Whats a bigger ariel - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If you mean antenna is it for outside or in the house?
Posted on Nov 05, 2012
Tip
How to change a broken electric ariel on a saab
my electric Ariel stopped working and I was quoted £87 to replace it I bought a replacement on ebay for £13 its a simple fix just undo the Ariel nut on top of the car rear wing get someone to sit in car and push radio button old ariel starts to come out simple assist it until it has completely come away from car put new lead into hole then get person in car to switch of radio and feel the ariel start to be pulled back into place be carful to keep it straight as it enters then replace locking nut total time less than 5 mins cost £13 plus one person to assist easy fix
on May 07, 2015 | Saab 9 Cars & Trucks
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
How to fill an ariel bathtub
The proper way to fill the Ariel Bathtub is to turn on the faucet that is near the tub with warm to hot water to your liking. Once it is above the highest jet in the wall of the tub, if your Ariel tub is a Whirlpool model you may operate the jets.
Rod
US Parts Center
888-521-6183
Mar 17, 2013 | Ariel Platinum AM128JDCLZ Whirlpool...
Whats a bigger ariel????
Loaded question? If you mean antenna is it for inside or outside the house?
Nov 05, 2012 | Televison & Video
Moved house and tv will not tune into inside
You could try a 15dB UHF amplifier that will usually feed upto 2 TV's they cost about £10-15 and usually have a pass through 240V plug and will work with the Sky Magic Eye.
Mar 18, 2010 | RCA Mikomi 5290925 15 in. LCD TV
I need a manual to tune in a Alba LCD 19880HDF . I cannot get it to find channels using a plug in ariel which has always worked for previous TV.
Quite often with different TV, the built in tuners are different, so even though you may have been able to tune in automatically with one you can't with other tv's as there tuner isn't so good, you may want to look at getting a bigger aerial as the 1 you have may not get a strong enough signal for the tv tuner.
Nov 26, 2009 | Televison & Video
LE32R74BDX
this is because most new lcd tv's have a poor tuner built in and require a stronger ariel, to pull in the analogue or digital signal. Check that your ariel is freeview capable whether using freview or not, as these ariels are better at pulling in the signal, or do what i have had to do and buy a mains plug in signal booster from Asda for about £6.00, this did the trick, especially if you don't want to replace an ariel costing about £30.00
Jun 13, 2007 | Samsung LN-R409D 40 in. LCD Television
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
