Question about Sharp AR-5316 Advanced Digital Imager Copier
How to change developer sim mode for sharp ar 5520
  • 255 Answers
SOURCE: I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Posted on Dec 01, 2009
Bubbabear64
  • 2794 Answers
SOURCE: Sharp AR-M165, maintenance led and developer replacement leds on
It's the drum thats causing the lines to happen. Youre going to have to get that replaced before you can reset the counters.
If you get light copies, then the developer should be replaced.
Posted on Sep 01, 2008
  • 153 Answers
SOURCE: Sharp AR-156 Developer light stays on.but the
in service mode
Posted on Sep 28, 2009
xptareq2000
  • 1447 Answers
SOURCE: sharp reset developer on ar-122en
I do not understand What is step by step help?
Focus me clearly.This machine setup code is: # interrupt C interrupt.
Posted on Dec 10, 2009
SOURCE: SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Posted on Jul 17, 2010
My Sharp copier cannot get out standby mode and is flashing the developer indicator.
install the developer unit , or change developer inside the unit,
and reset using Sim code 42-01
Feb 22, 2015 | Sharp Ar 5316
The Developer is standby we have refill it but is still showing
Thats easy to correct. Press the # * C * button, The machine will enter Sim mode. Then press 24 and start. look for the code to reset the developer maintenance code.
Apr 25, 2011 | Sharp AR 163 Copier
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
Feb 05, 2011 | Sharp AR-5316 Advanced Digital Imager...
Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Oct 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
F2 40 error code on Sharp 5516s copier
you must use ar-202 developer.205sd used for 5516 or 5520
May 23, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR 235, output light
You have to change the Developer in the developing unit. code is: AR271D
This procedure must be done by a copier tech.
Feb 15, 2010 | Sharp AR-235 Copier
I have changed a developer and so i want to run a sim of developer in the copier sharp ar-5316
Hello sir; This model machine not require developer to replace, it come with toner cartridge therefor no such simulation code.
Jun 11, 2009 | Sharp Office Equipment & Supplies
Ar-5132 sharp copier
H3-XX codes involve the fusing unit temperature being too low or too high.
Try resetting the error.
[C] – [INTERRUPT] – [0] – [INTERRUPT]
Type in 1 4
Hit [PRINT]
Turn power off then on if it doesn't do it automatically.
If error doesn't reset then you have other trouble
I hope you ran the developer setup and reset all of the parts counters for the items you replaced. Not setting the developer reference can cause a host of problems.
Sim 25-02 adjusts developer.
Sim 42 clears DV counter
Jun 05, 2008 | Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
184 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
