Question about Dryers
Hoover condenser dryer is squeaking when the drum turns one way
Dryer is squeaking when it turns clockwise. Doesn't happen when it reverses to anti-clockwise
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Check the drum rollers. You can ad a drop or 2 of oil to quite them down.
Posted on Nov 05, 2012
  • 262 Answers
SOURCE: Zanussi tumble dryer
take it apart and you will see that the belt is probably find the belt broke
Posted on Dec 29, 2007
  • 56 Answers
SOURCE: My noisy hoover tumble dryer...help please!
possibly bearings gone on drum shaft
Posted on Mar 20, 2008
SOURCE: Hotpoint condenser dryer CDT00
how to connect the dryer belt to the motor is there is two pullys.
Posted on Jul 25, 2008
  • 198 Answers
SOURCE: dryer spins counter clockwise
When installing new belt the belt comes off the right side of the drum and through the idler and around the motor shaft, then up the left side
Posted on Jan 07, 2009
heatman101
  • 43501 Answers
SOURCE: i have a hotpoint Aquairus condenser dryer CTD00P
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Oct 29, 2010
Testimonial: "thank you for your advice, and help it is the heater fan thanks again.."
Hoover condenser dryer, drum is stiking, if i manually spin the drum ir will go bk in cycle
see this causes and fix it. God bless you
Not all will apply to every dryer. Check our video page for more style dryers.
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. You will need to disassemble the dryer to check these. Some dryers use rollers in both the front and rear. Check our videos for other style dryers.
Belt
The Belt should be replaced if you hear any noise coming from it or if there is any cracking, glazing, or grooves worn out. Replace the Belt along with the idler pulley.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace the glides and bearing housing if necessary. Put hand inside drum near front and push up there should be no play.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace the rear bearing when they're worn. Put hand inside drum near rear and push up there should be no play. This video walks thru another type.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermosta ts, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace the blower wheel. Many times the blower wheel is making the noise and it is commonly mistaken for the motor.
Motor
The motor may be making noise. The easy way to check is to remove the belt and turn the dryer on if it is noisy replace the motor.
Oct 02, 2012 | Dryers
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
My dryer squeaked for awhile no it hums but the drum doesn't turn
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2011 | Roper REX4634KQ Electric Dryer
Dryer is squeaking as drum turns
heatman101
Jul 27, 2011 | Dryers
Hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
May 08, 2011 | Hotpoint Dryers
I have a hotpoint Aquairus condenser dryer CTD00P and when the dryer is turned on there is a awfull load grinding noise when drum is turning front ways and also in reverse
heatman101
Oct 28, 2010 | Hotpoint Dryers
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
Nextra7 condenser dryer making squeaky noises
heatman101
tukuymhg
Feb 14, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Mar 20, 2008 | Dryers
Dryers Logo
56 people viewed this question
Top Dryers Experts
