Question about Kodak ESP C310 AllInOne InkJet Printer
Kodak esp c310 paper feed
Paper starts to feed but then kicked back and "out of paper" message shown.
  • 285 Answers
SOURCE: error code 3820
try the baack of the printer. open it up from the back
Posted on Jan 28, 2009
  • 2976 Answers
SOURCE: Paper won't feed into printer
Make sure the paper doesn't have a curve in it. Also, fan the pages to make sure they aren't sticking together. Load shiny side up. Try taking about 10 sheets out
Posted on Jun 29, 2009
  • 295 Answers
SOURCE: paper jam message on esp 7 kodak printer
open rear access door and check out if there is any tape in and around the rollers or any torn paper or any staples there.. turn printer upside down and oprn bottom p[aper tray check out if there is any paper stuck there. take power cord out of printer and again insert it back. ur printer will work fine
Posted on Jul 28, 2009
  • 8 Answers
SOURCE: i have Kodak esp 5 all in one- says I have paper
f you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below. Works for esp 7.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
Posted on Mar 05, 2010
  • 64 Answers
SOURCE: got a paper jam how do I take off the back to fix
Log onto www.kodak.com/go/itg and follow the online steps to either resolve the issue or tell you to contact Kodak for replacement.
Posted on May 13, 2010
Testimonial: "Was helpfull"
ESP Office 2150 all-in-one
Shows paper jam. no paper in machine
Apr 11, 2016 | Kodak Office Equipment & Supplies
Paper wont feed
Paper not feeding in all-in-one printer - Kodak
support.en.kodak.com/.../paper-not-feeding-in-all-in-one-printer
KodakPaper not feeding in all-in-one printer. Published 10/19/2010 04:38 PM ' Updated 09/23/2014 01:38 PM ' Answer ID 19640. What should I do if the paper does ...
Basic troubleshooting - Kodak
resources.kodak.com/support/shtml/en/manuals/.../urg01238c11s1.shtml
KODAK ESP Office 2100 Series All-in-One Printers - Extended User Guide ... If you experience an error with your printer, restarting your printer will ... For wireless connectivity issues, go to www.kodak.com/go/inkjetnetworking. Carriage ... If thepaper is not stacking properly in the output tray, remove the pages as they exit.
[Solved] Kodak ESP Printer Paper Jam - YouTube
? 20:50
https://www.youtube.com/watch?v=jpkitdHmkuc
Aug 15, 2014 - Uploaded by Sabretooth Barnacle
This is probably a common issue amongst all Kodak Printers. ...thanks for the video, these same instructions worked on theKodak 2150! ... What do you thinkthe pproblem is, Kodak offered me another one for ... the printer realises they don't match so rejects the paper until you feed in the size it's expecting.
Paper won't feed on kodak 2150 printer - Fixya
Dec 21, 2015 | Kodak ESP Office 2150 All-in-One Inkjet...
My printer is showing an error code 3524 (paper jam) yet there is no paper jammed. It says press OK to continue, but just instantly returns to the same message. It does seem that the cartridge head is
had the same problem it only happened when i turned the ac off . humidity i guess. i started buying paper made for a inkjet cost a little more but it seems like it helping.
Oct 24, 2014 | Kodak ESP C310 AllInOne InkJet Printer
Paper jaming
Here is what I did to fix the aggravation and annoyance this particular printer caused me. I let my son take it to the back yard and smash it with a bat. Then he took it to the dump.
I hope this helps.
Jun 06, 2014 | Kodak ESP C310 AllInOne InkJet Printer
My kodak printer esp 3.2 is giving me an error code 3533 paper jam but there is no paper jammed and when i put new paper in it, it still wont print and keeps giving me the same error code 3533
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Sep 12, 2013 | Kodak ESP C310 AllInOne InkJet Printer
I HAVE A KODAK 3 IN1 ESP C310 AND WHEN I GO TO PRINT ANYTHING IT PULLS IT TO ONE SIDE BUT THERE IS NO PAPER STUCK AND A MESSAGE APPEARS SAYING IT IS OUT OF PAPER
I have the same problem on my printer, the same as yours, and have not come across a solution yet. Please e mail me at anthony.leftwich@sky.com with the solution if you have come across one. Many thanks
Jan 16, 2013 | Kodak ESP 3 Multifunction Printer/ Copier/...
My kodak esp c310 tells me paper jam how do i fix it
Turn the Printer on
Wait for the error message
open the printer
move the ink cartridge a little bit to the right
on the left side you have three gear wheels
move the frontmost forward to move the printer carriage it should go easy.
Close the Printer and press OK to test the printer.
If it not works move the gear wheel further and further and maybe backwards to remove stuff which block the carriage
Nov 28, 2011 | Kodak Office Equipment & Supplies
Paper jam kodak esp 5 message even though i don't see one how to unjam paper
usually paper jam is at the back of the printer for more information see your printer manuals
Jun 23, 2010 | Kodak ESP 5 Printer
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Dec 20, 2008 | Kodak ESP 5 Printer
Kodak ESP C310 AllInOne InkJet Printer Logo
185 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
