My alba tv had stoped picking up the signal
Its worked the just automatically stopped working not picking up signal for the freeview or normal television and my other tvs pick it up using the same ariel
    Genius:
  • Televison & ... Master
  • 2,432 Answers
If your tv has only a raster display or just like a snow white raster appear with any channel receive, the cause is failure in the tuner board. the problem either has a loose connection inside of the tuner or no supply .if you have the tools like the philip screwdriver and soldering iron you can do this . remove the cover to access the internal part of the tv then look for the tuner, the tuner board this is where your areal antenna hooked up covered with metal. remove the metal cover then check weather the connection going to the RF coaxial of the tuner get broken or loose contact, just re soldered the connection.if still no channel receive, at this time you will need to have voltage checking which provide a digital tester. if you don't have an idea about this at this time you need a help with a trained tv technician.
Posted on Nov 06, 2012
  • 2318 Answers
SOURCE: No signal on tv
Since the TVs are less then a year old, they're still under manufacturers warranty. LG Contact Information Main support number 1-800-243-0000
Email: supportcustomerservice@lge.com
Posted on Aug 15, 2008
SOURCE: philips 50" tv will not pick up remote signal
Even tho we change settings on Phillips flatscreen Model 50pfp5332, if we turn it off and back it' shows it's RETAIL SETTINGS. We do not have the original manual and would appreciate your help........
Posted on Sep 12, 2009
  • 8 Answers
SOURCE: I need a manual to tune in a Alba LCD 19880HDF
Quite often with different TV, the built in tuners are different, so even though you may have been able to tune in automatically with one you can't with other tv's as there tuner isn't so good, you may want to look at getting a bigger aerial as the 1 you have may not get a strong enough signal for the tv tuner.
Posted on Nov 26, 2009
Testimonial: "thank you, will try that tonight"
dvdcdlaser
  • 1285 Answers
SOURCE: my tv wont pick up any channels
have you switch the broadcast to Air from Cable using the remote go to this and also let it scan for channels auto...hopefully this will do the trick
Posted on Jul 26, 2010
SOURCE: freeview is not working on my samsung tv
Freeviw not working on my Samsung LA40A750D but did work through a free view box on another tv previously
Posted on Dec 20, 2010
Hi have a built in freeview alba tv tune in channels working fine but dont have any bbc or c4 c5 any one can help me or send tv back
Can't tune Alba LCDW16HDF :( - Freeview - Digital Spy Forums
forums.digitalspy.co.uk/showthread.php?t=1238173
Digital Spy
Apr 1, 2010 - 17 posts - ‎8 authors
No matter what the problem DS Forum posters will always provide an answer ... That the Alba is your only digital television receiver - you don't have another ... I suspect the set may have found Craigkelly's BBC & ITV/C4/C5 ... BBC Three questions? - Broadcasting
Dec 13, 2015
Why dont RTE do this - Page 2 - Broadcasting
Aug 21, 2015
Channel 4 Licence Renewal and Scotland - Broadcasting
Mar 12, 2014
Why Won't Freesat/BBC let Viewers Nationwide have ...
Jan 20, 2014
More results from forums.digitalspy.co.uk
Freeview Help: Missing Freeview Channels - Radio and Telly
Jan 01, 2016 | Alba Televison & Video
Alba set top digital freeview box
normally its - press menu - install - scan for channels and then save
something similar to this
hope it helps davetech
Aug 08, 2014 | Alba DVBT set top box
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | Televison & Video
I have just purchased an Alba LCDW16DVDHDF and it is not picking up all the freeview channels (including BBC). Is it a problem with the TV or with the signal from the aerial?
By pressing the volume + & - buttons at the same time on the TV itself you will bring up the master setup menu.
From here you can select first time installation and the TV will auto retune to the new digital stations
Feb 28, 2010 | Televison & Video
After having to retune my Alba Freeview Digital Top Box - Model No. A002157058939 - on September 30th to allow for better digital reception of Channel 5, I am no longer able to receive ITV3. Have retuned...
You may need a better aerial. Digital TV signals need good signals or you can't pick up the full range of channels. Broadcasters and others are tending to keep their mouths shut about the expense of needing much better things on the roof than what many people use to get away with on analog signals. Even if you have a good aerial, If you have the 'brown' coax cable connected to it you could lose signal and stations. So it's best to replace it with Satellite coax cable FT100. That should stop a lot of blocking caused by interfearance by cars or those off road bikes youths ride around on.
Oct 04, 2009 | Televison & Video
Built in freeview doesn't work but digibox does
Have you done a channel search on both tv sources(atv and dtv). most new tv's will automatically start will "New Install". If you havent had a digital installed recently then this could the problem. set top boxes and TV's will pick up the signal ok but others wont.
Sep 16, 2009 | Hitachi Televison & Video
Dont not pick up freeview channels
if u pick up NON freeview channels, i think the antenna isnt good enough to pick up the signal..freeview requires a very good signal, very important.
If you think this isnt the problem rescan the channels
If you think the TV is faulty contact Samsung directly
Jul 15, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Do not understand how to set up my alba digi box to my television and recieve basic digital channels help!
Hi.
Ok
1) plug aerial in to the antena in sock on freeview box.
2) plug short aerial type lead in to rf out socket on freeview & antena in socket on TV.
3) plug A scart lead in to the socket marked TV on freeview box & the other end of scart in to one of the scart sockets on the TV.
If your TV has more than one socket plug it into the one marked AV1 or AV2.
4) plug in freeview to mains electricity & switch box on.
5) Turn TV on freeview should appear automatically if it doesnt look on your TV remote for A button marked AV or a button with either A circle or square with an arrow going through it you may need to press this several times until you see digi picture come up.
Thats basically it but do check that you dont need a new aerial etc to be able to get digi signal in your area.
http://dysonmanuals.llc.nu/
Jul 26, 2008 | Televison & Video
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
