Question about ASUS Eee PC 1005HA-PU1X-BK Netbook
ASUS Eee PC 100HA NETIO.SYS status:Oxc0000221 HELP
Boot manage will not allow it to start every time I try to start with the harddrive or a bootable flashdrive all I get is FILE: NETIO.SYS Status: Oxc0000221 info: windows failed to load because a required file is missing or corrupt
acdr
  • 1913 Answers
SOURCE: my asus eee pc 900 wont work
open the cpu cover then refix RAM then checl if problem still remains
then u have to reinstall reapir win xp
Posted on Dec 31, 2008
kamal1984
  • 1383 Answers
SOURCE: i have a eee asus laptop. I cannot startup the
you have to fix error on harddisk.
If you have winrecovery disk you can boot your computer with winxp recovery disk then boot computer with recovery disk then type in recovery console prompt "chkdsk /r" then pres "y"
then it fix error on harddisk.
Posted on Jul 13, 2009
  • 52 Answers
SOURCE: asus eee pc 900 /windows/system32/config/system
2 problems, your using a netbook that doesnt have an optical drive (cd/dvd) and you need a windows cd.
I dont think there is anything you can do until you call your retailer and request a copy of windows cd.
After that you can do a windows repair. Use the link below to see you options for accessing the cd once you have it.
http://www.itworld.com/windows/68069/three-ways-install-windows-7-netbook
Posted on Aug 29, 2009
Davethesnake
  • 689 Answers
SOURCE: I have a Asus eee 1005HA running Windows XP. When
Ring this number: 0870-120-8340. You might be able to get a disk of them at Asus,if not im sure they will help you with the best possible advice---Good Luck!
Davey Snake!
Posted on Oct 25, 2010
  • 4 Answers
SOURCE: a new asus eee pc 1005ha boot problem
replace hard drive,
First remove 4 bottom screws, and Ram cover.
remove keyboard by pressing down on the 4 tabs across the top of the keyboard with a small flathead screwdriver. disconnect ribbon from body
once keyboard is removed unscrew the 6 black screws where the keyboard was they are the same as the other 4 bottom so do not worry about mixing.
pop open the top casing starting in the top right working your way around to the top left in a clockwise motion.
remove and replace the harddrive from here.
Find a PC install a program such as WinToFlash (freeware) and create an installable copy of Windows XP on a flash drive no smaller then 2 gb.
Put flash in USB slot
press escape as computer starts choose the USB drive
Format and install XP from flash
Posted on Dec 09, 2010
Asus eee pc 900ha master password hard drive locked
an actual hard drive lock? Those are a bummer, a new harddrive is the only real way.. not even tech support can help with this, I've been down that road, It sucks. the only real way to fix an actual harddrive lock is to remove a chip from the harddrive and solder a new one one. that being said, i had to replace with a new one. with that sector of the HDD locked, not even booting into a bootable CD(like linux) will help, the harddrive will not be dectable.
Oct 29, 2013 | Computers & Internet
Vista will not boot
From the description you have hard drive issues, or windows files are corrupted, I would get the hardware tested out unless have a method of reloading windows.
Apr 29, 2012 | Sony VAIO PCG-505TR Laptop
I have a asus Eee pc notebook,when i turn it on the message REBOOT AND SELECT PROPER BOOT DEVICE appears how do i do that?
check if there is any fashdrive or memory card plugged in. if it shows that message it might mean your pc cant detect a bootable harddrive. was it working before? was it dropped or bumped maybe the harddrive got loose. at the bootup screen do you see your harddrive? if your pc can still detect your harddrive try installing a fresh copy or your operating system. hope this helps.
Aug 24, 2011 | ASUS Eee PC 1000HE Netbook
I have a asus eee pc 100ha.. i had it last december of 2009.. just last night my lcd screen went black.. pls. help.. few weeks back, once in a while it will my screen has displayed liked there is a power...
when i turn my netbook on the lights turn on but the screen doesnt. I figured out that if i leave it running till the battery goes very low it will turn on.
Jun 07, 2010 | ASUS Eee PC 1000HA Notebook
Forgotten password
try pressing ESC 2 or 3 times to bypass this option. Then go to your user account settings and change or delete your password. If all else fails, format HD or burn a bootable windows password recovery program and boot up pc with the disc.
Sep 05, 2009 | ASUS Eee 4G Notebook
Dell vostro 1700 NETIO.SYS 0xc0000098
This is probably a problem with either the media (bad disk, or picky optical drive) or with some hardware. In the first case, I would try to reinstall first, and if that fails consider using a different drive or disk (if possible). As it points to the Netio.sys file, in the second scenario it may be related to a network device (i.e., ethernet). My suggestion in that case would be to remove all devices possible from the computer, and to disable on-board LAN/audio in BIOS to see if that helps.
Apr 15, 2009 | Dell Vostro 1700 Notebook
Laptop will not boot error message missing file sys/32
u need winxp recovery bootable disk for it.then boot with it then u have to repari your win xp .
Feb 09, 2009 | ASUS Eee PC 900 Notebook
Asus Eee PC 2G series will not boot up
Try to unplug the battery, wait 10-15 seconds and plug it again. Sometimes it gets stucked with hardware issues and this is a kind of "reset". It doesn't affect your data.
Jan 07, 2009 | ASUS Eee PC 2G Surf Notebook
ASUS Eee PC 1005HA-PU1X-BK Netbook Logo
157 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
