Question about New World G60m Gas Single Oven
New world gas oven grill igniter keeps clicking
I have a new world single gas oven and grill. the grill lights ok but once warmed up the igniter starts clicking even though the grill is alight.
  • stephen bird Nov 07, 2012
    could it be the thermocoupler
3 Suggested Answers
gasman44
  • 83 Answers
SOURCE: My grill won't light
Hi
Forgive me for asking this, but you have read the instructions haven't you?
If you have, and it's still not working, then the likelihood is that there is a fault, this could be one of the following:
Faulty solenoid valve to grill (some grills had a safety button fitted to stop you from closing the door if the grill was being used)
Blocked pipe inside unit
Either way you need to get a qualified gas engineer to take a look at it, if it's under warrranty call the manufacturers first!
I hope this helps
Steve :)
Posted on Jul 14, 2009
  • 447 Answers
SOURCE: gas mark nob not having any effect on gas levels
Time to change the thermostat. the cap tube sounds like it has been broken. If it has a temp control board, change the temp probe. The clicking sound, if unit is equiped with an ignition control modual, is bad, (not shutting off after sensing pilot) or sensor rod is dirty.
Posted on Dec 23, 2009
Ignition Switch ?
There is a safety device built into gas outlets to prevent the gas from running if it fails to ignite. It works by heat. If a valve is not heated enough then the main valve will not remain open. That's why many gas appliances ask you to leave a second valve open for as much as 30 seconds after igniting. These valves are highly reliable. It sounds like your appliance may not be warm enough. Try to run it on high for 5-10 seconds before you turn it down. To access the valves; pull all the knobs straight off first then try to remove the facing by the screws. A make & model would be helpful since there are many different configurations.
Jun 27, 2015 | Ovens
The ignition continues after gas lights on new world elegance/cooker and grill
The igniter will glow orange while the oven is on. This is NORMAL. If it went out the burner would not come back on when the thermostat calls for heat .
Aug 18, 2014 | New World G90m Gas Double Oven
How do you light the gas grill
I assume outdoor gas grill? If so, turn on gas at tank. There should be a knob that has a lightening bolt or something similar representing ignition. Turn the knob to that diagram and click the igniter till it lights. If you don't have igniter use a long grill lighter. Once that is lit you can turn other knobs that control other rows of gas if so equiped.
May 17, 2014 | Magic Chef Ovens
New World G90m grill turns off - overheating?
Its a good chance its the thermal control board to the fan (PCB),if faulty it doesnt allow fan to reach correct speed thus overheating.
Hope this helps
Feb 05, 2012 | New World G90m Gas Double Oven
Oven keeps cutting off gas does not stay on
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 16, 2011 | New World G60m Gas Single Oven
Gas mark nob not having any effect on gas levels in the oven seems like it is on its highest setting all the time? Also the ignition keeps clicking away all the time could this be a s/c on the wire from...
Dec 23, 2009 | New World G60m Gas Single Oven
Grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Aug 21, 2009 | New World G70m Gas Double Oven
New World TGO 70 grill not working because door was closed
THIS IS PROBABLY BEST LEFT TO A QUALIFIED ENGINEER. To reset the grill thermal cut out. This is located under the metal panel at the top of the unit and it is necessary to ether partially or fully remove the whole oven from its housing to get at it. 1. Disconnect electric supply. 2 remove the 2 housing retaining screws. These are located either side of the at the top of the grill cavity. 3.Pull the whole oven /grill unit out and support it underneath to stop it falling forward. 4. Remove metal cover covering top of oven. 5. the safety cut out is a small component that has 2 wires connected to it by spade terminals, in the middle of which is a small red button. push this button gently with the end of a pencil or screwdriver until it clicks. This should now be reset and allow the gas supply to the grill to resume. Finally reassemble making sure that the integrity of the gas and electrical supplies are, in no way compromised and test.
Aug 20, 2009 | Ovens
Hi
I hope this helps
Steve :)
Jul 14, 2009 | New World G70m Gas Double Oven
New world tgo 70 grill
I have a TGO 70 for sale in Doncaster
Aug 14, 2008 | New World G60m Gas Single Oven
New World G60m Gas Single Oven Logo
234 people viewed this question
Top New World Ovens Experts
paulcarew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
