Question about Fujitsu 18C1 Air Conditioner
Flashing led codes fujitsu asta09lcc - Fujitsu 18C1 Air Conditioner
3 Suggested Answers
SOURCE: CODE FLASH 2TIME
fujitsu clear the code
Posted on Feb 14, 2009
SOURCE: Fujitsu Inverter ASTA09LCC Where is the drain tube
It is directly behind & thru the wall to outside next to the refer. piping.Everything goes outside thru a 3" hole. tube should b there.Blow it out.good luck
Posted on Mar 12, 2010
What does 3 green led flashes in sequence, operation led off mean on Fujitsu ASTA09LCC aircond
This means a "Serial reverse transfer error during the operation"
Diagnosis:
When the indoor unit does not receive the signal for 10 consecutive seconds during the operation
>Permanent stop after 30seconds.
[Diagnosis Point]
Check the indoor /outdoor cable connection (in order). If the cable wiring is not abnormal, measure the voltage of the outdoor
unit terminals and diagnose the defective location.
(Refer to the after mentioned [Serial Signal Diagnosis] for the voltage measuring method and diagnosis method.)
This is generally caused by a faulty controller board in the outdoor unit. Often they are shorted out by geckos or bugs but sometimes a power surge.
Jul 14, 2015 | Fujitsu Heating & Cooling
I have two flashes on the timer light of my indoor unit of Fujitsu Inverter ASU9RLS
Serial signal (reverse) error, at operation start up. operation led - off, timer led - 2 flashes, coil dry led - off, check wire between indoor and outdoor
Jul 10, 2015 | Fujitsu ASU9RLS2 Single Zone Wall Ductless...
Fujitsu 42 wide plasma tv No sound & No picture Only red LED light flashes Model no : PDS4233E-H
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 23, 2015 | Fujitsu Televison & Video
Timer light flashes twice on my asta09lcc but it wont work
If operation light is normal and timer light flashes twice, the error is:
Most likely a faulty outdoor controller PCB. Around $250 for new board plus labour.
Jul 09, 2012 | Fujitsu 18C1 Air Conditioner
Fujitsu Inverter ASTA09LCC Where is the drain tube located? The air con is leaking water and I believe drain may be blocked.
Mar 12, 2010 | Fujitsu 18C1 Air Conditioner
Manual for Fujitsu plasma inverter Model ASTB09LDC
Fujitsu Plasma ASTB09LDC, has the operation and timer leds flash 4 times then the timer led flashes 3 times then cycle repeats. What does this mean?
Jul 28, 2009 | Fujitsu Heating & Cooling
Fujitsu plasma screen went blank and the LED light which generally shows green (on) or red (off) is blank (no color) as well.
Usually when these develop a fault you will get flashing LED codes. If you are not getting any the power supply may have failed completely.
Try another cable and socket in the first instance and ensure the manual power switch feels normal in action.
Jul 06, 2009 | Fujitsu Televison & Video
CODE FLASH 2TIME
Feb 14, 2009 | Fujitsu 18C1 Air Conditioner
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu Inverter ASTA09LCC - heating not working
Use a pen to hit the reset button on the remote.
Feb 09, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu 18C1 Air Conditioner Logo
385 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
