Question about Motorola Mobility KRZR K1m Cellular Phone
Bootloader USB INIT
When I turn my phone on it goes straight to a blue screen with the motorolla sign and at the bottom it reads "bootloader USB INIT" and I can't get out of it. Any suggestions! I need to flash my phone because it had water damage and it now has a blue screen that says bootloader USB INIT. I need help.
  • 3 more comments
  • bhausler Jan 23, 2009
    same as the other dude, except mine didn't get wet
  • iquest93 Jan 25, 2009
    I have the exact same issue and it is draining my battery because I can't shut the phone off. My KRZR did not get wet either. I was using it last night and when I went to use it this morning the blue Motorola screen with an @ logo on it appeared. I replaced the battery and retried to start it but I got the same message. I called Verizon and they told me to take it to the nearest dealer.
  • Anonymous Mar 02, 2009
    the same thing
  • ritaniki Apr 02, 2009
    blue screen w/motorola symbol on the bottom of the screen it says bootloader usb init - what does this mean?
  • Anonymous May 26, 2009
    Same thing just happened to me too. My phone did not get wet either. Worked fine yesterday and this morning when I turned it on I got the bootloader USB init message.
Blue screen with " bootloader usb init" message
go to service center. need to be reprogram. tnx
Jul 28, 2009 | Motorola Mobility RAZR V3
Bootloader usb init
hold the end key(power) and it should restart back to normal. If it goes back into bootloader then your phones software could be corrupt or could have a wrong value in somewhere. What provider is this?
Jul 23, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Bootloader usb init
This means that the phone firmware is corrupt - you can try to reflash it using Motorola software update, but it might not work for a phone stuck in bootloader mode:
https://rsddownload.motorola.com/download/Motorola_Software_Update.exe
Jul 01, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Bootloader USB INIT
Get this Phone reflashed. Of course if you Dropped the Phone or if it went into water then Forget it about spending 35-50 Bucks on reflasing this phone. because it will go back to Boot Mode.
Sep 06, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Bootloader usb init
basicly the software is corrept.take it 2 a cell 4ne repair shop they will fix it it cost about 150.u cnt do it on ur own coz it takes a specail soft ware n only certain ppl have it
Jul 28, 2008 | Motorola Mobility RAZR V3
BOOTLOADER USB INIT ?????
the phone need to be reflash so take it to a mobile center to have it done or mobile technician.
Jun 06, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Blue screen Bootloader usb init turned my phone off and now it says bootloader usb init?
Goto google and look up Bootloader USB ini you will get results from Howards Forum telling you on how to reflash your phone follow the instructions.. Ignore the post about "V3M bricked but not hopeless" thats mine and its a different situation from yours. Good luck!
Mar 13, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Bootloader usb init
the problem of your unit is not easy,you need a interface and software to fix it,i suggest sent it to any motorola service center...
Jan 20, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Bootloader USB INIT
this happens to phones that have had water damage or something else and a way that might make it work is to take the battery out for no more than 60 seconds and put it back in and push the *,# and power buttons at the same time and if the blue screen comes up, while on the screen push the buttons and hold them until it goes normal. it worked for me
Oct 01, 2007 | Motorola Mobility RAZR V3
Motorola Mobility KRZR K1m Cellular Phone Logo
306 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
