maximum storage capacity of 1.4 megabytes. Floppy is more risky device than Hard Disk for losing data.
Problem with Hard Disk:
Most common problems of Hard Disk which may arise anytime are Booting problem, OS Installation problem, Hard drive crashing and another Hard Disk not showing original space or not showing partition etc. But in every case the risk is loss of data. In some of cases formatting and reloading of Operating System can recover your Hard drive and make it useful but formatting can recover a blank Hard Disk only without data. But you have to recover Hard Disk with data, so formatting is not possible.
Data Recovery:
Data recovery is the process of retrieving back data from the damaged media. The damage of storage media can be physical damage and logical damage. The data is retrieved back by recovery experts after determining the type of the damage caused to the storage media. Most of cases data recovery is important and formatting is not possible there. So that I need to choose another way for solution of this type of problems of Hard Disk. The first and secure way to recover a Hard Disk is using data recovery software.
Recover Data from crashed Hard Disk: Power surges, Software Corruption or Malfunction, Hardware or system failure, Natural calamities, User errors may crash your Hard Drive. Data recovery software helps to retrieve or recover the data from the crashed hard Drive. Data recovery software gives an easy and Graphical User Interface with less difficulty so that the data can be recovered easily. The recovery software helps to recover the data and restore them on a second Hard Disk, the Hard Disk being connected to the computer and recognized by the BIOS, the recovered data can be stored on a safe location on the second disk.
Logical data recovery: In a data loss situation when the Hard Drive is perfectly fine and the BIOS recognizes the Hard Drive but reports a read error, logical data recovery technique is very helpful. Here the files that are damaged or corrupted by any user error or virus attack are rebuilt rather than repairing the Hard Drive.
Fragmentation: When the FAT entry is lost during accidental file deletion, formatting or partition deletion that particular block of Hard Drive becomes inaccessible. Some data recovery software makes an attempt to rebuild the files without a FAT entry. This technique is very efficient if the file size is smaller than the clusters size. But it is inefficient in recovery the larger files.
Data Recovery from deleted partition: Partition is allocation of memory in different sections. Each partition will be like separate disk drives. Partition is very use full when the user is using operating systems more than one. Usually after formatting the disk it may not be able to recognize a partition because of accidental deletion of the partition table or by virus infection. The partition is not actually deleted; it can be recovered by using recovery tools and copy the data present in the partition to the required destination. Formatting the drive erases a large amount of data present on it, but not all the data. The recovery of the data depends on the fragmentation of the file system as the parts of files are being placed on different places in the drive. The data recovery software will assume that files were not fragmented and stored in continuous clusters. If the partition was formatted using different file system, then recovery process will be very complicated.
Another Data recovery process: If you don't have any data recovery software you can try another process to recover data. Attach the Hard Drive with another system in slave or second SATA.If detect the drive then boot to the first Hard Drive and use the bad Hard Drive as secondary. Then you can copy the data from the second drive to first drive easily. Here have another process to recover data from a crashed Hard Disk. But it is so risky, and should not try to do this for an inexpert person. First pack the Hard Disk in a bag properly where moisture can't attack. Now freeze it upto get chill. After freezing quickly attach with a system in secondary, and copy the data within the Drive will come in room temperature.
So the most secure process to recover data from a Hard Disk is to use data recovery software. It is available in market.
on Mar 18, 2011 | Computers & Internet
Restore factory settings
Many Toshiba laptops come with the factory software recovery image stored in a special (hidden) area on the hard disk. From this special hidden system recovery image, you can restore your computer to its factory-fresh software condition by following these steps:
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. Press and hold down the 0 (zero) key on the keyboard while powering on the computer. Release it when the recovery warning screen appears.
  5. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. A warning screen appears, stating that when the recovery is executed all data will be deleted and rewritten.
  7. Click Yes to continue.
  8. When the Toshiba Recovery Wizard opens select "Recovery of Factory Software" or the appropriate option for your needs.
  9. Continue to follow the directions restarting as necessary.
For laptops equipped with Windows 8, "Reset" returns your computer to its out-of-box, factory default conditions (removes your personal files and apps as well reset all settings to defaults) similar to a "System Recovery."
Please note that the process may vary slightly from machine to machine, that you may be asked to insert disks (multi-disk packages) and that the process may take one to two hours to complete. The recovery process will restart your computer several times.
As you use the recovery process you will have several options. One of these may be to create a custom size partition. Follow the directions on screen for this and other options as prompted. When in doubt, it's usually best to accept the default, or pre-selected option.
Nov 30, 2013 | Toshiba Satellite A45-S150 Notebook
Toshiba qosmo g10
Information:
Please note that the process may vary slightly from machine to machine, that you may be asked to insert disks (multi-disk packages) and that the process may take one to two hours to complete. The recovery process will require you to restart your computer several times.
Aug 27, 2012 | Toshiba Computers & Internet
How to format my hard drive in dos
Rita,
Most computer recovery disks will perform the formatting for you. (This depends on the Manufacturer and Model though...)
If you put the recovery disk into the computer CD/DVD Drive and restart the computer - to boot to the disk, it should launch the recovery process and warn you that the hard drive will be erased and all data will be lost. This warning step is the recovery disks way of informing you that it will format the drive.
To boot to the CD/DVD you will need to tell the computer to do that. When the computer first turns on, you should see a brief message at the very beginning of the boot up process. The message will say something like: "Press Del for Boot Device" or "Press F12 for Boot Menu" or something of this sort. If your recovery disk is in the drive and you can get to the boot menu by pressing the key the computer prompts you to press, then you should be able to start up with that recovery disk.
Allowing the recovery disk to run through it's full process should format the hard drive and set your computer straight.
Make sure to run all of your updates once the recovery is complete and also make sure to install and update a good anti-virus software of some sort.
Nov 19, 2011 | Computers & Internet
One day my acer laptop aspire 5742z came up with disk read error please restart... I didn't have a disk in the drive but I restarted it anyway ... It kept coming back to that same screen. I restarted...
Hi koga9783...
How to reinstall the Operating system on your computer
Select models of Acer laptops, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Note: During the process, all data stored on your computer will be overwritten. This means all your files, such as email and photos, will be erased. Therefore, we recommend making a backup of all personal data before starting the recovery process.
To start the system recovery:
1.Restart the computer.
2.When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
3.If you are prompted with a Microsoft Windows boot screen, press the Enter key.
4.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
2.When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
3.Press the CD-ROM drive eject button and insert the disc labeled System CD.
4.Close the CD-ROM tray.
5.Refer to on screen instructions to select either CDROM or USB CDROM.
6.The computer will boot from the Acer Recovery Media
7.When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
8.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Please take time to rate me
Sep 21, 2011 | Computers & Internet
My acer laptop aspire 5742z came up with error reading disk error when I had no disk then I restarted it and it went to the acer start up window then 5 seconds later it turned off then on and it follows in...
Hi koga9783...
Try this solution to your problem.
Select models, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Sep 21, 2011 | Acer Computers & Internet
How can i master reset my net book
Once Hard Disk Recovery is enabled, restart the system and hit ALT+F10. This will begin the Aspire system recovery process. You will be prompted to type six zeros as a security step. Type 000000 to proceed.
You will then see a screen to select your Operating System. Do this and hit enter and the recovery process will begin.
The process for restoring from the second partition is similar with all major brand names. The most important thing to remember is to always have backups of your data and take a few minutes to burn recovery DVDs using Acer's built in utility.
Thank you for visiting FixYa! Have a good one!
May 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
I want to wipe my computer and take everything back to factory settings with only the programs that wcomes with windows. My computer is a little older but I have a dell and it has windows xp profesional on...
1 Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
2 Immediately upon seeing the blue bar, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish starting, and then restart the
computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
3 On the next screen that appears, click Restore.
4 On the next screen, click Confirm.
The restore process takes approximately 6–10 minutes to complete.
5 When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
6 When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the screens that
appear, such as the End User License Agreement, are the same ones that appeared the first time the
computer was turned on.
7 Click Next.
The System Restore screen appears and the computer restarts.
8 After the computer restarts, click OK.
Jan 31, 2010 | Dell Dimension 4700 PC Desktop
Used the restore disk after a system crash, now when I power on the system takes 25 to 30min, to boot. after aprox. 15min use, the system freezes up and I have to do a manual shutdown. So what did I do...
Not sure of the toshiba recovery process but does it partition and format the drive? (I would assume that it does).
Why did you have to do a recovery? Was the notebook slow then? Does Toshiba have a hdd utility to check the drive? Utility to check the other hardware?
Perhaps the drivers have to be updated since the recovery disk was created.
Hope this helps.
Nov 09, 2009 | Toshiba Satellite M35X-S149 Notebook
Computers & Internet Logo
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tony
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
