Cell Phones Logo
Ian Busta Posted on Nov 05, 2012
Watch phone n388 no power charger ok ,,both batteris seem dead think phone
3 Related Answers
Anonymous
  • Posted on Mar 01, 2008
SOURCE: Use Genuine Battery
I folded up a small piece of paper and put it in between the battery and back case.
aliasger yq
  • 219 Answers
  • Posted on Apr 09, 2010
SOURCE: My phone shuts off when I plug in the charger
check for new charger .it may be charging section fault
Anonymous
  • Posted on Sep 14, 2010
SOURCE: My lg kp500 phone has gone dead.
lg kp500 mobile phone dead plz help contect karmjeet singh 919872154717
I have a n388 watch and I'm trying to pair it with a zte zmax.
Make sure Bluetooth is on. Look in the watches manual for more instructions
2answers
DEAD. MAYBE INTERNAL BATTERY IS DEAD? DONT THINK ITS THE WALL CHARGER...WUT CAN IT BE???
Wall charger's go bad. Measure it's output with a volt-meter, to make sure it's working. I killed one watching too many dvds on the computer and overworking it.
Stupid phone and phone charger
your battery might be fully flat,now take a battery eliminitor & set it to 4.5 volts then connect - &+ terminal to the dead battery 4 the few minuts,put battery back into the cell phone connect charger do not power on the cell,if every thing is ok then charging should start.
4helpful
2answers
My Nokia 6620 is not powering on.It has in the battery and everything but it jus isnt coming on.The only time it comes on is when i plug in the charger.
Your battery seems to be absolute dead. Try a new or someone elses battery. It runs on charger means that the battery is not storing any charge and the phone gets it directly from the charger.
Jun 30, 2009 • Nokia 6620
4answers
W200i doesnt turn on or charge
I think some software problem...pls try to reset to factory default setting...
to do that press >*<<*<*
3answers
O2 Xda Exec
It appears it has something to do with the flash continuely trying to operate. When charging (Red LED blinking in quick succession) the flash can be conitnuely seen to be operating.
Doesn't fix the problem but I think this is the cause
2answers
Treo 650 won't turn on
Could be a dodgy power connection this seems to be happening a lot at the momentif you look at other threads here.
Kevan
Help!Phone does nothing!
Ok you need to replace that charger cos thats the one that is doing all the damage. Check your battery voltage if its below 3v then you need to rejuvenate it back to its original capacity. It will be ok good luck.
Battery not charging on rx3115
Be sure the charger is connected to AC power. USB charging won't work when a battery's really dead. And it may take up to 24 hours, I've read, to get it recharged.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
