Question about Mitsubishi Outlander 08 2008
The car is 2008 mitsubishi forweel and on dashin board there is ABS always switch on and it take more petrol .
    Master:
  • 689 Answers
If it is on there is a problem in the brake system, That will have to be check out,No bones about it, Before you have no brakes at all,
Posted on Nov 09, 2012
How do I get the ABS/VDC/AWD lights off on my 2008 Nissan Rouge not that I have replaced my left ABS Wheel speed sensor?
try this --when you start the car fist keep your foot on the brake pedal keep it on then turn the key on --if no warning lights its your brake light switch
Dec 20, 2016 | 2008 Nissan Rogue
Brakes jumps when trying to stop
your truck has ABS brake system and it will work like that
Dec 14, 2016 | Mitsubishi Cars & Trucks
Is a 2008 Mitsubishi outlander 2.4 mivec petrol engine interference or non interference
Please could you be more specific about your engine and with what is it supposed to make (or not to make) interference? Or what is making interference or non-interference with the engine
Sep 27, 2015 | Mitsubishi Outlander 08 2008
Is the transfer case for a 2008 NS Mitsubishi Pajero Auto Petrol (3.8L) same as 2008 Diesel?
I have since discovered that the answer is 'NO'. The part numbers are different - Petrol is MI-3242A055 and Diesel is MI-3242A035. My problem was that The Gearbox Shop at Slacks Creek fitted a diesel version (3.2L V4) in my petrol (3.8L V6) vehicle after a centre diff 'flashing light' problem (contact me if you have that problem). While the final gear ratio is different, the sensor rotor on the rear output shaft is also different - resulting in the speedometer reading between 17.6% and 21.9% above the actual speed as read by my GPS.
I would be interested to know if there are ant other performance differences between the two cases.
Aug 09, 2015 | Mitsubishi Cars & Trucks
Mitsubishi 2008 did not work and get ABS light
Check the fuses and connections on brakes for abs.
My answers are short and sweet. Common sense mostly. If you are trying to get something for nothing...Don't waste my time! Remember if something sounds to good to be true that it usually is. I've spent many years of my life trying to cheat the system and was pretty good at it. This all changed when I discovered that people were doing the same thing to me. What comes around, goes around. Karma! Now I assist people in making win-win deals...that are legit!
Dec 31, 2014 | 2008 Mitsubishi Pajero 3.2
Could it be the booster
check your push rod going from the pedal to the booster a quick way is to pull the vaccum hose and see if they release the vaccum not being released can cause sticky problems also check your vaccum hose also
May 26, 2014 | 2008 Mitsubishi Lancer GTS CVT Sedan
Abs light stays on
I would check all 4 wheels to make sure the abs wires are making good connection to the sensor
Apr 07, 2014 | 1998 Mitsubishi Montero Sport
Mitsubishi montero limited and the ABS light and brake light is on and has a buzzer/alarm on always. To brake the car you really have to press hard on the brakes. Please what are the possible solutions.
Immediately check your brake fluid level. If its low, you may have a leak within the brake system. This also allows air to enter the brake lines causing insufficient braking power. If levels are ok, have the ABS actuator checked for proper function. Have it diagnosed immediately, as this may cause a major accident.
May 23, 2011 | Mitsubishi Montero Cars & Trucks
Diff lock and abs lights
Check to see if the plugs on the wheels are plugged in check that the pins are all the way into socket, that your ABS problem, next check to see if you knocked loose the wire on the differential most likely cause and be sure to top off power steering fluid. Check that the fluid level is ok on the Diff. if you need more help let me know and thanks for using Fix-ya and rate if this was helpful.
Avid101
Aug 21, 2009 | Mitsubishi Passenger Cars & Trucks
Mitsubishi Outlander 08 2008 Logo
Top Mitsubishi Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Mister Danger
Are you a Mitsubishi Car Audio and Video Expert? Answer questions, earn points and help others
