Minolta dialta di552 error code c-0072
HOW DO SOLVE THIS ERROR CODE C0072?
3 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: Copier Minolta model D1520
Remove the toner bottle and let the copier warm up to Ready, then re install the toner bottle and see what happens
Posted on Feb 08, 2008
  • 1602 Answers
SOURCE: Minolta DiAlta Di450 Error Code C-0072
I NEED THE ERROR NUMBER OR HOW MANY TIMES DOES THE BLINK WHEN YOU TURN ON THE COPIER.
MORE INFORMATION PLEASE ROD
Posted on Feb 13, 2009
C-0072 is showing on my Konica Minolta di552 please help to remove this error
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it is damaged you get a code. If this does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 06, 2015 | Konica Minolta Minolta Di450 Di470 Di550...
How to solve code C0510 on konica minolta di552
Open the front door upper left access cover, open press trouble reset if the code comes back do not reset as this deals with fuser can catch on fire will ruin perfectly good day
May 01, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Code C-0072
power off the machine. Then take the toner bottle out be careful hole in the bottle may be down so that yank it out. pull out slowly!!!!!!!!!!!!!!!! Then with no toner bottle in the machine turn it on let it goes thru its normal routine it may take a while you may even here the the toner bottle turning GOOD SIGN. When the the machine says replace toner re install the toner bottle PROPERLY if the nub (s) on the toner bottle are bent replace the bottle, MAKE SURE it is the right toner bottle for the machine be amazed how may people place and bottle that fits!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Apr 17, 2014 | Minolta DiALTA Di183 Copier
Error code c 145 E ON MINOLTA di 552
Sir/Mam the you have the problem under the Di183 but you have di552 check the 183 no such code Sure it is a Di 552 and code is c145E?
Apr 11, 2014 | Minolta DiALTA Di183 Copier
ERROR CODE C 145 E FOR MINOLTA DIALTA
Sir, You have this problem listed under Di183 , Di3010 and Di552 First two have no code C145E Never heard of a Di552
Please give the Model number and code again does this have Fax option?
Apr 11, 2014 | Minolta Di3010 Copier
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
Error code C0601 Error code C0072
for the 0072 try this:
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
As for the 0600 code the scanner the bright lite under the big glass is not lighting replace the lamp and board
as for the
Dec 16, 2010 | Minolta DiALTA Di183 Copier
Feb 13, 2009 | Office Equipment & Supplies
Minolta di520
es el pote fraSCO DEL TONER
AT THE TONER WHERE IS
Jul 17, 2008 | Minolta DiALTA Di520 Laser Printer
Feb 07, 2008 | Office Equipment & Supplies
91 people viewed this question
k24674
jasbo
jasbo
