Question about Daewoo 3.3 CuFt Top Load Washer - DWF-33AMW
My machine shows LE and keep buzzing - Daewoo 3.3 CuFt Top Load Washer - DWF-33AMW
    Top Expert:
  • Daewoo Master
  • 9,472 Answers
Replace the lock switch
Posted on Nov 05, 2012
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
My Daewoo DWF 806 MP doesnt dry/spin after washing and rinsing and shows LE error. When drying starts some sound comes and then LE error apperas
my Daedwoo DWF-806 MP machine when i swith on shows figure 49 and not figure 0, and it also making noise like Buzz in between when the machine is ON. Can anybody help me to resolve this defect
thanks
Nov 01, 2013 | Daewoo Washing Machines
My daewoo washin machine shows error code LE & it wont work actually whats the problem ? tq
my daewoo washing machine has error code LE
after every wash , it cannot rinse and spin then show
beep sound and show code LE. Thank you
Oct 06, 2010 | Daewoo Washing Machines
My washer just keeps on buzzing and it and the time is showing on the machine
If no water is going into the machine..Could be due to supply turned off or faulty solonoid valve within machine.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I keep gettine the letters LE come up and my machine wont work whats does LE mean
if this is a LG washing machine code LE is motor fault call engineer
Feb 11, 2010 | Washing Machines
LG WM-2077C CODE LE
LE stands for locked motor error. Sometimes just unplugging it for about 10 minutes will fix it, but if not you will probably have to replace the motor position sensor(hall sensor) or the motor.
Dec 05, 2009 | LG WM-2077C Front Load Washer
Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
Sep 14, 2009 | Washing Machines
Samsung washing machine shows error "LE"
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jun 14, 2009 | Samsung WF203ANW Front Load Washer
Daewoo 3.3 CuFt Top Load Washer - DWF-33AMW Logo
166 people viewed this question
Top Daewoo Washing Machines Experts
dweatherby
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
