SOURCE: 1998 mitsubishi idle problems
it could be something simple as a wire or lead off under the bonnet or vacuum hose even a vacuum switch if all else fails get a free quote
SOURCE: idle is too low, car dies, engine runs fine
An IAC (idle air control) motor is designed to adjust the engine idle RPM speed by opening and closing an air bypass passage inside the throttle body. The car computer or ECM (electronic control module) receives information from various sensors and will output signals to adjust the IAC motor in or out to adjust engine idle speed by controlling engine idle air.
An IAC motor is highly susceptible to carbon and coking build up; if an IAC goes too long without cleaning it can cause stalling and poor idle quality. Some cars are designed with a large vacuum transfer hose that connects the intake manifold to the IAC (idle air control) motor. If a broken or dilapidated these vacuum lines can cause the engine to lose vacuum which will allow the engine to run rough and die.
Inspect all engine and accessory vacuum lines to look for missing, torn or dilapidated lines and replace as needed. To check the IAC motor remove the unit, with the wires connected turn the key to the "on" position without starting the engine, the IAC should move in or out.
If the IAC motor does nothing it has probably failed, replace it with a new unit and recheck system. Note: while the IAC motor is removed clean (use aerosol carburetor cleaner) the passages the IAC uses to control idle air speed.
Good luck and hope this helps
SOURCE: 2002 impala 3.8L 180,000kms. Having
it is possibly the throttle position sensor(tps) malfunctioning. basically the computer or "brain" of the car thinks the throttle is in a different position than it really is and automatically makes adjustments to fuel, air ect.... based on these false readings from the sensor thus causing the engine to react a little different when you expect to have power.
SOURCE: the car won't start; lights,
Check the starter and the starter relay or fuse. A client of mines car was doing the same thing, it ended up being two issues, the starter not working anymore, and a relay that was bad. If I am not mistaken everything should be labeled in the fuse box under the hood and will tell you where the fuse/ relay is for your vehicle
SOURCE: 2002 Dodge Neon, approx 99,000
Its the TCM- Replace the Transmission Control Module. WITH THE DRBIII PERFORM QUICK LEARN AND REPROGRAM PINION FACTOR.
The transmission Control Module (TCM) is located behind the passenger fender and is fastened to the frame rail forward of the suspension. Here is a picture of it...
P1537
Intake Manifold Runner Control Stuck Open
P1504
Intake Air Control circuit malfunction
P1506
Idle Air Control Over Speed Error
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0743 Torque Converter Clutch Circuit Electrical
I hate to hear you are havine so much trouble. These are a basic descrition of each of the codes.
If each of these codes are active, i would imagine you windstar isn
Did you get a code from the the vehicle? ...and if so...what code did you get? Thank You
