Question about Casio FX82MS Scientific Calculator
How to solve simultaneous equations? - Casio FX82MS Scientific Calculator
  • Casio Master
  • 7,993 Answers
This calculator does not have a utility that solves equations of any type.
Posted on Sep 30, 2013
How can i write this in my calculator example. 2x=10 the answer is x=5 but how can i put x in the calculator
What you want to do is solve the linear equation 2x=10 to find the value of the unknown x that makes the equality true. Solving an equation usually involves rearranging therms, factors and so on. However your calculator was not designed to handle the solution of equations, no matter how simple they are.
Some Casio scientific calculators can solve some types of equations (polynomials of degree 2 or 3, simultaneous linear equations in up to 3 unknowns). These are the FX-115 ES (Plus) and FX-991 ES (Plus C). Other equivalent models are sold in the world under different names.
Oct 16, 2013 | Casio FX350MS Scientific Calculator
Hello How to solve complex equations using casio fx 9860G AU For example (2+i)A+B=6 2A+(1+i)B=1 How to solve A and B using this calculator
The simultaneous equation solver requires the coefficients to be real. Similarly matrices must have real coefficients.
Your only alternative is to express each of A and B as a real part and imaginary part.
A= x1+iy1
B=x2+iy2.
Substitute x1+iy1 for A in the two equations. Substitute x2+iy2 for B in the two equations. Do the algebra. Gather real parts and gather imaginary parts. Split each original equation into two equations: One equation comes from setting Real Part of left side = real part of right side (1); the other equations comes from setting the imaginary part of left side= imaginary part of right side (here 0).
Do the same procedure for the 2nd original equation.
At the end of the process you will have 4 coupled linear equations in the 4 unknowns (x1,y1,x2,y2).
Then you might want to use the calculator to solve the derived system. Once you have x1,y1,x2,y2 you reconstruct A=x1+iy1, etc.
Aug 29, 2011 | Casio FX-9860G Graphic Calculator
I am doing a java application to structural analysis.it involves the solution of system of linear simultaneous equations.may yuo pliz assist me with a java code to solve the equations.its urgent .pliz...
The absolutely-best, most-robust, software for solving systems of linear equations is the LINPACK software library.
It was originally written in FORTRAN.
But, see: http://www.greenecomputing.com/apps/linpack/
which indicates that a JAVA version exists.
Mar 02, 2011 | Computers & Internet
Multiple equation solver
There are a few routines to solve simultaneous LINEAR equations that are embedded in the Operating system of the calculator.
  1. solve(
  2. Simult(
However if you are looking for the simultaneous equation solver application, you can download it from the TI website. Here is the link
If you need download and install instructions, you will find them here.
Aug 01, 2010 | Texas Instruments TI-89 Calculator
How do you do algebraic equations and inequalities on this calculator? The keys and the instructions are too small to read.
You can use symbols (X,Y,A,B,C,D, and M, =) to create expressions to use in the SOLV program or to generate a table of values.
To type them you use [ALPHA] followed by the symbol you want. The symbols on the body of the calculator are of the same color as the ALPHA key. The [=] in expressions is different from the general = sign at the bottom of the keypad.
There are also some typical equations already in the calculator: simultaneous linear equation in 2 or 3 unknowns, and polynomial equations of 2nd and 3rd degree. They are accessed under the EQUATion Mode.
Jun 21, 2010 | Casio FX-115ES Scientific Calculator
Will the ti83 work simultaneous equation?
Yes. Since there's far too much material for a single post, please refer to the chapter "Matrices" in the Guidebook. If you've misplaced your guidebook, you can download a new one from http://education.ti.com
Apr 28, 2010 | Texas Instruments TI-83 Plus Calculator
Solving simultaneous equation with scientific
Let us assume you have two simultaneous linear equations :
a_1*x+ b_1*y+c_1=0
a_2*x +b_2*y+c_2=0
where a_1, a_2, b_1, b_2, c_1,c_2 are coefficients (numerical or algebraic).
The problem is to obtain the particular values of the unknowns x and y for which the two equations are both satisfied: If you substitute the particular values of x and y you find in any of the two equations you discover that both equalities are true.
A small system of equations like the one above can be solved by some very simple algorithms (elimination, substitution, combination) which can be carried out by hand.
The solution of large systems of linear equations can be sought by making use of the concepts of matrices (plural of matrix), determinants, and certain rules called Cramer's rules.
Due to its repetitive nature, the algorithm ( a well defined, limited sequence of steps) is suitable for a calculating machine (computer or calculator).
Certain calculators have, embedded in their ROM, a program that solves linear systems of simultaneous equations. Usually you are asked to enter the values of the coefficients a_1, etc. in a set order, then you press ENTER or EXE (Casio) . If a solution exits (not all linear systems have solutions) the calculator displays it.
Hope that satisfies your curiosity.
Aug 12, 2009 | Sharp EL-531VB Calculator
Using the ti89 to solve mesh equations
This book is what I used to help learn how to solve mesh circuits. A high education level helps. You just set it up as you see it in a simultaneous equation.
Electrical Engineering Applications with the TI-89
Electrical Engineering students will find the 70 topics covered in this book provide in-depth analyses of how to solve many common engineering problems using the powerful CAS system of the TI-89.
Author(s) - David R. Voltmer and Mark A. Yoder
raklein62@yahoo.com
Mar 23, 2009 | Texas Instruments TI-89 Calculator
IF I HAVE TWO equations 5x+8y=54, AND -9x+y=26 how do i solve
use the simultaneous equation solver software available on ur ti-89 and enter the equation in the form of augmented matrix and you will get ur answer.
Dec 03, 2008 | Texas Instruments TI-89 Calculator
I did no understand simultaneous equations
Here is a site dedicated to teaching simultaneous equations. Hopefully that'll help.
http://www.themathpage.com/alg/simultaneous-equations.htm
-John
Aug 31, 2007 | Sony Playstation 3 (PS3) Console
Casio FX82MS Scientific Calculator Logo
95 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
