Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
What is the uses of the memory - Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
  • Intel Master
  • 5,660 Answers
Depends on what Memory you are referring to, yampratwum
1) Cache for a Processor;
A small memory area on the Processor.
(L1 and L2. Some Processors also went to L3 cache)
Cache operates at the same frequency rate ('Speed') as the Processor.
It is the First memory area the Processor accesses.
http://en.wikipedia.org/wiki/CPU_cache
http://computer.howstuffworks.com/cache.htm
http://www.hardwaresecrets.com/article/How-The-Memory-Cache-Works/481
2) Ram Memory;
Volatile memory.
Once the computer is turned off, all memory stored in Ram Memory is GONE.
Ram Memory typically operates at half, of the frequency rate of the Processor's Front Side Bus. (FSB)
It is the Second memory area that the Processor accesses.
http://computer.howstuffworks.com/ram.htm
3) Harddrive; (Hard Drive. Hard Disk Drive)
This is the Third memory area the Processor accesses.
There is also a small memory area on the harddrive.
This is it's Cache. It is called the Buffer.
http://computer.howstuffworks.com/hard-disk.htm
http://en.wikipedia.org/wiki/Disk_buffer
http://www.hardwaresecrets.com/printpage/177
4) Virtual Memory;
An area on the harddrive that Windows has allotted.
Rule of thumb is Virtual Memory is one and one-half, (1-1/2) the amount of Ram Memory.
Example;
2GigaByte (2GB) of Ram Memory?
Typically Virtual Memory will be 3GB.
http://en.wikipedia.org/wiki/Virtual_memory
5) BIOS;
Basic Input/Output System
A program that is flashed to an EEPROM chip. The BIOS chipset.
Another small memory area.
http://computer.howstuffworks.com/bios.htm
http://computer.howstuffworks.com/computer-memory.htm
Regards,
joecoolvette
Posted on Nov 06, 2012
Memory is used up by excel
I don't think you can. It's a real resource hog especially if youre using 2010/13. See below.
Excel 2003 is officially limited to 1 Gigabyte (GB) of memory.
This limit appears to be a limit on the working set memory used by the Excel process, which is the memory reported by Windows Task Manager.
Although Excel 2003 has a substantially increased memory capacity, many of the individual specific memory limits listed below have not changed in Excel 2003.
Excel 2007 is limited to 2 Gigabytes of memory for the Excel process under Windows XP/Vista (Windows memory limit).
This 2 Gigabyte limit is a limit on the Virtual Memory address space. Virtual memory used by a process is larger than the working set memory reported by Windows Task Manager, so the amount of useable memory under Excel 2007 is considerably less than twice that of Excel 2003.
Because Excel 2007 (Excel12) also requires more memory to store the indexes to the increased number of rows and columns you may not be able to load larger workbooks under Excel 2007 than was possible under Excel 2003. Memory Fragmentation may also mean that it is difficult to make use of all of the available 2 GB of virtual memory.
Many of the individual memory limits listed below have been removed in Excel 2007.
Excel 2010 is available in 2 versions: 32-bit (2 Gigabytes of virtual memory) and 64-bit (8-Terabytes (which is 8000 Gigabytes of virtual memory)).
The 32-bit version has the same memory limits as Excel 2007, but the 64-bit version, when used with a 64-bit Windows operating system, will have extremely large memory limits.
Note that the different versions of Windows Vista 64-bit and Windows 7 64-bit support differing amounts of RAM.
Aug 17, 2014 | Microsoft Excel for PC
I want to unlock my micro sd card 2 GB
u can unlock your memory card by the following steps.
Use 2 software phone for unlock the memory card. Use your frinds mobil.
Use a software set(eg nokia 5800, 5233, 5230. 6120c etc)
Insrt the memory card into the software phone
Select setting > data mgr > memory > format memory card...
Its working... Try it..
Note: formating memory card will delet all datas in the memory card.
Sep 21, 2011 | SanDisk 2GB microSD Memory Card
How to transfer messages from phone memory to memory card using nokia E72
just go to Message setting Select other in that Memory in use By Default Phone Memory is selected so change it to Memory card while changing memory your messages will be copied to memory card.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 18, 2011 | Nokia E72 Smartphone
I am using the camera for 2 monthes and now its says memory card error. i didnt changed the memory card SDHC what sould i do
Welcome to Fixya. Getting a card error means that:
* memory card is not yet formatted for camera use
* memory card requires cleaning
* using a incompatible memory card
* camera malfunction
Here are some troubleshooting steps that you can do it by yourself. However if the error message still persist, you should contact your Canon service center.
Memory Card not formatted
You have to format the memory card. Some memory card can't be formatted using a PC's, or formatted by another digital camera. I suggest that you have to format the memory card using the camera itself.
Memory Card requires cleaning
Use a dry and soft cloth in cleaning the memory card and the memory acrd slot.
Using a clean pencil eraser can also be useful in cleaning the memory card but you have to be careful, slightly rub the eraser on the memory card.
Incompatible memory card
Please use a compatible memory card
Camera malfunction
In this case you have to contact you service center. It will be a big help if you can check if your camera is still under warranty to get a free service.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Apr 20, 2011 | Canon PowerShot SX210 IS Digital Camera
My mmc card is corrupted how can i format mmc card
Hello DJB,
Formatting the memory card is a easy process. You can format the memory card from the format option available in memory card option itself. You can also format the memory card using the desktop pc or laptop. Remove the memory card from the phone and connect the memory card in computer using the external memory card reader and format the memory card.
Apr 15, 2011 | Nokia 6630 Cellular Phone
I keep getting a card error and I have tried 9 dif cards including a new one and still the same thing.
Welcome to FixYa.
All you need to do is:
Camera malfunction
Apr 11, 2011 | Cameras
When i want my photos go in memory card then i click on shutter button its not go in memory card its tell me internal memory is full why tell me its full information. very thanks for this kindness.please...
This camera needs some internal memory free in order to work at all. It can't use memory in the memory card unless it has some internal memory free. You need to delete some pictures in internal memory.
It should use the memory card memory automatically. If it can't use the card (if card is incompatible) there will be an error message. Some cameras can't use SDHC cards even though they fit in the SD slot. Or the card may need formatting. But first you need to free some memory in the internal memory.
Dec 02, 2010 | Kodak EasyShare C180 Digital Camera
I cannot change my 'Memory in use' from Phone Memory to Memory Card. 'Changing message memory in use' is appearing, but after that, nothing happens, it's still using Phone Memory as storage.
are you doing it for messages, if yes, it works properly but whenever you remove your memory card it reverts to phone memory, you have to revert setting back to memory card
Jun 27, 2010 | Nokia N73 Cellular Phone
Memory upgrade
We have the memory you need. Memory-Up is committed to provide the best memory and excellent services for all of our customers. We know that sometimes it is a bit confusing to buy the correct type, speed, and capacity of memory for your system. Therefore we hope that these tips below would help you for buying the new memory.
Memory Upgrade Tips
What is Compatibility and Memory Density Issue?
Memory module can be composed using different type of memory chips and therefore created different type of density for the module. For instance, a 512MB PC2700 DDR SODIMM memory can be composed using eight 32x16(High Density 512Mb technology) memory chips or sixteen 32x8(Low Density 256Mb technology) memory chips. As the laptops are equipped with different memory chipsets, some older laptop (chipset) would have compatibility issue working with the modules that is built with the newer 512Mb technology. Using the Not-Compatible memory will result the laptop to either not boot or only recognizing half of the memory modules. Thus that is not the correct memory for your system. Our Memory Finder and Memory Scanner will help to eliminate those problems and find the correct memory for you. We guaranteed the memory to work or your money back.
How much memory do I need?
Here are some general descriptions for different type of users and the amount of memory they would need for their systems.
Normal User: The system is mainly used for checking e-mails, processing word/excel file, and web surfing. Suggestion: 512MB to 1GB of system memory.
Power User: The system is mainly used for playing computer games, editing photos/videos, running database queries, or multi-tasking environment. (Surfing web/Processing Word/Excel File/Listening to Music). Suggestion: 1GB to 2GB of system memory.
Super User: The system is mainly used for running large number of database queries, professional editing of photos/videos, heavy multi-tasking environment. Usually a server or a workstation would be considered as Super User due to the multiple accesses from users. Suggestion: 2GB and above of system memory.
How much memory and memory slot do I have with my system?
You can download our Memory-Scanner to find out the the amount of memory that you have and the memory slots that are available for upgrade.
How many memory module should I buy?
It is recommended to purchase one module with bigger capacity than two modules with smaller capacity. For instance, if you can buy either one 1GB memory module or two 512MB memory modules for your system, it is recommended to get one 1GB and leave the other memory slot empty for future upgrade if necessary.
Note: For systems that supports dual channel memory mode, although memory modules need to be installed in pairs to enable Dual Channel Memory Mode, we still recommended users to purchase one bigger module than two smaller modules since Dual Channel Memory Mode has only a minimal improvement in the actual system performance.
What if I want to mix different memory together?
Different sizes/speeds of memory can be used together as long as their specification are qualified by the systems. For instance, a laptop can use one 256MB and one 1GB of memory for the total of 1.25GB system memory. Mixing two different speeds of memory modules would result the system to run at the speed of the slower memory between the two modules. We recommend users to use our Memory Finder or Memory Scanner to find the correct memory for your system.
i thnk that will helpfull for u
Oct 18, 2008 | HP Pavilion ZE5730 Notebook
Nokia N70 wont acknowledge memory card?
Note: This device uses a Reduced Size Dual Voltage
(1.8/3V) MultiMediaCard (RS-MMC). To ensure
interoperability, use only dual voltage RS-MMCs. Check
the compatibility of an RS-MMC with its manufacturer or
provider.
Use only compatible Reduced Size MultiMediaCards
(RS-MMC) with this device. Other memory cards, such as
Secure Digital (SD) cards, do not fit in the memory card
slot and are not compatible with this device. Using an
incompatible memory card may damage the memory card
as well as the device, and data stored on the incompatible
card may be corrupted.
You cannot use the memory
card if the door of the
memory card slot is open.
Format a memory card
When a memory card is reformatted, all data on the card
is permanently lost.
Some memory cards are supplied preformatted and others
require formatting. Consult your retailer to find out if you
must format the memory card before you can use it.
To format a memory card, select Options > Format mem.
card
. Select Yes to confirm. When formatting is complete,
enter a name for the memory card, and select OK.
Apr 03, 2008 | Nokia N70 Cellular Phone
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
230 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
