Western Digital Unknown partition - Computers & Internet
  • 31 Answers
I think one should make use of Yodot Hard Drive Recovery software in order to recover partition. I have used this software for SSD partition recovery. I thought the recovery procedure would be difficult to follow. But the process was so easy that I could recover all the files within few minutes. This software is the best option to recover ssd partition.
Posted on Jan 23, 2013
2 Suggested Answers
  • 16 Answers
SOURCE: Is there a way to recover lost data from my Western Digital My Book??
Yes, there is a way to recover lost data from a WD drive.
First thing first - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD.
The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more from: http://www.western-digital-data-recovery.com/
Best regards!
Posted on Aug 24, 2012
Hibernation partition
Make sure you have the HDD in the same state as it was on Hibernating. If it was removed after Hibernation, it will not be 'seen' by the PC. Everything that was connected during Hibernation MUST be connected again when starting the machine so the O/S can follow the route.
Nov 22, 2013 | Western Digital Computers & Internet
My new Western Digital Desktop PATA EIDE 3.5 Inch Internal 250GB Hard Drive only shows 127GB on My Computer. I am running XP SP3 with IDE Connectors. Is the Mother Board too old to handle that many...
The motherboard BIOS most likely have a hard drive size limit. Yes you can create two or mare partitions to use the rest of the hard drive space.
Go to Control Panel - Administrator Tools - Disk Manager to create a partition and format this partition.
Aug 12, 2012 | Western Digital Caviar SE 250GB 7200rpm...
Wd drive PATA wdc-wd2000 jb - 00fua0 should be a 200 gb drive. said was running out of space and when checked found drive was only reporting it's size as 31.49gb. have tried everything I can think of to...
Check the hard drive for partitions, it could have several partitions, but only the first partition has been formatted.
Go to Control Panel - Administrative Tools - Computer Management - click on Disk Management and look at the Western Digital it could be Disk 1.
If you see unallocated partition, you can create and format this partition.
OR
You can delete the existing partition and create a single large partition and then format this partition.
NOTE - this process will delete the existing data on the hard drive.
Dec 16, 2010 | Western Digital (WD2000BB) 200 GB Hard...
WD 500 GB Passport Formatting error
you may have a FAT32/NTFS format problem between your wd500 and your pc. or differently formatted partitions. right click on their device letters on 'my computer' and look at 'properties'. should tell you how they're formatted and # of partitions, etc.
just a guess!
good luck!
Sep 29, 2009 | Western Digital 500GB My Book World...
320 GIG Hard Drive now thinks it is an 80 GIG hard drive
Enter your BIOS setup and check what the BIOS sees for hard-drive. It may not be assessing the drive size correctly so you may have to force it by manually entering the data it needs to see the drive.
May 23, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Western digital Scorpio 120 G
Actually there is no solution, the hard drive is bad.
What I ended doing was recording the partition in iso. ( I had a Factory Partition)
Got a new hard drive 160G scorpio unfortunately it does not come with installation disc.
Installed Vista, and with vista created a partition and then installed the contents of the factory partition.
Feb 18, 2009 | Western Digital Scorpio WD1200BEVS 120 GB...
USB device not recognized
if it,s showing in the device manager as an exclamation mark. that means it,s found it, but can,t recognise it.
i,d suggest formatting and partitioning it, with some good software. also ensure that it,s powered via 2 usb cables to laptop, from 1 on the drive itself. some bigger hard-drives, need the extra power to drive them.
Mike @ compurepair.
Jul 25, 2008 | Western Digital 500GB My Book World...
Western Digital 120 GB Model WD1200U017.002 SN WXE0o6620867
1.I will suggest you please partitioned it properly.
2. Check your Registry. Some times people use to FIX Registry for Reading multiple Partitioned External Drive.
3. You must require partition.
4. Have you check the cable which was supplied with the HD. As other cable may not support properly.
Enjoy
SQE
Jul 21, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
HDD data recovery
most hard drives have that erie only 2 partitians at a time this is with your computer how it can handle since you made three particians there is a chance that it only allows partitions of only 2
say for instance you have a celeron your comp would only allow what you memmory can give you this would knock out the 2 partician when created the 3rd partician
not enough memmory to fill all 3 partitians
safe end to this particians in long run can hurt your comp more than help it i suggest buying another hdd to make your back ups or get a portable pull out system hdd this ensures your files are as easy to get as putting in a new hard drive
hope this gave some insite
Apr 29, 2008 | Computers & Internet
Partition error
Try using the command FDISK /mbr. This should fix the master boot record. If not, then if you don't care about the data on your drive, you could wipe it clean with any of the several utilities available on the web and then try partitioning it. Search for "Wipe Disk" in Google.
Sep 28, 2007 | Western Digital Caviar 40 GB Hard Drive
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
