Question about HP Mini 210-1030NR Netbook
My hp netbook wont turn on, what shoud i do?..
I tried turning on using the charger only but still doesnt work...help..''
    Novelist:
    Champion:
  • 233 Answers
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement HP Mini 210 AC Adapter Cord 30Watt 19V 1.58A
Posted on Nov 07, 2012
5 Suggested Answers
  • 111 Answers
SOURCE: My HP Compaq nx9030 wont turn on
try to remove your memory/ies. then plug it to ac power without battery, if it turns on try to unplug and put back the memory module (one by one if more than 1). plug and switch on if it works then put everything back if not, you ned to replacethe memory.
Hope this helps.
Please vote if it does.Thanks!
Posted on Apr 18, 2008
  • 2567 Answers
SOURCE: Was using my Hp Pavilion dv7 laptop, suddenly
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Posted on Oct 10, 2010
  • 16 Answers
SOURCE: My laptop Hp G60 won't turn on the charger light
Maybe you have disconnected the small cable which connects the power button to the motherboard. Or your charging unit at the back of your laptop is faulty, take the cover off and click the button without it on maybe a alternative. Only other solution would be have you had a powercut recently?
regards,
jon
Posted on Apr 21, 2012
Geekman
  • 32281 Answers
SOURCE: hi my hp mini netbook turned itself off and wont turn back on. iv tried takin the battery out and put it back in. iv also tried leaving it plugged in for a while and nothing. the hp symbol comes up an
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Oct 24, 2012
My eee pc netbook won't turn on I need help
1-remove the battery and put it again
2-turn it on from the power button
3-if it doesnt work press F1
Jan 27, 2013 | Computers & Internet
My BH-503 wont turn on again. The reset option (hold multi key + volume up) doesn't help at all, in fact. Nothing really happened! The only thing is does right now is: that the indicator blinks...
i thing that for you use the Different charger try to use this original charger that was came with it and if you have any another problem you can chat with me ad try to find all Solution my Email xxhemaxx@live.com
May 19, 2011 | Nokia BH-503 Bluetooth Headset
Net book is stuck windows screen. Wont turn off
If this is only a one time problem, simply unplug the charger and remove the battery, leave the battery outside for few minutes and again reinstall it, now turn on the machine. It should work fine. Must be it's too hot and hanged/freeze.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 16, 2010 | HP Mini 1000 Netbook
Lenovo netbook wont turn on. It is brand new, and ...
hi! just a tip if its a brand new one try to isolate the problem check if it can actually run by removing the battery just by the ac adapter if still doesnt work then probably you have to charge the battery first if it still doesnt charge then probably there is somethin wrong with the power board. i suggest you call your lenovo tech support for further assistance. hope this would help goodluck!
May 20, 2010 | Lenovo IdeaPad S10e Netbook
My iphone 2g wont charge & wont turn on
Try using another cable or charger. A damaged charger or cable could cause it not to charge.
Otherwise, contact apple or apple store for repair.
May 06, 2009 | Apple iPhone Smartphone
Hope this helps.
Apr 18, 2008 | HP Compaq nx9030 Notebook
HP Mini 210-1030NR Netbook Logo
81 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
