Question about Geberit Home
How do I remove Gerberit Airline flush plate on top of toilet cistern?
  • julius schachter Nov 07, 2012
    I want to access the cistern. It is hidden in wall, with dual flush plate on the top, and I don't know how to remove the flush plate.
Obertelli
  • 3006 Answers
SOURCE: water overflow from cistern to bowl
The shut off valve depends upon where your plumber fitted it and whether one was installed at all. If there's not one near the cistern then you'll need to find the stop valve which is on either the main household cold water tank outlet or if the cistern is filled directly by mains water then you'll need to turn off the main supply valve or even the valve in the street.
The fault is caused by a failed syphon assembly inside the cistern. Although it's possible to remove the faulty part and replace it the sheer number of different syphon assembly designs and the age of many of them usually mean that it's quicker and simpler to replace the entire assembly. Without knowing exactly which make and model of syphon you have it's impossible to give you any more specific details as the operating methods vary so widely, but if you're mechanically minded then you may well find that you can dismantle the old syphon and locate the failed seal. Sometimes all you need to repair them is an old car tyre inner tube and a pair of scissors. A repair often costs pennies and takes hours, a complete replacement syphon assembly often costs between £13 and £60 depending on the model and design (plus labour) but usually takes no more than around fifteen to twenty minutes to replace if the cistern is close-coupled to the toilet and a bit longer if it's an old-fashioned high level cistern with restricted access.
Given the need for guesswork based on the limited details in your question I hope that you appreciate my reply and ask only that you return the favour by rating my answer.
Posted on Oct 01, 2009
Testimonial: "thanks for the fast reply and solution"
SOURCE: my toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
Posted on Oct 31, 2009
SOURCE: toto toilet with gmax flushing system blue top
I have the same problem and can not find a solution. The toilet flushes fine but then a delay in filling up the tank occurs. Is there a part I can replace? Does something need to be cleaned or cleared?
Posted on Jan 15, 2010
  • 5 Answers
SOURCE: cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Posted on Jul 02, 2010
  • 3 Answers
SOURCE: Weak dual flush does not empty the toilet bowl.
Waste pipe problems aside, if its a dual flush check you are actually working the full flush button and that the mechanism is working properly and not stuck operating only the half flush. If then you look in the tank both the total water level in the tank (white screw at the filling valve) and the quantity of water let go for each full and half flush (blue parts below, in the flush mechanism) can be set to different levels. Yours might be set to the minimum
Posted on Mar 13, 2012
How to mend a running gural vitrifiye toilet cistern
With lid removed, look down into it and remove and replace the black rubber thing in the center. This is the flush valve and is worn to the point where is no longer provides a tight seal allowing water to pass and run into bowl. Also, could be something underneath it not allowing it to seat properly.
Aug 26, 2014 | Home
Tip
FIXING A TOILET THAT WILL NOT FLUSH!!! a simple but very effective money saving...
This simple how to, is based upon most lever operated toilets, with the cistern mounted above the toilet bowl. The make and model of toilet used for this feature is of the following:
Toilet and internal syphon
DUDLEY ELITEDudley S7 Cascade syphon
Problem:
My toilet will not flush, but the ball float valve is working and there is water in the cistern; no leaks present and the flushing lever is not broken or disconnected, what do I do?
Answer:
first isolate the water to the toilet or the main water supply to the house. Bail out the water from the cistern using a small jug or cup, (or you can syphon the water manually using a hosepipe or similar pipe, a towel to cover your mouth, and either a bucket or the toilet bowl) and remove water from the bottom of the cistern with a sponge.
Changing the syphon in a toilet that is not close coupled is far easier as you do not need to remove the cistern from the wall!
Undo the lower of the two large nuts beneath the cistern using a large pipe wrench or pair of water pump pliers, now disconnect the flush pipe and push it to one side.
Place a bucket or bowl beneath the cistern and undo the Nut which is immediately below the cistern (syphon replacing nut), some water may be released by the syphon, take note of any washers that are removed as new ones need fitting when replacing the siphon.
Unhook the lift rod from the flushing lever and remove the syphon.
Inside the toilet syphon, there will be a small plastic piece of sheet called a diaphragm; you can fabricate a replacement using the plastic title cover on a DVD case. Cut this to the exact same size and shape as the original part, and fit this to where the original diaphragm was. This is your new replacement.
Refitting is a complete reversal of removal, be sure to fit any washers (preferably new ones) that you have taken out. Ensure everything is tight but do not over tighten before refilling the cistern
on Aug 09, 2010 | Plumbing
Invisi Series ll Round Dual Flush Plate & Buttons
That would be a leaking flapper valve. They are inexpensive and easy to install. Good luck
Jun 09, 2014 | Toto Aquia II Dual Flush Toilet
Geberit model 150-403 toilet Water keeps running after flushing
I have the same problem with my new Gerberit 800 plus fitted last Thursday, it will not stop flushing in the manual it says valve problem contact service dept. Joke they dont give a number for them.
Feb 02, 2013 | Home
I am having trouble getting the top of the cistern of an Omnia Pro suite. Does the flush button unscrew or clip off.
The flush button should unscrew from the top of the lid. to replace the flush mec. and to remove the lid.
Good luck
Nov 09, 2009 | Villeroy & Boch Home
Cannot remove top of cistern
Oct 29, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
I needs new valves for my dual flush, close
No I'm sorry they do not. You might try plumbing supply house in your area.
Aug 05, 2009 | Home
Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
Modern toilet cisterns without overflowprovision
Most modern flush units have built in overflow protection, if the water level rises above the flush device then water runs into the toilet itself rather than out of the overflow pipe to the outside as in older toilets.
You could always check by taking the top off the cistern and push down the float device with your finger to see what happens!
hope this helps
Mar 30, 2009 | Facebook Social Network
Maybe I'm an idiot but I don't know how to get the top off of my
The cistern lid is held down by the chrome assembly (which includes the two buttons that you press to make the toilet flush) sticking up in the middle of the lid. You need to unscrew that (anticlockwise) to be able to lift the lid off, to get to the inlet valve, etc.
If the water is running in very slowly, chances are high that the small screen filter under the inlet valve is partially blocked. Working inside the cistern, you need to unscrew the inlet valve assembly (noting the order in which the various parts come out!), then unscrew the cranked fitting just under that, to get the screen/filter.
Dec 27, 2008 | Duravit 0910100005 Happy D Toilet Cistern ...
Home Logo
95 people viewed this question
Top Geberit Home Experts
john h
Tom Chichester
Are you a Geberit Home Expert? Answer questions, earn points and help others
