Question about Toshiba Satellite P755-S5320 Core i3-2330M Dual-Core 2.2GHz 6GB 640GB DVD±RW 15.6" LED Notebook Winodws 7 Home Premium w/Webcam & 6-Cell
Toshiba satellite p755-s5320 keeps shutting down
    New Friend:
I hate to tell you this but I have the same problem with this laptop and it's bad news. The power button is likely the problem and Toshiba no longer makes the part so it cannot be repaired. Per my repair person it's poorly designed like a piece of tape and 2 pieces of aluminum foil and he can see why it quit working. It took a while to discover that this was the problem and he had to finally take it apart to see this. Toshiba will take no responsibility for this poor design and has told me to buy a new computer even though mine was purchaed in January of '12 and I started initially having this issue probably 14 months after purchase. I would love to keep finding more people with this problem, maybe if we all complained Toshiba would listen. You are not the only other person with this problem I have seen on internet forums.
Posted on Jun 07, 2013
  • Ron Pardee Jul 12, 2013
    Disappointment in Toshiba Satellite (P755-S5390, serial # ZB158998K) I purchased this laptop on April 1, 2012 from Staples. It failed to stay powered up in mid June of 2013. Staples easytech department diagnosed the problem being with the fan and the fact that it will not stay on, and powers off the computer (before it even has had time to boot up).
  • Toshiba Master
  • 27,725 Answers
Toshiba Laptops Overheating
Toshiba laptops are notorious for overheating, causing problems such as the system freezing up, the blue screen of death, or an actual automatic shut-down.
Usually this problem is caused by dust trapped in the computer's heatsink, which prevents the cooling system from working properly.
Solutions are fairly easy and straightforward.
Identification
Computer shops say that up to 20 percent of Toshiba laptops brought in for repair have issues with overheating.
Symptoms may be as simple as the keyboard and bottom of the laptop being very hot while the computer is working, or the fans running at maximum rotation while the system becomes very slow for several minutes at a time.
More inconvenient issues are common, such as the system completely seizing up and having to be "killed" with the battery pulled out, or the computer may shut down all by itself with no warning.
Sometimes the laptop works fine until the user starts any significant memory-demanding applications, like photo editing software, several Internet windows being open at the same time, or an Internet video stream.
Significance
A common problem with the Toshiba laptop is that dust becomes clogged between the cooling fan and the heatsink, a device which lowers the temperature by dissipating heat into the surrounding air.
Now heat produced by the processor is trapped inside the laptop, and the fan cannot blow it out.
Prevention/Solution
If you or a friend know enough about computer hardware to take the case apart, you can clean the heatsink.
Some Toshiba laptops allow access to the heatsink with a latch on the bottom of the case.
You will need to remove the fan, then clean the fan and heatsink with a vacuum cleaner or a can of compressed air, specifically designed for computer cleaning.
Types
Sometimes the fan becomes defective and must be replaced.
A common sign of this problem is the fan becomes noisy and perhaps makes a grinding sound.
Again, a person handy with computer hardware will easily be able to replace the fan, which can be purchased directly from Toshiba.
Considerations
A couple jerry-rig solutions can work, too, if the heatsink is not completely clogged.
You can try putting a vacuum cleaner hose to the fan opening and see if that draws out enough debris to clear up the problem.
If not, keeping a desk fan running, pointed at the back of the laptop, will keep the machine cooler.
Also, laptops stay cooler when not sitting flat on a surface.
Placing the laptop on a stand is a possible solution.
You can buy or make a stand, and if you don't care about aesthetics, even two 9-inch-long pieces of wood or a baking rack will work.
Check your computer ram modules for secure dust free seating you might even remove the ram modules to check for dirt on modules and in the module socket and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
if your computer runs long enough scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be running your computer over its limits causing memory dumps
also under processes see what is ticking over in the background you might have a virus again if you see something you
dont need to be and users you will see who is using your computer
you might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility of the ram before making any purchase
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
Posted on Nov 06, 2012
The battery run down without no use and when you boot it, it will shut down by it self, and is booting slowly.
If this is a new laptop, you need to migrate your data off it and get it replaced. Something is draining your battery, or the battery is bad. Keep the power cable plugged in and save what you need. Contact your vendor customer support for a replacement.
Mar 17, 2015 | Toshiba Satellite P755-s5320
How to factory reset my Toshiba satellite laptop P755-S5120, core i7, 64bit plese help me.
Go to BIOS setting through the Bios setting Key eg F2 and click on file then select set to Default.
Oct 04, 2013 | Toshiba Satellite P755-s5120 Core I7 Pc...
My laptop fell off he bed and the power comes on but the screen is blank. i tried plugging to an external screen but no luck. i just want to urgently get a few documents before it goes in for repairs......
if you tried to plug another monitor and do not work, is signal that control video is faulty.
You must go to some repair shop computer for to fix it. or you mus dissasemble the l.top and order the parts.see the video attached
God bless you
Oct 01, 2013 | Toshiba Satellite P755-s5320
Toshiba drivers WINDOWS 7 64 BIT
You can use a wired Ethernet connection to connect to the router.
This requires a different set of drivers to Wi-Fi.
Sep 05, 2013 | Toshiba Satellite P755-s5320
My toshiba satellite p755 keeps shutting down
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Nov 04, 2012 | Toshiba Satellite P755-S5385 15.6 Intel,...
My Toshiba Satellite P755-s5320 letters and number will not work. Even the number pad on the right side won't work, and yes the num lock is on. I'm thinking my cat may have pushed a button or...
Yes you are correct the print box is displayed when Ctrl + P are pressed. When the Ctrl button is held down one will not be able to type numbers at all.
I think your Ctrl button is stuck, try pressing it repeatedly to unstick it.
Worst case you will need a new keyboard.
Take care!
damnor01
Sep 11, 2012 | Computers & Internet
My Toshiba satellite p7S5- S5320 just got in January2012, well i let a friend get on my computer and when they got off my back lights on keyboard stop working, can some one please help me to get it ba
First, don't even think about using the recovery disk for this. Talk about overkill.. Would you really wipe out your entire system just for a little light?
Ask your friend what they did Then just undo it.
Don't let anyone use your laptop unsupervised. Or, create a guest account with limited restrictions and let them se that.
Don't know what type of system you have, since you didn't mention it, but check the documentation that came with the laptop, or look in the control panel for the keyboard settings, or the MobleMe software.
Hope this helps. Please rate this response.
Randy
Aug 31, 2012 | Toshiba Satellite P755-s5320
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
Toshiba Satellite P755-S5320 Core i3-2330M Dual-Core 2.2GHz 6GB 640GB DVD±RW 15.6" LED Notebook Winodws 7 Home Premium w/Webcam & 6-Cell Logo
1,201 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
