Question about GE Advantium 120 Convection/Microwave Oven
Ge advantium 120 microwave
The interior light no longer works....how do i replace it, is it a bulb or a fuse? thank you for any help. i wanted to do this myself.
  • 4 more comments
  • Anonymous Dec 05, 2007
    Interior not lit when running. Can't check on item while cooking without opening door.
  • Anonymous Dec 10, 2007
    the surface light burned out. I obtained a replacement bulb. I took out the burned out bulb and replaced it with the new bulb. the surface light did not come on. I also noticed that the interior bulb in the microwave is no longer working either. is there a reset button somewhere? my email address in naeic@avci.net
    thank you
    Neal Eichler
  • Anonymous Feb 12, 2008
    I followed the instructions below and Ta DA!! Problem solved. Thanks for saving me $100+
  • anaid1230 Feb 07, 2009
    Advantium 120 light bulb out any other suggestions before we take the thig apart
  • george_gonza Feb 21, 2009
    Light does not turn on when cooking for less than 2 minutes. Is this normal. Turns on and off during speed cooking
  • Anonymous Mar 28, 2014
    Interior light bulb replacement
  • 4 Answers
It's pretty simple as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a lge advantium 120 microwave - 6229660.jpgnce!):
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Posted on Dec 26, 2007
  • GE Master
  • 9,098 Answers
On some newer models, the bulb can be replaced by removing the lower panel. But for most models, the oven must be pulled from the wall (a 2-person job) and then the cover has to be removed. The bulb will probably be a halogen type and must be handled with a clean cloth or gloves. If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number (not Advantium) here: http://tinyurl.com/gv383
Posted on May 22, 2007
I found this site/posting because I was wondering the same. However, I didn't really like the current solution posted of removing the microwave from wall so looked into it a bit further myself and have found a way to replace the interior light bulb on the Advantium 120 microwave WITHOUT removing the microwave from the wall and/or removing entire cover.
I'm going to take a few pictures and try to describe / illustrate process and post somewhere / sometime...in the meantime, if you want a brief description of how, email me at dlarmstr@nc.rr.com .
Doug
Posted on Dec 19, 2007
Doug
Advantium 120 interior light won't go out
door switch is bad or out of adjustment I have a dometic that does this sometimes I just slam it a little harder
Jan 29, 2014 | GE Advantium 120 Convection/Microwave Oven
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
My GE Advantium Microwave first had the cook top light go out. I replaced the bulb and it worked for about a week. The control panel went haywire, and then the interior light went out. I have replaced...
In this case, you have to check the control panel. There might be wire connections and contacts that loosens. The bulbs inside the oven is connected to a switch that that only functions once the oven is in closed position.
Nov 05, 2010 | GE Advantium SCA1001SS Convection /...
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 Interior light is out. How do I replace?
Here ya go... this fella did a good job and replaced the bulb for $4.95 vs $180.00 for the service call parts and labor. This is With pictures and how to steps down the page.
http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
Thanks for using FixYa.
Kelly
Apr 09, 2010 | GE Advantium 120 Convection/Microwave Oven
Interior light always on Ge advantium 120
I bet by now your microwave is no longer working....did the bottom or top "hook" finally break off? I found that mine had cracked and started coming loose and so when it closed it was no placing enough pressure on the internal safety switch that tells the oven the door is shut. I was able to use a sturdy plastic glue to solve the problem but finally after about 2 years of fixing it I can no longer get it to bond. Now, I'm looking for a new part. Who makes a product this expensive with plastic parts!!?!??!?!? So frustrating.
Apr 13, 2009 | GE Advantium 120 Convection/Microwave Oven
I have a GE microwave. Model # JVM1870BF02 and the interior light is not working. I see a circular disc in the roof inside the oven but, can not seem to slide it and remove to replace the light bulb. Can...
THAT DISC ACTUALLY HOUSES THE ANTENNA FOR THE MICROWAVE ENERGY. NO NEED TO GO INTO THAT. TAKE OFF THE FROM GRILL AND IN THE MIDDLE THERE IS A METAL COVER WITH ONE SCREW. TAKE THAT OUT TO ACCESS THE BULB.
Jan 25, 2009 | GE Advantium 120 Convection/Microwave Oven
Replace Microwave Light
Apparently there's a flaw in the design. My light has gone out/ been changed roughly evry 9 months. No longer under warranty and cost to have someone come in and replace is outrageous. Light bulb is located on top of the oven. You need to remove the top to get at it. Looked fairly easy.
Jan 01, 2009 | GE Advantium 120 Convection/Microwave Oven
Advantium Bulb replacement
You are describing the little bulb in the front. The speedcook light is a different bulb
See: http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
Apr 12, 2008 | GE Advantium SCA1000H Convection /...
GE Advantium SCA 1001HS
Should be able to get to the lamp by removing the grill.
Oct 04, 2007 | GE Advantium SCA1000H Convection /...
GE Advantium 120 Convection/Microwave Oven Logo
1,218 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
