Question about Dymo LetraTAG Thermal Label Printer
I need to get a new 7.4v 650mAh battery and 12v 0.5a charger
Where can i get some new battery and a charger a label printer
Will my 240v charger work on 110v
Can't say for certain, but there are specific 110V and 220V versions of DCB101.
None are labelled 90-220VAC as would be normal for universal voltage equipment.
If you operate 110V equipment on 220V then you will most likely damage it with overvoltage.
If you operate 220V equipment on 110V then you will most likely damage it in over current or have it simply not work.
It is possible that the charger is universal, just not labelled as such.
Send DeWalt an email.
Mar 29, 2015 | Dewalt 12v Max - 20v Max Li-ion Battery...
I'm trying to find the correct battery pack for a Commtel com 214 scanner.Unit says 12v dc.??
The 12vdc refers to the charger you need,
The battrey is a rechargeable internal battery and you just need to find a 12v charger,
ebay "commrel 214 scanner charger" to buy it
if you do need a new battery the model number is bp-120
here is a link to pictures of the battery and EVERYTHING you need to know about the scanner
http://radiopics.com/Commtel/Commtel_COM214.htm
Dec 26, 2014 | Office Equipment & Supplies
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
My battery has discharged. I bought a new charger, but it seems to not carge the battery. Any actions or is a new battery needed?
I took my totally discharged batteries into an auto supply store and they left them on their charger overnight. There was no cost for that service and the batteries came back to life and have lasted an additional 6 months. I just replaced them with 12V 15Ah batteries and am getting much better performance now. The total cost for the new batteries was about $70, including delivery.
Aug 12, 2010 | Pride Go Chair Travel Power Chair
I have a 12V Peg Perego battery charger. I think
yep check it with a multimeter and it should show between 12-14.6 volts
May 08, 2010 | Peg Perego 12 Volt Rechargeable Battery
Low Battery
Your battery may be losing it's ability to hold the charge or your charger may be fully replacing the charge in the battery. Personally, I suspect the battery.
Don
Jan 13, 2010 | Brady TLS2200 Thermal Label Printer
Batterys dont keep there charge i think the batterys need to be replaced
before you dump those batteries, check the charger. If the battery when charged runs the tool but dies out quickly then you are probably right. If the battery never seems to be charged at all, then it may be the charger.
Dec 10, 2009 | Hitachi DS14DVF3 14.4 Volt Ni Cad 3/8 Inch...
How to fix or repair a panasonic 12v cordless
it realy depends on what kind of charger it is, if it has a coil or a switch mode charger, switch mode chargers have ic's in them and changing them or even getting them may be very hard, if its a coil type check output on coil as its likley to be that they have a built in thermal cut out fitted witch burns out, if they get over heated,,,
Dec 06, 2009 | Cameras
How 2 charge a kodak with rechargable batteries!!!
get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
May 02, 2009 | Kodak EasyShare C613 Digital Camera
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Dymo LetraTAG Thermal Label Printer Logo
79 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
