Question about GE Refrigerators
My compressor is getrting real hot, the realy is also bad, i managed to make the fridge to work the fans worked the compressor was making noise again like a buzzing sound that it normally makes. but t
I TRIED TO FIX THE FRIDGE AND WHAT HAPPENED WAS MY COMPRESSOR STARTED WORKING AGAIN SO I THOUGHT, NO COLD AIR WAS BEING MADE. BUT THE COMPRESSOR WAS MAKING NOISE SO I THOUGHT I FIXED IT. THE NEXT MORNING I WOKE TO FEL THE COMPRESSOR AND IT AS VERY HOT TO TOUCH, AND STILL NO COLD AIR, I NOW KNOW THE RELAY SWITCH IS BAD IT RATTLES. AND SPARKS. I TOOK IT OUT AND ORDERED ANOTHER ONE, MY QUESTION IS ABOUT THE COMPRESSOR, BECAUSE IT GOT SO HOT IS IT ALSO SHOT?
  • 29 more comments
  • Fredric Flinstone aka scott cassell
    WOW SORRY FOR THE MISSPELLING LOL.
    OK ONCE AGAIN, I PLAYED WITH THE RELAY SWITCH LAST NIGHT THE COMPRESSOR WOULD NOT COME ON. SUDDENLY IT DID SO I LEFT IT ALONE. NEXT MORNING I WENT TO SEE IF IT WAS WORKING, AND IT WAS NOT ONLY A HOT COMPRESSOR AND NO COLD AIR. NEXT I REMOVED THE RELAY SWITCH AND SHOOK IT AND YES IT MADE RATTLE SOUNDS, MY ONLY QUESTION IS NOW THAT THE COMPRESSOR GOT SO HOT HAVE I DESTROYED THAT TO?
    can i bypass the relay till i can get one? i got one today from ebay but it to was a bad relay it turned red and burnt up, i shook it when i opened the package and yes it rattled so i knew it was bad, i installed it anyways and the compressor kicked on for few seconds and then clicked off, the relay was red, hot! i wonder can i bypass this relay till i can offord another one,?
  • Richard Roth
    Richard Roth Nov 08, 2012
    No! Do not bypass it! If there should happen to be a problem with the compressor, you burn the unit up or even worse, the house!
    thank you Richard Roth i just thought i could bypass it for a while. this is really sad, i lost all my food because of the storm and now i bought a relay from ebay and it did not work. i now gotta send it back, while the cost was 42 bucks, and said to work. i installed it and it turned red hot. and the coils also turned red then shared black. now i gotta pay shipping to send it back. what a bad month this has been but thanks man,
  • Richard Roth
    I feel bad for you. I let you in on a secret that will fix the refrigerator for about 1/4 of the cost of the replacement relay. Take a look at this 3 in 1 relay.http://www.repairclinic.com/PartDetail/H... This is what i use all the time for the refrigerators. It will never burn out and will reset itself. It will replace the start relay, run capicator and over load relay. (3 in 1) and it is only like $16.00! You can find them at alot of shops if you call around. I would never pay the $40.00 - $50.00 for 1 relay while this is on the market. Get one of those instead of the start relay. You won't be disappointed!
    wow richard, i had no idea and thanks, i would have done that, but i did call around and nobody said this, and everyone said i had to replace that relay as well as saying they have discontinued it, so what your saying is i can completely remove that relay and use a 3 in one part? i am so upset that i did not investigate more before getting ripped off and i thank you so very much i am absolutly sure this will solve the issue.,but now i have to wait until i get paid again to order this 3 in one part you showed me, again i thank you so very much i am very greatful to you for showing me this, is this 3 in one part hard to wire up? or does it simply go on those 3 prongs that the old relay was on? well im uploading a pic to you to show you what i payed 42 bucks for its a complete joke. , WOW RICHARD THANKS..
    this is what i payed for. a broken relay,
  • Richard Roth
    That is a sad looking relay. Did you use PayPal when you ordered it? If so, you can file a grievance with them and get your money back. When you file a grievance, the seller cannot except any more PayPal transactions until it is cleared up. Let me find some installation instructions that are easy understand and I will post them back to you.
  • Richard Roth
    OK, here is the brand I use. This is for a 1/2 horsepower so it should work well for you and the cost is $14.25 plus the shipping of $11.14 so the total would be $25.39. You might want to call around your area to see if it is available locally to you. The next post is a video that shows you how to install it.
  • Richard Roth
    http://www.youtube.com/watch?v=3MYNecMts...
  • Richard Roth
    Grasp the 3 'n 1 relay box, and locate the five wires protruding from it. There are three color-coded wire plugs (red/positive, black/negative and blue/neutral) to match the terminals on the compressor, as well as two wires (red/positive, black/negative) that match the two wires protruding from the compressor.
  • Richard Roth
    Strip back the insulation 1/2 inch on the red and black wires protruding from the relay box, using wire strippers. Match the red wire on the relay to the red wire on the compressor, and the black wire on the relay to the black wire on the compressor. Twist each wire together until they are firmly attached. If necessary, use a pair of pliers to twist the wires together. Add wire caps to each set of wires.
  • Richard Roth
    Connect the red wire plug to the positive terminal on the compressor. Then connect the black wire to the negative terminal, and the blue wire to the neutral terminal. Refer to the compressor's wiring diagram for the exact location of each terminal.
  • Richard Roth
    Stuff the wires carefully into the refrigerator cabinet. Place the relay box inside the cabinet next to the compressor unit. Vacuum out all dust and debris from inside the refrigerator cabinet and be sure the coils and fan are clean!
  • Richard Roth
    Keep me posted Scott.
    ok richard i just ordered this part, i will keep you posted, and again thanks, but if you could would it be possible to drawl out a pic of how to install this 3 in one unit. the video is a bit confussing, i need to see step by step instructions in how to connect the wires to the 3 prongs were the old relay was. i am sorry to trouble you. as well how do i rate your help i would give this 10 stars if possible,.youve been awesome and i thank you so very much.
    hello again richard i just had to argue with the seller, he was about to refuse a reurn of broken item. i had to contact ebay to start a report. they said to send this item back via post office since the weight was only 3 ozs. and that they will open a case, and make sure that the credit card gets payed back. again i thank you for your help. so it looks rather easy to install this 3 in 1 part i do hope i can understand how to do it and hope it comes with instructions. i wonder if i can find this part at a local store
  • Richard Roth
    Richard Roth Nov 09, 2012
    I will help you with it it comes. I will be here or better yet, get me thru the "contact us" link on my website athttp://appliancecafe.com since we are not allowed to give our email address out. I will find some easy instructions for you or I can walk you thru it so don't you worry!
  • Richard Roth
    The 3 in 1 will also have instruction with when it arrives.
  • Richard Roth
    Take a look at this video. It is a lot better. http://www.youtube.com/watch?v=ABIMHfZf7...
    your sir are awesome.
    whoops i meant you sir are awesome,
  • Richard Roth
    Why thank you!
    dear richard will this one work?...http://www.ebay.com/itm/Q-E-REFRIGERATIO... (going to order soon but needed to ask first). thanks again.
  • Richard Roth
    Richard Roth Nov 10, 2012
    I would get this one. http://www.ebay.com/itm/Hard-Start-Kit-R... This is the only kind I use and I know that they are reliable.
    done thanks again, you are a life savor, the compressor is running and the lines feel cold, but the compressor gets hot after a while of running it the way i am trying to run it, what i have done is put the old one back on and it will spark a little but after a while it kicks in and runs but again it done get cold in the fridge, do you think my compressor is also bad? it does make a noise and lines do get cold but fridge wont get cold, fans are also running, but i am ardering this part now and again thanks,
    wow spell check lol
    ok i just ordered this. i seen a supco part, as well it was 7.99 but i went with your idea, i sure do hope this works for me. i am a bit worried due to the fact i do hear my compressor making noise but no cold air is being made, plus it is getting hot to touch the base, i hope this has everything to do with a bad relay. i see that these 3 in one parts make older compresors last longer, i had no idea, again i really thank you for all your assistance, \
  • Richard Roth
    This should work for you. The 3 in 1 as more start power and running power so it should get that compressor running correctly. If this doesn't work, well I hate to say it but the compressor would be going out. But, I have faith!!
    yes faith is good, now i wait on the part to come, what i hate is that i ordered it from ebay again lol. says new never used, i dont trust to well those online stores. but i do trust in god to lead me in the right direction, and you sir were that direction, i would have been lost without your help, while i asked everyone about another way to get this thing working, when you said "i will let you in on a secrite" you were not kiding lol.
    Top Expert:
  • GE Master
  • 9,472 Answers
No telling til you replace the start relay.
Posted on Nov 06, 2012
Testimonial: "richard roth, awesome advice your great, your solution will solve my problem soon, i wish i would have asked fixya sooner about my problem before getting ripped off from ebay, thanks again richard roth, "
  • Richard Roth
    Thank you for using FixYa!
5 Suggested Answers
mgprice
  • 744 Answers
SOURCE: Clicking noise and fridge/freezer not cold
Hello, This problem is going to be as you suspected the relay. This part is fairly cheap around $30 if you are going to do the fix yourself. The relay is mounted to the side of the compressor. I would change both the overload and relay because of the burning smell you had. If you have an appliance tech in to look at it I would say it's going to cost some where in the region of $150-$200. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Mike
Posted on Sep 09, 2009
  • 161 Answers
SOURCE: I have an Amana bottom
If the coils were really dirty, the compressor is probably just overheated. Let it cool down overnight then try again. If it still won't stay running it needs serviced. Could be the start relay or internal overload/overheat sensor in the compressor. If the coils were really dirty and it was used like this for a long time, the compressor could be damaged. It is almost never worth replacing a compressor in a home refrigerator.
Posted on Jul 03, 2008
aasc
  • 1606 Answers
SOURCE: Fridge working but not cooling.
The white component you see , is the problem . That is the overload/relay . These short due to power surges , dirty coils in the front bottom of refrig , or just by age . They short , to save the compressor , when one of these happens . The part number you need is # 8201786 . This part just prys off (maybe one wire clip ) , easily replaceable with instructions included with the part .
Posted on Sep 06, 2009
heatman101
  • 43501 Answers
SOURCE: Seems compressor stopped working. No longer cold
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 19, 2010
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
The freezer stopped working (the fridge is working but not as cold as it should be), I cleaned all the vents and the freezer worked again fro a short time then I heard a noise like possibly the fan...
It does sound like a bad fan motor. With the compressor getting hot you may need to change the start relay, overload and run capacitor if it continues to run like this with a defective fan motor. What is the correct model number? Sea Breeze
The condenser fan motor for a model MZD2766GES is part number=> 61005323 Condenser Fan Motor or here=> 61005323 Condenser Fan Motor
Oct 18, 2013 | Maytag MZD2766GES Side by Side...
My fridgedaire cannot initiate compressor
Possible start kit bad or compressor. Make sure condensor fan motor working. if not replace it. if ok replace start kit and if still a problem you can bet it is the compressor.
Mar 02, 2010 | Frigidaire FRS26R4A Side by Side...
Hi i have a problem with the above fridge/freezer all the lights are on it makes the appropreiate noises at the right time the fan is working fine no previous problems but now the fridge and the freezer...
Hi, if the freezer fan is on, you need to get behind it and remove the panel where the compressor and condenser coil and fan motor are located. They both should be up and running also. If not, feel the top of compressor and see if it is hot but Carefully, they can get very HOT. If the fan motor is not running, that will be the problem. If it is, see if the front of the coil is dirty, like a sheet of dirt on it. Clean it. If the compressor is hot and off, and fan is running, the compressor is off on external overload. Locked up.If it tries to start you can hear it click off and back on. This is the overload. More then likely, the compressor will be faulty. If the motor is off, replace it and it will work as soon as the compressor cools down. Unplug it if the motor is bad. You can get one at a appliance parts store. Take all part, model, serial, numbers along. Check these out and keep me posted.
Sincerely,
Shastalaker7
Feb 05, 2010 | Refrigerators
The fridge/freezer is making buzzing noises that go on for 10/15 seconds every 5 minutes or so. Both fridge and freezer have heated up to 49 and 26 degrees through the night. Help!
ur compressor is trying to start but the safety is turning it off may have a bad compressor but try this first might get it working again -(safety click sound) disconnects power when compressor gets to hot or is drawing to many amps--stuck--comp gets hot unplug unit and clean with a vacuum carefully under where comp and fan are this is the condenser area after cleaning or 1 hr plug in and check for start and that condenser fan is working may be reason for overheating-if still not working compressor needs service
Nov 04, 2009 | Maytag Freezers
My Amana fridge (model ARSE67RBB) compressor has stopped working. It locks up when it gets too hot, and then makes a high pitched buzzing sound. I purchased the fridge used, so I don't think Amana is...
The buzzing noise is the compressor stalled and trying to start. Is the condensor fan working? (the fan at the back by the compressor) as if it's not it could cause this issue. If the rest of the unit is in good condition then yes I'd replace the compressor as these are normally good models and aren't cheap to buy new. This problem shouldn't happen again if you have a good new compressor installed by an expert. cheers
Oct 30, 2009 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Fan is working on fridge, temperature is set correctly but fridge not cooling. the compressor boiling hot.
is the compressor fan working and the freezer fan working also? if you have a meter you can do a amp draw on the comp.,it sounds like the comp. being so hot your coils under the frig. are real dirty or the comp is about to lra out(burn out) let me know more-mike
Oct 21, 2008 | Refrigerators
Refrigerators Logo
407 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
