Question about Maytag Washing Machines
I sm not sure if I mentioned, but it is a front load, model amh4000aww. It was running fine, until I had a roomate who overloaded it, and used the wrong detergent, I was hoping it was a belt, that
I am sorry for any inconvenience, but I put the incorrect model number, I am exhausted, and a dingy blond to top it off, so I am very sorry, but the correct number is.. mah4000aww
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What problem are you having?
Posted on Nov 05, 2012
the dr
  • 447 Answers
SOURCE: LSE7806A Top Load
The belt is still attached to the transmission right?? It sounds like the brakes may be stuck. Or are both belts off and the motor still trips out?
Posted on Dec 05, 2007
Coldcut
  • 1554 Answers
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Posted on Mar 04, 2008
  • 1294 Answers
SOURCE: Maytag Model # MAH4000AWW Neptune
Clean out your filter after ref. to user's manual. Try some WD40 on the door mechanism (on machine), lock & unlock door 5 or 6 times while machine is off.
Posted on May 10, 2008
SOURCE: Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
Posted on Oct 07, 2008
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
My cuisinart 5.5 stand mixer when you press the on button it starts for a second then it stops.
Make sure the plug is securely plugged into the wall.
Next, remove and reattach any mixing arms etc that may be attached to the mixer. Having one not attached properly can result in a start, start.
If problem persistes make sure the speed is reset.
If problem continues, here is an excerpt from the user manual found here.
http://www.cuisinart.com/share/pdf/manuals/sm-55.pdf
Problem: Your stand mixer has an
overload protection device and if
overloaded, it will shut down to protect
the motor.
Solution: In the unlikely even that this
happens:
• Turn off and unplug the unit.
• Reduce the load by removing some of
the ingredients, and allow the mixer to
stand for a few minutes.
Plug in and reset the speed. If the
stand mixer does not start when you
press the on button, allow the unit to
stand for additional time.
If you are still having trouble, the product comes with a 3 year limited warranty, so if you're bought it within the last 3 years it may be covered.
Good Luck!
Mar 01, 2011 | Cuisinart SM-55 Stand Mixer
How to down load inter mother board drivers and sound drives i sm strungle to drivers softwear
its easy to me if you mentions the model number of mother board <br />just try this link below:<br /><a href="http://www.updrivers.com/drivers/Motherboard/Intel/13/176.html">http://www.updrivers.com/drivers/Motherboard/Intel/13/176.html</a> <br />thanxs<br /><br />
Aug 30, 2010 | Intel Motherboard
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
Dryer shuts off right after started
You don't mention the model or make of dryer but this problem is usually due to a small component in the machine called a thermal overload switch. This switch stops the dryer when the elements get too hot. However, it often malfunctions and turns off the dryer the moment you use heat settings. The overload switch is inexpensive and should easily be found at your local appliance dealer.
Best wishes,
Graemevm
Dec 17, 2009 | Washing Machines
Maytag neptune washer model fav6800aww wont finish spin cycle
Hello c bellone,
If you rotate the clutch pulley by hand CW the tumblers should rotate in the wash basket. If you rotate the clutch pulley CCW the tumblers will rotate until the clutch spring comes under tension then the wash basket will begin to turn CCW and the tumblers will stop rotating because the transmission rotates with the wash basket. Do you have this action?
The clutch has been an issue for many are you taking dc or UC errors to the display? This clutch incorporates a Drawn Cup Roller clutch bearing (one way clutch bearing) designed to rotate freely CW and lock up CCW to rotate the spinner shaft in spin cycle rotating the wash basket/transmission CCW. You are halfway thru the clutch removal process, I would drop the clutch out and inspect the roller clutches, clean them up with WD-40 and some light bearing grease. If they are rusted up beyond clean up and or the clutch spring is broken as in this post you will have to replace the clutch. You will know what you are up against once the clutch is out and opened up for inspection.
Here is the process I use for clutch removal;
Access and remove the Clutch for maintenance
Disconnect 120VAC power cord.
The
Service Manual for reference. Sears Parts Direct for reference.
Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
Remove the front panel see page 41.
Tools required;
3/8 inch socket and socket wrench to remove clutch pulley bolt. Page 47 of the SM
1/2 inch socket or wrench to loosen Drive Motor tension bolt.
5/16 nut driver or 5/16 ¼ socket on an extension to remove front panel see page 41 of the SM.
1. Lean the washer back and blocked in that position for a better reach angle. Rotate 3/8” clutch Pulley Bolt CW to remove clutch bolt.
2. Follow SM page 46 & 47 to remove clutch pulley.
3. Remove 4 screws holding plastic cover on clutch, inspect clutch spring to make sure it is not broken. Inspect roller bearings clean up with WD-40 and re-lube with bearing grease.
4. Replace white bearing plate into clutch pulley hub, insure key slot slips into clutch Spring pin in clutch hub.
5. Replace Clutch plastic cover with 4 screws.
6. Reseat clutch on spinner shaft and rock back and forth while lifting clutch with upward pressure to reseat clutch. When seated properly you will feel a 1/16-1/8" gap between the Pulley face and shaft end as mentioned and shown on page 47 of the SM. On reinstallation, tighten Clutch Pulley bolt CCW to 96” pounds 8’ foot pounds (Snug no torque wrench required).
7. Do a quick wash and make sure clutch runs true with no wobble or clicking sound. If the clutch has not been seated properly it will spin off. If this happens go to page 16 of the SM Board Output Test and turn on Drain Pump in Service Mode to pump out excess water.
8. Repeat steps 6&7 if the clutch has excessive noise or spins off.
My clutch open up for clean up.
Apr 20, 2009 | Maytag Neptune FAV6800AW Top Load Washer
How do I reset paswrd for DL524 router so my laptop can connect
- Press and hold the reset pinhole at the back of router for 10 seconds with a paper clip.
Mar 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
The spinner gets off balanced make knocking sound
Ok first is it a top load or front load and I need the model number inside the lid or door.
Sep 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 washer won't drain
ckd pump traps for debris on kenmore remove front panel on samsung i think a rear approach is best
Jun 03, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
