Question about HP Laserjet 1020 Workgroup Laser Printer cd & All Plugs Very Good Condition
Printing is not proper. sometime margin cuts from one side and now, white strips are coming in between the paper print.
  • Pankaj Sharma Nov 05, 2012
    i guess, cartridge problem is there... plz help me out..
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Check your leser unit properly
Posted on Nov 06, 2012
Delphi51
  • 33 Answers
SOURCE: paper margin problem in pagemaker application
Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
Posted on Sep 10, 2007
  • 112 Answers
SOURCE: paper feed
The feed rollers are slipping on the surface of the label, causing the page to load incorrectly. There is no permanent solution at this time. Try one of the following workarounds to correct this issue. Workarounds Workaround 1 Adjust the top margin using Page Setup.
  1. Click File , then Page Setup in the program being used, (accessing Page Setup may vary from program to program. Refer to the Help file for that program).
  2. Adjust the top margin until printing is correct on the label.
Workaround 2 Manually print one sheet at a time. Place one sheet of labels in the input tray at a time, printing only that page. Repeat for all pages of labels needed.
Posted on Jan 15, 2008
SOURCE: Problem printing business cards
in your program adjust the pic your printing to fit in yours sumtimes u have to adjust your print in preview box your card u made down or up whole thing so it fits in nice for u sumtimes they just dont line up right i had same issue just move your project up with it ok to make it print in box cards u need ok
Posted on Mar 13, 2008
Ajkill
  • 2035 Answers
SOURCE: paper feed problems hp PSC 1510
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Oct 17, 2008
CompuGuy44
  • 432 Answers
SOURCE: Printer does not print whole document
In 'Print Preview' look at the margins, and see if anything is too close to the edge of the paper. If it is, then set your margins further from the edge, or drag graphics further from the edge, etc.
To correct the margins that are set to close to the edge of the paper, open the document in Microsoft Word and follow these steps:
  1. Make sure that you are using the same printer driver that gave you the error in Microsoft Word Viewer.
  2. In Word, on the File menu, click Page Setup.
  3. Click OK.
    You receive a warning dialog box about the unprintable regions.
  4. Click the Fix button.
  5. Save and close the document.
You can now open and print the document in Word Viewer without receiving the error message.
Posted on Dec 19, 2008
Why won't the printer print .5" margin on the side
1. The side guides of the paper tray are adjustable and should be snug to the edges of the paper. To loose and things can begin to shift.
2. Are you using letter sized paper or A4. Your print driver and word processing program need to know this.
3. The driver and processing program have margin adjustments within them. They are usually good by default but perhaps another user was in there and changed things.
4. Is the print job specked for the correct orientation....portrait or landscape and is the paper loaded the same.
Jul 25, 2014 | HP Office Equipment & Supplies
When printing the document info is cut off on the left hand side op the paper
printer tiflon is damage please contact the shop kapeer and repair tefon paper
Apr 13, 2012 | Canon LBP6000 Laser Printer
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
Ricoh prints everything in left Margin
Check the printer properly and see what size paper the printer thinks is in there, or check at the controll panel.
-Carl, please let me know if this helps.
Jun 25, 2009 | Ricoh CL3500N Laser Printer
Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Jan 08, 2009 | Lexmark Optra T610 Laser Printer
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
Outlook Printing Problems
open ie, change margins in file/page setup and try it again
Apr 08, 2008 | Microsoft Office Outlook 2003 for PC
Canon Imagerunner C3200 - printing problems
check the feeder rollers and make sure they are grabbing the page at the right time. Sometimes rollers cna get slick and spin for a moment before picking up the paper. This can cause the timing to be off when the page is fed through.
Mar 06, 2008 | Computers & Internet
Margin problem???
I can just guess it has to do with the paper being fed. either you have the paper wrong or the paper settings to a different size then the actual dimensions of your print material.
Oct 24, 2007 | Dell 3100cn Laser Printer
Margin printing problems
Check your application's print settings (for e.g. MS Word). Then check the printer's properties and print settings. If nothing works you also try re-installing the latest printer driver. If you use MS word should check the page setup option, for paper size errrors. If the color of your margin is red and the red ink is out then you won't se the margin line.
Oct 09, 2007 | HP Color LaserJet 2600n Printer
HP Laserjet 1020 Workgroup Laser Printer cd & All Plugs Very Good Condition Logo
50 people viewed this question
Seeker5211
Seeker5211
