Question about Refrigerators
Samsung Iceworld 380 not getting cold enough
The Samsung Iceworld 380 is an over-under fridge freezer. I can usually hear the compressor running (but not always) and it gets very hot! but only occasionally hear the freezer fan running. Temp controls are both on coldest but it just doesn't get very cold -some ice melts in the freezer). Grateful for advice please.
  • 1 more comment
  • Rich Nov 07, 2012
    1. I don't feel air in either fridge or freezer2. There is an occasional very loud crack comes form the unit when it is working! BTW, the freezer is at the top and the freezer fan seems to ony run feebly when it does run so I suspect that at least part of the problem lies there. Problem is, I can't seem to access the fan as the back of the unit seems to be permanently locked in place.
  • Richard Roth
    Richard Roth Nov 08, 2012
    Hmmmm....... that's not good. Let me see what I can find out for that model and get back to you. If you don't here from me, please post back here to make sure I didn't forget you. Thanks!
  • javase
    javase Dec 03, 2012
    I have the service manuals for this refrigerator the SR-38NMB. my email is javase@live.com . Anyone who wants the manual please send me an email and i will send you the files.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Check the compressor, condenser coils and fan on the back of the unit for lint and dirt buildup. It needs to be clean to cool properly.
Posted on Nov 07, 2012
  • Rich Nov 08, 2012
    Thank you indeed Richard. Problem is I can't seem to get at the coils as the back is plain sheet steel with no obvious way to remove (no screws etc) to access the coils and fan..
  • Rich Nov 08, 2012
    Thanks again Richard BTW, the model number is SR-38NMB
    New Friend:
HERE IS THE SERVICE MANUAL FOR THIS REFRIGERATOR.
I UPLOADED FOR YOU! ENjoy and good luck with fixing!!! :D
http://rapidshare.com/files/3182384492/Service_Manual_for_SAMSUNG_SR-38NMB.zip
Posted on Dec 03, 2012
  • Rich Dec 03, 2012
    Thanks guys! I found the problem was the switch for the fan on the freezer door. Freezer had thawed during a power cut and gunge had got into the switch. Not available locally but I managed to get it workng again by banging it on worktop a few times. Been working fine for 2 weeks now; thanks again! ;-)
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
  • 2670 Answers
SOURCE: fridge & freezer are cooling on bottom but not
when you open the freezer door do you hear the fan blowing?sounds like the air isn't moving,there's also a damper on the fridge side,the door opens to let the cold air in and then closes,make sure the door is opening,you can take the cover off and put an ice cube on the twirled up metal part to close it and put your hand on it to open it to see if it's working
Posted on Mar 22, 2010
mreid542
  • 166 Answers
SOURCE: freezer works fine, fridge cool not cold.
if the freezer is freezing and the fan working in the freezer and the fan at the compressor is working and you have no frost build up on the back wall of the freezer caused from a defrost problem -then turn your controls back to the middle. one of the controls is a thermostat control and the other control is merely an air diverter from the freezer to the refrigerator. if you close this diverter down too much (by putting it on 9)it will leave most of the air in the freezer.
bottom line if the freezer is working properly and freezing good all the time then the refrigerator should be ok as well unless you have diverted most air to the freezer. allow 24 hours after you have changed the settings.
you can feel air blowing in the back of the refrigerator at the top next to the freezer and can adjust the diverter control and feel the difference it makes. most of the time the control you use is labeled freezer and if you put both controls on 9 then your freezer will be the coldest but the refrigerator won't get as much air. the thermostat control can be left at 5 or higher (this is the control that turns the refrigerator off) but leave the other control at 5
if this doesn't work you have probably got problems with your freezer also and may not know it yet.
Posted on May 27, 2010
heatman101
  • 43501 Answers
SOURCE: fridge/freezer not getting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
caroldon
  • 17130 Answers
SOURCE: Fridge and freezer doesnt seem cold enough. Things
Please check the timer the thermostat and the heater for the auto defrosting to work. Switch off the fridge and after all the frost has gone off switch on to see if the sooling returns . If so you can be sure that the timerr does not work and so reduces cooling on frosting. If there is still no cooling then you will need to check onthe compressor and the gas pressure. Get help to confirm and take an estimate before attempting, get an warranty assurance for work. Hope you try out and see first.Good day
Posted on Aug 10, 2010
Samsung rb2055sl running warm 55 degrees in refrigerator and 70 degrees in freezer fan is working no ice, way to warm
Is there a clicking noise? Feel the compressor to see if too hot to keep your hand on top. Look ate the frost pattern in rear of the freezer compartment and tell me the results. Several things could be causing the compressor to get hot and not run. Freon leak is one thing that could happen and defective start relay, overload and run capacitor is another. You could also have a defective cooling fan under fridge or inside the freezer compartment
APPLIANCE 911
Sep 18, 2016 | Samsung Refrigerators
My Samsung French Door, Bottom Freezer Model RFG297AARS was leaking into the refrigerator & pooling under the deli drawer.
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Apr 05, 2015 | Samsung RFG297AARS Bottom Freezer French...
I have a Samsung french door fridge.
Apr 02, 2015 | Samsung RFG297AAWP Side by Side Bottom...
My KTM3900WB fridge/freezer is not freezing and cooling in the fridge. The light goes and can hear the motor is running.
You are either low on freon refrigerant, or your compressor is frozen (usually due to low freon) or your compressor is bad. the motor will cycle on and off even though the compressor is not working. the refrigerator away from the wall and look compressor will be a nerf football sizedand usually black cylinder. It could be very hot or cold/frozen. can also unplug the refrigerator leave it for a few hours and plug it back in if it work you are low on freon. You need a repairman
Jan 04, 2015 | Refrigerators
Samsung RS275. Water pooling under bottom drawer and freezing. What doesn't freeze, leaks through the door to the kitchen floor. What is happening?
Jun 26, 2014 | Samsung RS275AC Refrigerator
Samsung rf 197 water collecting under crispers fridge has no ice maker or drinking water supply
May 13, 2014 | Samsung Refrigerators
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
Door frame is always hot on freexer side
Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fridge is not cold
Side by side cooling units usually have 2 compressors, one for the freezer and one for the refrigerator. The refrigerator compressor may be bad, or not pulling enough power, or there may have been a leak in the tubing that the compressor uses to cool the unit with. To diagnose the problem, be aware of the noises the unit makes, and check to make sure it is a 2 compressor unit. If you only hear one compressor running then your compressor is bad, if you hear one running too often, then your tubing is bad, if the back of the refrigerator side is warm but the inside is not cooling down, then the compressor is not drawing enough power. Keep in mind that the radiant heat from the operational (presumably) freezer side may cause the refrigerator side to appear warm. (usually there is a type of wire backing with tubes running along it, these tubes should be mildly warm.)
Jun 15, 2009 | Samsung RM255LASH Side by Side...
Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Feb 28, 2008 | Refrigerators
Refrigerators Logo
256 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
