Red qoutation light keeps blinking/a440 print dock
Incorrect or missing print cartridge /red qoutation light keeps blinking/a440 printing dock
  • Anonymous Mar 29, 2009
    i have the same problem, and am NOT using a pc connected to it. One solution is to clean the metal contacts on the cartridge with DISTILLED water using a q-tip. I haven't tried it yet though.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
HP Photosmart A440 Printer showing Incorrect or missing print cartridge flashing up even though print cartridge is installed
Try carefully clean the contacts in the printer. I would use cotton sticks with a little Isopropanol.
Sep 26, 2017 | HP Office Equipment & Supplies
Red light blinking
The Attention light is flashing red.
Solution The printer requires attention. Try the following:
* If the printer is connected to a computer, check the computer screen for
instructions.
* If you are printing a CD label on a CD/DVD, insert the CD/DVD holder in the
CD/DVD tray now.
* If you have a digital camera connected to the printer, check the camera screen
for instructions.
* If the printer is not connected to a computer, check for the following problems:
- Main cover open - Out of paper - Paper jam - Print carriage jammed or stuck - Print cartridge missing or inserted incorrectly - Print cartridge tape not removed - Incorrect print cartridge installed - Packaging materials are not removed * If you are unable to solve the problem by using the instructions above, turn off
the printer and unplug the printer power cord. Wait 10 seconds, and then plug
it in again. Turn on the printer.
Feb 18, 2014 | HP Photosmart D5160 InkJet Printer
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
Aug 01, 2011 | HP LaserJet 1020 Printer
Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
  • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
  • The protective tape is not removed from a new cartridge.
  • Contacts on the cartridge are not making proper contact with the print carriage.
  • The cartridge is remanufactured or refilled.
  • The cartridge is defective.
Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
All photos coming off with red tinge photosmart a440
Hi friend,
Your photosmart color combination is not working properly you should check the color ink ..which is u are useing....you should use HP product for better printing..
Jan 01, 2010 | HP Photosmart A444 Camera and Printer Dock...
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Feb 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Red light ink cartridge keeps on blinking
what does it say next to the blinking light for example check paper, check ink cartridge, etc.?
tom
Dec 20, 2008 | HP PSC 1350 All-In-One Thermal Printer
DELL AIO 922- All in one- Printer won't print
Remove the right ink cartridge (color). You will get an error saying the cartridge is empty, but ignore that. Hit cancel on your printer. Print your job...when your print screen comes up, under preferences check the box for print colors in black and white. Your printer should print just fine without the color cartridge. Ignore the flashing red light.
Sep 06, 2007 | Dell 922 All-In-One InkJet Printer
225 people viewed this question
jasbo
jasbo
