The lint filter in my 500m Hoover washing machine has broken off and is stuck down the centre pipe (where you pull it from). Any suggestions on how to get it out?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Can you see the end of it?
Posted on Nov 05, 2012
2 Suggested Answers
SOURCE: Lint Filter in Whirlpool Agitator washing Machine
I have a regular top loader and the lint filter is on the underside of the inner tub. You have to remove the inner tub to get to it. You might be able to find a service manual explaining this at appliancejunk.com.
Posted on Dec 09, 2009
How do i clean lint filter ?
Most washing machines have a lint trap that can be pulled out so you simply need to pull it out and pull the lint off of the filter and throw it away, easy as that.
If it is caked on there and wont come off, I would suggest spraying it down with a high pressure hose outside or even just soaking it in some CLR.
Aug 27, 2011 | Washing Machines
How to clean out the machine a top load 7.5 kg load hoover
Open the lid, locate the centre washing spindle/arm then undo the cap on top of the spindle (this will either unscrew or just slip out, Pull up.) inside there you will see the lint filter, wash this out and put back.
Nov 02, 2010 | Hoover HTC243 Top Load Washer
I can't find the filter location for Hoover 202M 5.5kg washing machine. Can you pls help.
The filter is in the agitator. Remove the agitator cap, and you will find it down there. The filter is pretty much useless. Even though you might get some lint in the filter, if it wasn't there the lint would go down the drain. This machine has a neutral drain feature where the lint gets pumped out with the rinse water before the bowl turns, so preventing the lint from being stirred up nd put through the clothes. Cheerts Tony.
Sep 07, 2010 | Washing Machines
Does the hoover 200m 4.4kg top loading washing machine have a lint filter if so where is it
Hi just read your posting.It should be in the center of the agitator.Pull the center out and there should be a lint bag attached to it.Unfortunately they do not stop much lint from getting on the clothes.Hope this helps and please reply if you need more help.
Jun 17, 2010 | Hoover HTC243 Top Load Washer
Hoover 500M only washes on one direction
The Brake-arm under the washer needs to be replaced it is a white plastic moulded to steel (U) shaped artical connected to an electrical solonoid with a split pin it is either cracked or the nib is broken off where it locates plastic cog on the main shaft assy.Hope this helps.
Dec 13, 2009 | Dryers
The pump on my hoover washer hnf7148 has been changed but the problem persists. Water is still in the drum and it will not drain away. The control panel when the machine stos shows the door closed with...
This particular model has a problem with the circuit board(control board,PCB) it does everything but drain, its very easy to replace and costs around £52
Jun 24, 2009 | Hoover Washing Machines
Hoover 600md washing machine lint filer
l spoke to a repairman and he told me that it is probably a soap build up from only using cold water.....he suggested using sugar soap and hot water and let it soak for a few hours and then let it finish a cycle...and surprise surprise it worked, the lint trap is now working and the smell has gone
Nov 10, 2008 | Hoover Washing Machines
Hoover750l
Please help
My Hoover 750 L Top Loader leaves a lot of fluff when I wash my dark clothes. I have been looking for a filter on it but no success. Any one have an answer please.
Sep 07, 2007 | Hoover Nextra HNF 3167 Top Load Washer
Washing Machines Logo
146 people viewed this question
Top Washing Machines Experts
