My plasma has lost volume, picture OK, turns on but not to standby and none of the buttons or remote changes anything?
Volume automatically went down to zero. The remote does not change anything. The buttons on the panel do not have any affect. Turning TV off and back on does not solve the problem and it goes straight on without going to standby.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
First is to remove power from set and a box if used--the sound issue happened at same time? It sounds like the set locked up internally and if unplugging things does not help it may be a main board issue in the set.
Posted on Nov 05, 2012
  • 32 Answers
SOURCE: Yesterday I turned my volume down to zero on my tv
There are two possibilties, the buttons on your TV are stuck on one position or your control inteface board is damaged. I would need mopre info to rectify.
Posted on Jul 24, 2009
  • 325 Answers
SOURCE: No volume without holding remote button
The volume on either on your Remote or Tv is stuck down. This can be caused by spilling Liquid onto the remote (we all do it) you can test which one it is.
take the battery's out of the remote and turn the volume up via the Tv volume button on the telly. If this stays at the required Volume Then this means that the - volume button is stuck down on the remote. Try and clean it with something like a baby wipe or something similar (not a sopping wet cloth) If this does not work then you may need a new remote.
Hope this Helps
Cheers
Little Dish Fitter
Posted on Sep 24, 2009
  • 668 Answers
SOURCE: The volume goes up automatically, then after a few
Most of the time it is the touch button assembly on the tv. The Volume down touch button switch is sticking.
I hope this helps,
Skyassoc
Posted on Dec 08, 2010
eagle338
  • 4889 Answers
SOURCE: TV does not respond to
When this kind of a problem appears it is usually due to a malfunctioning microprocessor IC . The IC cannot be replaced and the board has to be replaced as a whole. Replacement board should run you about 100$. I can find you a replacement if you are interested in fixing it.
Sai.
Posted on Jan 11, 2011
drifterK
  • 4924 Answers
SOURCE: AT NIGHT, TV SWITCHES ON AUTOMATICALLY AND CHANGES
what you describe is almost impossible ..the only explaining is someone with a compatible remote control messing around with you ..so ...pay attention ..and after that if you are completely sure that this is out of case...Leave a comment and I will search for another possible cause ..
Posted on Mar 17, 2011
My LG Plasma TV
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 04, 2016 | LG Electronics 60PB6650 60 Inch PLASMA
Rca 42pa30rq
Hi! Hope this will give hint... I understand some televisions nowadays are fully controlled using remote but there is always a standby power button for the television remote function. If the there is no power after turning on using the standby power button please check power cables, supplies and fuses. If the television has a standby power waiting the remote to act on but no response after pushing the remote's power button check the battery and its contact. Goodluck.
Mar 18, 2014 | Televison & Video
Panasonic tv
Try couple of things .hold the volume button on the tv and at same time press the menu button rapidly 3 times.if this does not get into the correct screen try holding the volume button on tv and press the zero(0) button 3 times rapidly and another is to hold volume button on tv and press zer(0) button on remonte rapidly 3 times each o fthese methods these should get you into various set up screens but be careful and take notes if you change settings .you may have to unplug or turn power off at mains and power up again to see changes
Feb 16, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
TV remote non-functional
do a factory reset: input, setup, fac reset, all settings: passcode 3355. you should be ok
Jan 15, 2007 | Dell W4200 42 in. HD-Ready Plasma...
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
