Question about Craftsman 6" Bench Grinder with Lamp
The replacement capacitor for my bench grinder 319.19062 is different from the original capacitor.
With relation to my bench grinder 319.19062. The old capacitor I am replacing had one red, and one black wire. I noted where each was connected to. The replacement capacitor has two GREY wires coming out. How do I know which wire goes where? My question relates more specifically to the new capacitor. The part number for the new capacitor is #3AA03301 Connecting the red wire and the black wire is self explanatory. Having two grey wires gives no indication of which wire goes to where the red and black wires were connected previously.
3 Suggested Answers
SOURCE: older sears bench grinder wont run 1/3 hp model 397 19581
Can you get a replacement? If not, we could probably figure out some suitable substitute.
Charlie
Posted on May 31, 2009
torqueman200
  • 12 Answers
I know this is an old post, but maybe it will help others looking for information.
I have the Craftsman 1/3-HP grinder models: 397.19580 & 397.19581.
They are Split-Phase single voltage (115 V), and use a Klixon start-up current style relay - 2CR14-224.
The relay is normally open. When the large starting current in the main/run winding circuit is sensed by the the relay coil (term 3 & 4) which is in series with the main winding, the relay contacts close (term 2 & 4).
The one end of the start-up winding is connected to the main coil's BLK wire in the coil pack.
When the relay contacts close the start-up winding is energized. The start-up coil is used to provide a boost to over-come the resting inertia of the rotor.
Once the rotor reaches between 65% - 75% of operating speed, the current through the main winding circuit is reduced to the point that the relay coil cannot over come the return-springs force, acting on the relay contact arm. With the contacts open, the start-up winding is no longer energized.
This should take about 2-3 seconds, if the relay malfunctions, the high current through the start-up windings (thin wires) may be damaged.
Here is a diagram I have made.
Klixon 2CR relays are no longer available.
You may find a suitable replacement here:
http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_
Posted on Feb 24, 2016
I need a capacitor #1343835 which has been discontinued. What replacement part will do the same job<
take the capacitor and the motor details (from the attached plate on the grinder ) to a motor rewind shop and they will have a capacitor suitable for the job
the terminals may be different so get terminals as well from them to put on the wires of the motor
Oct 11, 2015 | Delta GR150 6Inch Bench Grinder with Lamp
Replace missing switch on bench grinder
2 wires are not needed to use they are the wires of an supression capacitor on the switch then there are 2 wires from your power cable and 2 that goes to your motor that 4 you only you have to use you can also connect the 2 wires from the s-capacitor with te wires on the motor together thats is how its also correct, (but best is to remove it because its only for suppression for FM ukw radio signals and everybody has DAB+ and the change to have short-circuit is reduced.
Sep 30, 2015 | Bench Grinders
Will not start
The centrifugal switch inside has gotten dirty, or else the start capacitor is disconnected or faulty. It's about time to open that grinder up and examine the centrifugal switch. If it's working OK, then examine the capacitor connections. If they look OK, replace the capacitor.
Apr 25, 2014 | Grinders
Who makes Popular Mechanics Tools?
What information can you recover? The MFD rating is important. If you can take a picture of the wrecked one that could help. The capacitor will either be a run capacitor or a starting capacitor and the difference is important. The packaging of the capacitor is often a clue. Usually starting caps are in black phenolic tubes. Usually run capacitors are in metal cases. If the rating is 15MFD or less, the capacitor is likely a run capacitor.
Jun 04, 2012 | Grinders
I HAVE A CTT BENCH GRINDER MODEL CT-8B THAT WONTRUN
A lot of the bench grinders have a run capacitor in the base. These occasionally fail and unit will just hum when powered.
Mar 18, 2012 | Grinders
I have an old Craftsman bench grinder that I got at an auction. I need a capacitor and the one on it has no markings. It is a 1hp model 319.19063. Sears Parts direct says that it is no longer available and...
this is a "Split-Phase"motor it uses only a run capacitor and a typical capacitance rated MFD rating will be between 80 and 290 MFD, go to www. grainger..com and they will have your part,and even if its an older unit and the model/serial/number is available take it with you & they will have a replacement capacitor available in the correct size/dimension/mfd/etc
Apr 24, 2011 | Baldor 8" 1 Hp Electric Bench Grinder
I have a 1/3 hp motor with a capacitor. There are four motor leads coming out of motor, the capacitor is mounted in the wiring box. This motor does not have a centrifugal switch, to isolate the capacitor...
I am in the process of replacing a capacitor on a Craftsman 6 in 1/3 grinder, 2.8 amp, single phase, 110v. Not sure on the centrifugal switch. model 319.190621, ser B9530. When I took the old one out the black wire from the capacitor went to the cluster of back wires (in my case 3) in the wire nut. The blue wire from the grinder went to red wire from the capacitor in a wire nut. Hope that helps you....
Maybe you can help me... the specs on the capacitor burned off when it failed. Can you tell me what the capacitor specs are on yours?
Nov 16, 2010 | Craftsman 6" Bench Grinder with Lamp
It hums but won't turn. are there brushes? what is the black canister hooked to wiring going to motor? aloha, chip
Hi Chip , have you tried !!carefully!! turning the grinding wheels whilst the grinder is powered up and humming and does this start the machine , if it does your motor start capacitor ( a cylinder/tube with 2 wires or connectors on it ) will be deffective or the leads might have became detached from it , a replacement capacitor is quite cheap but you must replace it with the exact one ( a motor start/run capacitor of the correct Mfd or uF rating typically 30 uF/Mfd and at the correct voltage 110/220V )
if this dosent fix your problem most likely your motor start windings in the motor field coils are burnt out and the grinder is uneconomical to repair .
hope this helps .
Jan 22, 2010 | Delta Shopmaster 8" Bench Grinder
Craftsman 6" Bench Grinder with Lamp Logo
319 people viewed this question
Top Craftsman Grinders Experts
Jim London
Jim London
Lawrence Oravetz
Vernon Taylor
Are you a Craftsman Grinder Expert? Answer questions, earn points and help others
