Question about Lexmark X73 All-In-One InkJet Printer
CLOGGED CARTRIDGE on lexmark 73 I wish to clean the heads my self. how?
    Scholar:
  • 37 Answers
Sometimes the ink cartridges can get blocked with dry ink especially if it's been a while since it was used. I used to have a canon printer and i refilled my own carts many times. If I left them out of the printer without plastic wrap on them for a while they wouldn't work. If you take your cartridges out and blot the inkjets underneath with a damp paper towel it might help. Don't let the colour inks mix though so just wipe them in one direction so the colours don't cross. Blot with dry paper after this till the bottom of the cartridge is dry and try it in your printer. If my carts were really bad I would fold a paper towel several times and wet it, then sit it on a small flat plate such as a saucer, and just sit the cartridge on the towel so all the jets on the bottom touched it. Leave it sit there for a couple of minutes and the ink will blot out onto the paper. If you get no ink on the paper you know you need a refill or a new one. Can also leave it sitting longer if no ink to see if it gets better. Take the cart off the wet paper and just blot it several times onto a folded dry piece of paper towel to dry it, but don't wipe it sideways or the colours will mix if it's a multicolour cart.. Also, please make sure you NEVER EVER touch the gold contact plate on the side of the cartridge with your fingers as it might not work any more if you do that. You can clean ink off the gold contact the same way with a damp paper towel, but if you have got some fingerprints on there an alchohol swab might be better to get the grease from your fingers off the contacts.
Posted on Jul 12, 2009
My printer only prints magenta\
A color or photo cartridge is either low, clogged or has run out of one of the basic colors it mixes together to create the colors in your images. The printer cannot print correctly if it lacks one of the basic colors, even if it still contains some of the other colors. The cartridge may also be clogged. The cartridge must be replaced
This may help
You can try to clean the printer head manually. To clean the printer head, remove the ink cartridge from the printer. Moisten a cotton swab by dipping it in hot water or isopropyl alcohol, and then gently wipe the printer head. Do this repeatedly until it softens the dried ink.
For models where the printer head is located in the printer, you can put 7 to 10 drops of isopropyl alcohol in the ink receptacle where the ink flows from the cartridge to the head. Turn the printer to self-cleaning mode. You can also leave it for a few hours or overnight before repeating the self-cleaning mode.
If the print head is located in the cartridge, soak the print head in hot water and let it soak overnight. Dry the print head part using a paper towel and switch it to self-cleaning mode.
If the hot water soak does not work, place the cartridge printer head in isopropyl alcohol and let it soak overnight. Wipe off the soaked area and dry it carefully using a damp paper towel. Turn the printer to self-cleaning mode to remove any dried ink.
For more Help Source... Can You Fix Dry Ink Cartridge eHow
Thanks,
HP Phone Number
Jun 25, 2014 | HP Officejet Pro L7680 All-In-One InkJet...
Why isn't my lexmark x6570 printing in color even though there's still color ink in the cartridge?
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Sep 01, 2011 | Lexmark X6570 InkJet Printer
Problem with printhead please consult user guide
Use the printer's utility program to self-clean the printer. This process may need to be repeated as many as 5 to 10 times. Often this will resolve the problem.
Turn the printer off, preferably overnight, if the self-cleaning utility has not worked. The ink may need to soften before the self-cleaning utility will be successful. Turn the printer on and try the self-cleaning utility again several times.
Determine from the owner's manual where the print head is located. Epson printers, for example, are usually in the printer. Many other brands place the print head in the cartridge.
Remove the cartridge. For models where the print head is in the printer, drop seven to 10 drops of isopropyl alcohol (rubbing alcohol) down the ink receptacle area. This is the hole where the ink flows into the head from the cartridge. Run a few self-cleaning utilities. If necessary, allow to sit a few hours or overnight and repeat the self-cleaning utility.
Soak the cartridge print head in hot water if the print head is in the cartridge. Allow to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
Place the cartridge print head in isopropyl alcohol if the hot water soak did not unclog the print head. Leave the print head covered in alcohol overnight. Use a damp paper towel to wipe off the print head area. Dry carefully. Try the self-cleaning utility again.
Purchase a new cartridge if the alcohol soak did not unclog the print head in the cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the print head.
Mar 01, 2011 | Office Equipment & Supplies
Some of the ink-jets that shoot the ink onto the paper are clogged. Use the Lexmark software for the printer to run a few "print-head-cleaning" cycles, to try to unclog it. How do I find...
You can try to clean the head manually with a cloth damoened with warm water. Wipe it across the jets a few times then run a cleaning cycle. By the way, you should use plastic gloves as the ink won't wash off your hands. If this doesn't fix the printing, then you'll need a new cartridge as the jets are probably clogged and stuck.
Jan 07, 2011 | Lexmark X4650 InkJet Printer
I suspect that the black printer head is clogged up, is that seomething that I can repair myself?
Hello
Yes you can repair by trying the following steps:-
Hope it helps, if so do rate the solution
good luck
Dec 27, 2010 | Brother MFC 7300C InkJet Printer
I have lexmark z600 model but when i insert new cadridgethe printout is coming blank and i thought the printhead is not functioning,
1. I found it much cheaper just to by a new Lexmark Z600 printer than buy refills. The printer only cost $30 and the refill cartridge cost $30, go figure. 2. If you are buying recycled or recycling the cartridge yourself the print head may not be working or may be clogged. The print head is located on the bottom of the cartridge. Clean the cartridge bottom with alcohol and a clean Q-Tip.
Jun 28, 2010 | Lexmark Z600 InkJet Printer
My printer won't print anything - only blank pages. However, both ink cartridges have ink. Please help!
If the self-cleaning cycle does not solve the problem, try turning the printer off overnight to allow the ink to soften. Turn the printer on the next day and try printing a test pattern to see whether the problem has either disappeared or become less noticeable. This ink-saving procedure can work effectively because sometimes the dried ink on the print head needs time to soften before the printer head can be cleaned completely. Try running the self-cleaning utility again one or more times.
Steps for Manually Cleaning the Printer Head
If the overnight cleaning still does not work, there may be a layer of thick ink that is blocking the holes of the printer's head. The next option is to manually clean the printer head. Follow these steps:
* Determine from the owner's manual where the print head is located.
* Remove the ink cartridge from your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. NOTE: Be careful, especially if you use isopropyl alcohol to clean your print heads: Some printers use rubber gaskets, and if you get isopropyl alcohol on the gaskets it could dry them out.
* For models where the print head is in the printer, drop 7 to 10 drops of isopropyl alcohol (91% denatured isopropyl alcohol - not 'rubbing' alcohol) down the ink receptacle area where the ink actually flows from the cartridge into the head. Run a few self-cleaning utilities. If possible, allow the printer to sit a few hours or overnight and repeat the self-cleaning utility.
* If the print head is in the cartridge, soak the cartridge print head in hot water. Allow it to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
* If the hot water soak did not unclog the print head, place the cartridge printer head in isopropyl alcohol and allow it to soak overnight. Use a damp paper towel to wipe off the print head area and dry carefully. Try the self-cleaning utility again.
* If the alcohol soak did not unclog the print head in the cartridge you may need to purchase a new cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the printer head.
Jun 09, 2010 | HP DeskJet 5150 InkJet Printer
Lexmark 6570 lines o type missing and smudging. Cleaned heads, done all the normal stuff and cleaned rollers as far as possible.
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Aug 20, 2009 | Lexmark X6570 InkJet Printer
Document color differs from screen color- lexmark z617
Sounds like the print head is clogged. Some models have the head in the cartridge, others don't. Those that do, a cartridge replacement will help, others need cleaning manually. Also, a software head cleaning may be all it needs.
Jan 01, 2009 | Lexmark Z617 InkJet Photo Printer
Lexmark X73 All-In-One InkJet Printer Logo
125 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
