Question about Tricity Bendix AW1000W Front Load Washer
How to get the top of my bendix washer after taking out the screws
    Top Expert:
  • Tricity Bendix Master
  • 9,472 Answers
It should slide back a quarter of an inch or so and lift off.
Posted on Nov 05, 2012
How do i take the back cover off my machine to check the belt
Take off the lid. (MAKE SURE IT IS UNPLUGGED) There are 2 screws towards the rear of the sides on the top. There are also 2 screws at the bottom corners on the rear of the machine. Lift out the panel holding the fill solenoids at the top on the rear of the machine and the rear can then be pulled away from the back of the machine. It sort of slides on. Hope that helps.
Jul 26, 2011 | Tricity Bendix AW1400W Front Load Washer
Trying to organise changing brushes in Tricity Bendix AW 1400. I'm in Scotland, daughter and machine in England! Does top or back come off machine to allow access and is motor fairly accessible for...
Washing machine motors are usually induction motors and do not have brushes? Anyway, the back comes off and that normally gives access to the screws that hold the top on, but the motor is normally located at the bottom of the machine.
Feb 14, 2011 | Tricity Bendix AW1400W Front Load Washer
We cannot get the door open. We did one load and the door will not open. We went through the cycles fast just to see how it worked and must have screwed up. How can we open door?
take top of washing machine by taking of 2 screws at back and push top forward then follow the rod from the pushbotton down to the door, push the spring back in and bob is yoyr aunti
Nov 20, 2009 | Tricity Bendix WDR1040W Front Load Washer...
How to replace belt on tricity bendix aw440 washer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Oct 12, 2009 | Tricity Bendix Washing Machines
How do i fix my bendix washer
hi! you need to un clip orpull the draw out (easy enough!) then give it a good clean, there will be a little tube in the draw that will be gunged up! a pipe cleaner or ear bud wil clean it through, with lots of hot water!
Dec 20, 2008 | Tricity Bendix AW1400W Front Load Washer
Screw inbetween the drum and the outer shell
if you take the rubber empting tube off the bottom of the drum you can work the screw down to the bottom and out of the hole. ensure all electrics are un plugged obviously.
Jun 14, 2008 | Tricity Bendix AW1400W Front Load Washer
Bendix 800 autowasher
put it on its back on yhe top side of the motor you will see the brushes two screws hold each one on.
Jan 03, 2008 | Tricity Bendix AW1000W Front Load Washer
Top oven grill brackets on Model SE553
you won't get a freebie replacement on a 3 year old oven!
i've had this problem many times and solve it by using penny washers and nuts and bolts to fasten the brackets
Dec 29, 2007 | Tricity Bendix SE454 Electric Kitchen...
Tricity Bendix AW1001w
is the door locking if not replace it.
Nov 23, 2007 | Tricity Bendix AW1000W Front Load Washer
Washing machine makes beeping noise
It sound like a lid switch problem .A defective lid switch will notice of an open door when actually door is physically closed, and will prevent washer's spining and function at all. The switch located inside the machine near the door frame. You should open the top panel (open 2 screws and then slide it out) and you will have an access to it . You can test it by multi-meter (it is an on/off switch). In case of a deffective switch, it should be replaced. Be aware that you should remove machine's power cable before starting your test !!!! Good luck !!!
May 30, 2006 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
