How to unblock rear window water pipe - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 05, 2012
175d2750g377 fills but will not wash. light flashes between fill and (soak and wash)
you may find that the water sensor is not working properly, pull the plug out and take the back off and look for a small 5mm pipe that goes upward, take it off and blow into it gently you should hear a click and one when you let the air out this means that the sensor is working but the tube w, here you took it from is blocked, unblock with a pipe cleaner or a metal rod its normally full of soap goo replace the pipe fit the rear panel and restart the machine eric
Jan 09, 2018 | Washing Machines
My car has a lot of condensation on the front and rear windows ,dampness has formed in the passenger foot well,what could be the cause?
Air Conditioner Drain pipe blocked . Feel behind heater on carpet is it wet ?
If you have been using your Air conditioner in humid weather it will extract even more water from the air and if the pipe is blocked it will add water to your car.
If this is the cause it takes about 30 seconds for a car repair place to lift the car up on their car jack and unblock the pipe .
Jan 05, 2017 | Cars & Trucks
My lg tromm wm2277hw keeps giving a ue error at the last spin cycle. It even occurs when the washer is completely empty so it can't be an uneven load. It drains fine beforehand but always leaves a little...
it could be that the water sensor is not resetting, take the back off remembering to unplug the machine and look for a small 5mm pipe leading upwards, take it off and blow gently into it, you will hear a click and one when you release the air, if so then the place where you took the pipe from is blocked preventing the water sensor to work properly, so unblock the pipe with a pipe cleaner or a metal rod to unblock it, replace the pipe and run the machine again eric
Jan 16, 2018 | Washing Machines
Blocked overflow on fuel tank
I don't know what vehicle/equipment you're referencing here. With that in mind, can you drill a hole or holes through the chassis just below the gas cap to allow water to escape?
Jul 28, 2017 | Moto Guzzi Motorcycles
Rear washer not working
get a pin and unblock the holes in the jet sprayer + also check if the water is going to the rear jet by removing the pipe at the back of the jet.
Dec 10, 2013 | 2004 Citroen Xsara Picasso
Washer jets not working
Step 1:
Hi Nicola
First thing to check will be making sure you hear the washer bottle motor working, when you operate the washer jets inside your car.If you can hear it, then you know that works, if it does not work, then you need to check the fuse has not blown, if it has replace the fuse with the same color fuse. Then check to see if it works. If it does not work then you need a new pump.
Step 2:
Pull of the main pipe to your jets, Then operate your washers again, There should be water coming out of the pipe.
Step 3:
If no water comes out, Pull the pipe of the washer pump on the washer bottle & operate your washers, if no water comes out, then you will need to take out the motor & check it is not blocked.
Step 4:
If the water does come out, then you need to check that pipe witch runs down to the washer motor for any kinks in the pipe, or just disconnect the pipe, try blowing through it, U should be able to blow through it easily, If not there will be a kink in the pipe, or the pipe will be blocked, so then the pipe needs to be kink free, unblocked, or a new piece of pipe installed.
Step 5:
If step 2 works, Then your jets are blocked.
Step 6:
To unblock them, Get a needle & push the needle through the whole in the jet to unblock it.
Step 7:
Do the same for all the jets, Put the pipes back on, Then operate the washers. They will work.
Step 8:
If you have any problems let me know. :)
Dec 19, 2012 | Cars & Trucks
How to unblock rear window wiper water pipe on I10
Firstly have someone operate the rear washer while you listen for motor operation at the front wheel well of the car (same side as the washer fluid reservoir).
If you can't hear the motor, then the motor is likely faulty and requires replacement.
You can operate the front washers to locate where both motors are. (under the car, beside the wheel well.)
If the motor is working but no water is coming out, then remove the rear washer jet and disconnect, then using a high pressure airline, blow backwards into the jet to clear out any blockage. If you don't have a high pressure airline with nozzle, then use something like the nylon filament from a yard brush to poke into the jet, to try and clear the blockage.
Nov 05, 2012 | Cars & Trucks
Whirlpool cam2752 - 1 in of rinse water
there can only be one answer that is that the water sensor is closing off to early that tells me that the small 5mm pipe leading upwards from the drum is partially blocked, you would need to find this pipe remove it and gently blow into it you should hear a click and one when you let the air out this tells you that the switch is working but the tube you took the pipe from is blocked with soap goo, unblock the pipe with a pipe cleaner(smokers)or a metal rod, replace the pipe and rear panel run the machine eric
Jan 20, 2018 | Whirlpool CAM2752TQ
Machine wont stop filling.
there is most probably a fault on the diaphram switch
(what this does ,, it is normaly high in the machine case and has a pipe that leads to the drum when the machine fills up water travells up the pipe it pushes air infront of it when the water is at the right level the pressure in the switch will switch of the water inlet valve stopping water intake )
there is a possability that it is blocked but unless you are compedent to do this repair would seek machine engineer
always disconnect from the main power source before opening the machine case,
if you can do it remove lid and look normally to the rear of the machine normally round , with a pipe and two wires on it , if you have a multimeter you remove the wires and using contenuity connect each wire from the multimeter to each conector terminal , you will also need to remove the pipe , **** and blow where you removed the pipe from and whilst your multimeter is connected take a reading or you may hear a sound (depending on meter type) this is the contacts making and breaking , if you get no reading then replace unit , if you get reading it is probaly blocked and will need unblocking, the blockage will lower down the pipe near the drum.
Jan 15, 2010 | Electrolux Washing Machines
Water not draining
I had similar problem and discovered a ear bud stick got stuck in the pump that is located at the rear bottom end of unit on the outlet tube
Mar 24, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
