Question about LG Televison & Video
Screen goes into power saving mode
My son plays oblivion on the PC. After half hour or so the screen shows power saving mode and he has to re boot the computer. Is there a fix to this problem.
    Genius:
  • LG Master
  • 2,432 Answers
Turn off in the settings the power saving mode.
Posted on Nov 06, 2012
BoiseLCD
  • 63 Answers
SOURCE: insignia ns lcd37hd 09 picture no sound
bad Main board could cause this too. Unplug the three wires from the PWS to the mainbd and try it.
Posted on Apr 23, 2010
Th3_uN1Qu3
  • 47 Answers
SOURCE: Envision L19W761 LCD TV - VGA mode failure.
The resolution or refresh rate of the computer is not compatible with the TV. Before the computer starts loading Windows, start tapping F8 and select "Enable VGA Mode" from the menu that appears, this will set your computer to a very low resolution (640x480). I believe the option is actually called "Enable low resolution video" on Vista, it's VGA mode in XP. Now you should get a picture on the TV, work your way up from there.
Posted on Jun 26, 2009
  • 8909 Answers
SOURCE: when the computer is turned on, the monitor shows
Go to Control panel, select Power Options and turn it off.
Hope that helps.
Posted on Jan 25, 2011
SOURCE: Philips 52'' LCD HDTV. Has PC Input Issue.
Hello Terry,
I have the exact same problem that you described. I have tried 3 different HDMI cables. I connected my laptop to another LCD TV and didn't have the issue with that TV. It seems to be something related to the Phillips TV but I am still figuring this out.
Have you solved the issue with the HDMI to HDMI cable from the PC to the TV? My TV is the exact same as yours.
Greg
Posted on Feb 11, 2011
  • 3 Answers
SOURCE: TV PC SCREEN MODE BLANK
In settings on your computer screen resolution try giving computer a t,v, color profile. I had a similar problem recently that was solved by adding t,v. profile. #1 rite click blank area on computer screen .
#2 select properties or personalize #3 select settings or display then select advanced or add profile, this should enable you to add t,v, screen profile to display settings .hope this helps
Posted on Jun 17, 2012
Toshiba Satellite not Booting (No post Screen)
you can't boot on safe mode under F8 function key?
Mar 30, 2014 | Computers & Internet
Hi ,My dell screen goes to sleep mode after a long wait of not being used, say an hour, ..............but the pc sleep is not set ? The message comes up to move mouse ,or press any key ,but this does not...
please check your monitor settings may be sleep time is defined there. secondly check your system sleep time again. and also check window power saving mode. may be your system goes to power saving mode.
If you like this rate me kindly
Oct 12, 2010 | Dell E153FP 15" LCD Monitor
Have hp pavilion a340n that won't start, screen says "WARNING" PC entering power saving mode and then goes blank. the computer never boots up.
hi mylesj880,
Press del. or f8 to boot to Bios there should be an option for you to remove power saving mode. If none then you probably need to update the bios be careful when updating bioses.
Hope it helps. Feel free to ask
Thx
Banaple
Sep 02, 2010 | Computers & Internet
When i apply power to my PC, it goes right into power save mode.
At boot up press F8 and boot in Safe Mode. Once booted then go to Start->Control Panel->Power Options. Here you will be able to set it up correctly to not go into power save mode immediately. Save and reboot - normally this time.
HAPPY HOLIDAYS
Dec 25, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
I have sound but no video i have plugged every thing correctly
If there is a switch on your AV cable make sure it's switched over to whatever mode you are using. Sometimes if it's half-way I get no picture.
Jul 22, 2009 | Microsoft Xbox 360 Console
LG LCD monitor goes in power saving mode
That means theres no signal coming from the PC. either the PC is not booting up or the VGA coard is faulty.
Nov 25, 2008 | LG L1915S 19" LCD Monitor
Inspiron 530S Power Save Mode Loop
First you need to make sure that there are no other removable devices plug on the system, like usb, external hard drives, then if that will work try to go to the bios, press f2 when you see the dell logo, and go to the system setup, go to the boot device configuration and make sure that removable device is not the first boot device, if it is the first one choose hard disk and then second boot device ad cd rom/dvd rom and then disable the 3rd boot and the fourth boot device. Make sure to save the changes. And restart the system again. Once the computer is back and running try to go to support.dell.com and check the bios, download if there is a bios update for the system.
Oct 30, 2008 | Computers & Internet
Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Oct 29, 2008 | ViewSonic VE155b 15" LCD Monitor
Flatron L1719S
I think your monitor is unstable. Is it showing power saving when you boot your PC? Does it show something when the Windows XP splash appears?
Jun 05, 2007 | LG Flatron L1750S 17" LCD Monitor
Televison & Video Logo
572 people viewed this question
