Question about Dell Computers & Internet
Dell inspiration 8300 does not detect sata drive
Computer shows that no drive is installed
  • Dell Master
  • 998 Answers
Your hard drive is probably defective.
Posted on May 01, 2014
mansnes
  • 50 Answers
SOURCE: drive 0 not found;serial ATA,SATA-0
are you SURE you connected up the power connector in addition to the SATA connector? If so, you may have hozed your drive.
Posted on Feb 06, 2008
Sunil Panem
  • 80 Answers
SOURCE: help my second hard drive dont show up
Hi
Make sure it is connected properly.
Then go to Disk Management by typing "diskmgmt.msc" in the Run window.
Then check in Disk Management if there is any unassigned or any uninitialised partition there.
If you find one, right click on it and then select either "Format" or "Initialise".
Posted on Mar 05, 2008
Joed911
  • 4338 Answers
SOURCE: install sata drives on abit av8 motherboard (vista home)
Right click on my computer, click on manage. Then on Disk Management. See if the drive shows up . If it does you can format it by right clicking and select format.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Sep 28, 2008
bharatgourab
  • 52 Answers
SOURCE: windows xp won't recognize my new sata hard drive
  • Right click on my computer
  • click- manage
  • a window would open with a menu on the left
  • click
  • storage>disk management
  • that would show all your drivesboth formatted and non-formatted on the right
  • if you can see your hard drive there, then its fine, otherwise tell me I have the alternative.
Posted on Apr 01, 2009
  • 225 Answers
SOURCE: my computer shows to setup array and does not detect one hard disk
Please try to system reformat/reinstall OS to your HDD under SATA connection. then kindly check the jumper setting of HDD under IDE connection which I suggest to place it at Master while the SATA HDD will be automatically recognized as Slave by your computer. best regards
Posted on May 16, 2009
Can't install windows on FSB 800 motherboard its showing no hard disk installed in your computer but showing in the bios kindly help
If you are installing XP on a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 18, 2013 | Computers & Internet
Sata port 2 does not work
Remember always downwards compatible as a rule of thumb. You may not be able to connect a SATA 3 drive into a SATA 2 port.
Ports 2 and 3 are SATA 2.
http://support.dell.com/support/edocs/systems/xps8300/en/sm/techov.htm#wp1268982
GL
Nov 12, 2012 | Dell Xps 8300 Desktop Computer (Intel CORE...
Don't know how to connect hard drive to motherboad?
find in motherboard sata 1,sata 2 or" fdd socket.
May 30, 2012 | Dell Xps 8300 Desktop Computer
My computer wont boot up
check your cables,your hard drive is not detecting
May 09, 2012 | Dell Inspiron 530 Desktop Computer...
Hi i purchased a dell 1318 laptop from china suddenly i cont install xp it,s support only win7 while trying to install xp it will display the error message like this
Your laptop may have a SATA hard drive.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Nov 13, 2011 | Dell Inspiron 1318 Laptop Computer PC...
Windows wont start. dont know how it happened.
press F2 to go to the system setup, then press arrow down to highlight Standard CMOS feature, then press enter. Verify if the hard drive is detected, mostly it is installed in SATA 0 and you should see like a serial no of the Hard drive. If the hard drive is not detected, you might need to reseat the cables of the hard drive inside the computer. Make sure that all the cables at the back of computer is unplugged to be safe. After you reseat the hard drive cable, plug cables at the back of the computer then turn on computer and press F2, verify if the hard drive is detected, if still not, try to swap the connection of the hard drive and the dvd drive of the computer. Plug back the cables and turn on comp and press again F2, this time the the dvd drive should be on the SATA 0 and hard drive should be on the oter SATA port. If the hard drive is still not detected, you need to replace the hard drive, but if the hard drive is detected on the other SATA port and the dvd drive is not detected on SATA 0 then you need to replace the mother board.
Mar 16, 2010 | Dell Inspiron 530 Desktop Computer...
How to install sata hard drive on dell power edge
You have to "FDisk" or "Partition" the Drive before Windows will see it.
XP - Goto: Control Panel | Administrative Tools | Computer Management | Disk Management
Vista/Win7 - Goto: Control Panel | System and Security | Administrative Tools | Computer Management | Disk Management
You will see hopefully both Drives... Highlight the New One... Create a New Partion by Right Clicking or use the Pull Downs. It will ask size etc... use the defaults.
Next Format the Drive - Select the Drive again...Right Click Format using Quick Format to save time and you should be set.
Jan 02, 2010 | Dell PowerEdge 1600...
Dimension 8300 will not start.
Have you tried settings defaults in bios, and making sure the hard drive is plugged into sata0 controller on the motherboard?
Jul 16, 2008 | Dell Dimension 8300 PC Desktop
Hard drive
According to http://reviews.zdnet.co.uk/hardware/desktops/0,1000000973,10004197,00.htm this tower has Serial ATA, or SATA. Just to confirm, you can easily pop open the case and take a look at the hard-drives. If you see a wide thin ribbon-like cable connecting to your hard-drive then you need an Ultra ATA (or just ATA or IDE) drive. It looks like this:
If a thinner red cable connects to your drive, then that is SATA. It looks like this:
May 13, 2008 | Dell Dimension 8300 PC Desktop
Computers & Internet Logo
13 people viewed this question
Alun Cox
